Home » Language IDEs » ServerTools (WTP) » Dynamic Web Project & Dependencies
Dynamic Web Project & Dependencies [message #195458] Tue, 03 July 2007 00:32 Go to next message
Originally posted by: eclipse.news.codefarm.com.au
I've got a dynamic web project which I am trying to run on Tomcat 5.5
through WST.
I'm using Eclipse 3.2.0.
My dynamic web project depends on a few simple Java projects in my
workspace. When I publish and run it, the first reference to a class from
these projects causes a fatal NoClassDefFoundError and the server doesn't
start.
Is there a way to make sure these dependencies are deployed when I publish
my dynamic web project or is it best that I just deploy these as jars wo
WEB-INF/lib with an Ant build before I publish ?
Re: Dynamic Web Project & Dependencies [message #195489 is a reply to message #195458] Tue, 03 July 2007 05:21 Go to previous messageGo to next message
You can.
1. Right click on the Dynamic Web Project and choose Properties.
2. Go to the J2EE Modules Dependencies.
3. In the table you will see your Java project as nodes. Select the ones you
want to include.
4. Click OK.
You will still not see the Java projects you have selected under the
WEB-INF/lib folder of you web project. But when you do Export or Publish of
the web project, then the dependent Java projects will be packed as JARs and
included in the WEB-INF/lib of the produced WAR file.
"Ben Iggulden" <eclipse.news@codefarm.com.au> wrote in message
news:f6cjhg$hbh$1@build.eclipse.org...
> through WST.
> start.
Re: Dynamic Web Project & Dependencies [message #195660 is a reply to message #195489] Wed, 04 July 2007 20:55 Go to previous message
Aha that's tricked it.
Thank you Kaloyan.
"Kaloyan Raev" <kaloyan.raev@sap.com> wrote in message
news:f6d4ei$grf$1@build.eclipse.org...
> You can.
> you want to include.
> 4. Click OK.
> of the web project, then the dependent Java projects will be packed as
> JARs and included in the WEB-INF/lib of the produced WAR file.
>> through WST.
>> from these projects causes a fatal NoClassDefFoundError and the server
>> doesn't start.
>> publish my dynamic web project or is it best that I just deploy these as
>> jars wo WEB-INF/lib with an Ant build before I publish ?
Previous Topic:How to create a new Server for WebSphere 5.1
Next Topic:java.lang.NoSuchMethodError: org.apache.naming.NamingContextBindingsEnumeration. <init>
Current Time: Fri Jul 25 18:10:38 EDT 2025
Powered by FUDForum. Page generated in 0.04143 seconds
