Home » Language IDEs » ServerTools (WTP) » Case problem with org.eclipse.wst.wsdl
Case problem with org.eclipse.wst.wsdl [message #195596] Tue, 03 July 2007 15:36 Go to next message
Originally posted by: jdoyleoss.gmail.com
I'm having a problem using org.eclipse.wst.wsdl. I'm creating a resource
from a WSDL and a ClassNotFoundException is occurring. I have debugged it
down to the point where the EPackage from the org.eclipse.wst.wsdl plugin
is called to resolve the EClassifier for the wsdl:definitions tag. It
seems that the EPackage is only aware of Definitions, not definitions as a
name. This seems like a defect to me, since it is defined as
wsdl:definitions in the wsdl schema. I imagine this code should be case
sensitive, but think it should be aware of the lower case name.
I didn't find a defect logged. Has anyone seen this before?
~jd
Re: Case problem with org.eclipse.wst.wsdl [message #195604 is a reply to message #195596] Tue, 03 July 2007 18:43 Go to previous messageGo to next message
Originally posted by: valentinbaciu.hotmail.com
What type of resource are you using? The org.eclipse.wst.wsdl plug-in
provides a specialized resource implementation - WSDLResourceImpl. If you
are using the code outside Eclipse you have to register a resource factory
with EMF to instruct it to use this resource implementation. Something like
this should do:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "wsdl",
new WSDLResourceFactoryImpl());
WSDLPackage pkg = WSDLPackage.eINSTANCE;
It would help if you describe your scenario in more detail: are you using
the code from an Eclipse plug-in or as a standalone Java app, what version,
etc. A sample snippet of code would also help understand what you are trying
to do.
Valentin
"jd" <jdoyleoss@gmail.com> wrote in message
news:1335eb5360b0f9b9ea8c1c3e680907b3$1@www.eclipse.org...
> Thanks
> ~jd
Re: Case problem with org.eclipse.wst.wsdl [message #195698 is a reply to message #195604] Thu, 05 July 2007 10:41 Go to previous messageGo to next message
My plugin is running in an eclipse based environment and uses the
org.eclipse.wst.wsdl plugin. I haven't registered as you describe because
I am in an eclipse env. When I create the resource the resource
implementaion you noted is implementation that is created for me. My code
is this:
Resource res = resourceSet.getResource(uri, true);
Resulting in the following stack:
Thread [main] (Suspended (entry into method <init> in
ClassNotFoundException))
ClassNotFoundException.<init>(String, EFactory, String, int,
int) line: 28
SAXXMIHandler(XMLHandler).validateCreateObjectFromFactory(EF actory,
String, EObject) line: 1402
SAXXMIHandler(XMLHandler).createObjectByType(String, String,
boolean) line: 755
SAXXMIHandler(XMLHandler).createTopObject(String, String)
line: 765
SAXXMIHandler(XMLHandler).processElement(String, String,
String) line: 462
SAXXMIHandler(XMIHandler).processElement(String, String,
String) line: 65
SAXXMIHandler(XMLHandler).startElement(String, String, String)
line: 449
SAXWrapper.startElement(String, String, String, Attributes)
line: 73
SAXParserImpl$JAXPSAXParser(AbstractSAXParser).startElement( QName,
XMLAttributes, Augmentations) line: not available
XMLDTDValidator.startElement(QName, XMLAttributes,
XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanS tartElement()
line: not available
XMLDocumentScannerImpl$ContentDispatcher.scanRootElementHook ()
line: not available
XMLDocumentScannerImpl$ContentDispatcher(XMLDocumentFragment ScannerImpl$FragmentContentDispatcher).dispatch(boolean)
line: not available
XMLDocumentScannerImpl(XMLDocumentFragmentScannerImpl).scanD ocument(boolean)
line: not available
XIncludeAwareParserConfiguration(XML11Configuration).parse(b oolean) line:
not available
XIncludeAwareParserConfiguration(XML11Configuration).parse(X MLInputSource)
line: not available
SAXParserImpl$JAXPSAXParser(XMLParser).parse(XMLInputSource)
line: not available
SAXParserImpl$JAXPSAXParser(AbstractSAXParser).parse(InputSo urce) line:
not available
SAXParserImpl$JAXPSAXParser.parse(InputSource) line: not
available
SAXParserImpl(SAXParser).parse(InputSource, DefaultHandler)
line: not available
XMILoadImpl(XMLLoadImpl).load(XMLResource, InputStream, Map)
line: 140
XMIResourceImpl(XMLResourceImpl).doLoad(InputStream, Map)
line: 169
XMIResourceImpl(ResourceImpl).load(InputStream, Map) line: 977
XMIResourceImpl(ResourceImpl).load(Map) line: 832
ResourceSetImpl.demandLoad(Resource) line: 249
ResourceSetImpl.demandLoadHelper(Resource) line: 264
ResourceSetImpl.getResource(URI, boolean) line: 349
The specific call that fails leading to the exception is
getEClassifier("definitions") call on the WSLDPackageImpl that is created
by the call to getResource(). If I change the value from "definitions" to
"Definitions", the call succeeds (then fails on the next call with
"types"). The version of the wsdl jar is 1.1.0 (200602061610). Perhaps
this is to old.
~john
Re: Case problem with org.eclipse.wst.wsdl [message #195706 is a reply to message #195698] Thu, 05 July 2007 11:03 Go to previous messageGo to next message
For some reason it seems that your code actually ends up trying to load a
definition instance using the default EMF XML resource implementation
instead of the WSDL resource implementation. You can see this by following
the stack trace. Are you sure your URI references a file with a .wsdl
extension? If possible post a concrete example plug-in as a zip file here.
news:1caba969c41398d6f13abd60ba59a62a$1@www.eclipse.org...
> is this:
> int) line: 28
> boolean) line: 755
> SAXXMIHandler(XMLHandler).createTopObject(String, String) line:
> 765
> String) line: 462
> String) line: 65
> line: 449
> line: 73
> line: not available
> line: not available
> line: not available
> line: not available
> not available
> line: not available
> line: not available
> not available
> available
> line: not available
> line: 140
> XMIResourceImpl(XMLResourceImpl).doLoad(InputStream, Map) line:
> 169
> this is to old.
> ~john
Re: Case problem with org.eclipse.wst.wsdl [message #195714 is a reply to message #195706] Thu, 05 July 2007 12:10 Go to previous messageGo to next message
I'll see if I can produce a reproduction of this.
Does it matter that I end up with the default? When the
creatObjectByType() call makes the following two calls (causing the
failure) it is using the correct eFactory (WSDLFactoryImpl).
EObject newObject = createObjectFromFactory(eFactory, name);
validateCreateObjectFromFactory(eFactory, name, newObject);
~john
Re: Case problem with org.eclipse.wst.wsdl [message #195719 is a reply to message #195714] Thu, 05 July 2007 13:34 Go to previous messageGo to next message
The WSDL model provides the specialized resource implementation that must be
used when loading/storing definitions.
You cannot use the default serialization mechanism because the WSDL model
does not provide the required EMF extended metadata to make it work (that is
to map element names to class names). That kind of metadata is produced by
default for models that were generated from an XML schema or can be added
later. The WSDL model was not generated from the WSDL schema but from a UML
model.
Valentin
news:365a53ad614c5ece2dda36eaa59fa0e7$1@www.eclipse.org...
> ~john
Re: Case problem with org.eclipse.wst.wsdl [message #195724 is a reply to message #195719] Thu, 05 July 2007 14:54 Go to previous messageGo to next message
That's it. The wsdl plugin that is in my product has no extension points
in its plugin.xml. I'll have to investigate where this plug-in comes from
and make sure it gets the correct plugin.xml
Thanks a lot Valentin.
~jd
Re: Case problem with org.eclipse.wst.wsdl [message #195729 is a reply to message #195724] Thu, 05 July 2007 15:40 Go to previous messageGo to next message
Yeah, that would be a problem because then you'd be missing this:
<extension point="org.eclipse.emf.ecore.extension_parser">
<parser
type="wsdl"
class="org.eclipse.wst.wsdl.internal.util.WSDLResourceFactoryImpl ">
</parser>
</extension>
which is the declarative equivalent of this
Just out of curiosity, what version is the WSDL plug-in?
news:74af4ef1671c22c663cec26f4c7e08b2$1@www.eclipse.org...
> ~jd
Re: Case problem with org.eclipse.wst.wsdl [message #195736 is a reply to message #195729] Thu, 05 July 2007 15:47 Go to previous messageGo to next message
I'm not sure if it's a version release by eclipse, or something someone
cobbled together in-house in my group. The closest thing to a version is
1.0.0. Here's the plugin.xml contents. I think the variation of the
dates indicates that it's something cobbled together.
There's a lot more than one extension missing here.
<?eclipse version="3.0"?>
<plugin
id="org.eclipse.wst.wsdl"
name="%pluginName"
version="1.0.0"
provider-name="%providerName">
<runtime>
<library
name="org.eclipse.wst.wsdl.validation_1.0.1.v200602030355.jar ">
<export name="*"/>
</library>
<library name="org.eclipse.wst.ws_1.0.0.v200602061953.jar">
<export name="*"/>
</library>
<library
name="org.eclipse.wst.ws.parser_1.0.0.v200602062000.jar">
<export name="*"/>
</library>
<library name="org.eclipse.wst.wsdl_1.0.0.v200602061610.jar">
<export name="*"/>
</library>
<library name="org.eclipse.wst.wsi_1.0.1.v200602030355.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.wsdl4j" export="true"/>
</requires>
</plugin>
Re: Case problem with org.eclipse.wst.wsdl [message #195742 is a reply to message #195736] Thu, 05 July 2007 17:08 Go to previous messageGo to next message
Yeah, that looks awfully old. And because it doesn't seem to have the markup
to define the association between the file extension and the resource
factory you will have to do that in code as I showed you in my first post.
If possible you should try moving to the latest version that is part of WTP
2.0
http://download.eclipse.org/webtools/downloads/drops/R2.0/R- 2.0-200706260303/.
news:310f50e63d9839c3874d38166a79b613$1@www.eclipse.org...
> <plugin
> name="%pluginName"
> version="1.0.0"
> <runtime>
> <library
> <export name="*"/>
> </library>
> <export name="*"/>
> </library>
> <library
> <export name="*"/>
> </library>
> <export name="*"/>
> </library>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> </plugin>
Re: Case problem with org.eclipse.wst.wsdl [message #195795 is a reply to message #195742] Fri, 06 July 2007 10:15 Go to previous message
Thanks again for the help and the education on EFactories and the metadata
they contain.
~jd
Previous Topic:Tomcat 6 NIO connector & startup
Next Topic:Europa Run modules directly from workspace.
Current Time: Fri Jul 25 19:44:40 EDT 2025
Powered by FUDForum. Page generated in 0.07016 seconds
