Home » Modeling » GMF (Graphical Modeling Framework) » Exception when generating diagram code from .gmfgen
Exception when generating diagram code from .gmfgen [message #195269] |
Wed, 02 July 2008 05:01  |
I'm using Eclipse Ganymede (Modeling tools version) and working on a
EMF/GMF project.
I follow the GMF process for code generation :
* .ecore
* .genmodel -> generate model (edit, editor)
* .gmfgraph
* .gmftool
* .gmfmap -> generator model
* .gmfgen -> generate diagram code
##### Exception :
Exception occurred while generating code
Ambiguous definitions
xpt::editor::DocumentProvider::fileEditorInputClassFQName FOR
gmfgen::GenDiagram and
aspects::xpt::editor::DocumentProvider::fileEditorInputClass FQName FOR
gmfgen::GenDiagram for param types []
I didn't understand this exception.
I saw a similar problem on this thread :
news://eclipse.modeling.gmf:80/c6f1ac739ee35b4cf43ba2846fe01 51c$1@www.eclipse.org
but the solution seems to be unappropriate for me, I didn't have the
second problem mentioned by him.
Olivier PATRY
Re: Exception when generating diagram code from .gmfgen [message #195395 is a reply to message #195338] |
Wed, 02 July 2008 08:34   |
Alex Shatalin a écrit :
> Hello Olivier,
> Sounds rather strange. Can you try to generate one of the GMF example
> diagrams to make sure GMF itself was installed properly?
> Alex Shatalin
Hi, thanks for answer.
I test the GMF Tutorial, it works (quite) as expected, no error found,
execution ok. (Features seems to not work as expected, maybe a personal
error)
So, the code generation works well on a "from scratch" example.
Notice that my project was created by someone else with an older version
of eclipse(3.3)/emf/gmf(sdk 2.0).
I use the "migrate to GMF 2.1" command on the popup menu on *.gmfgraph
*.gmfmap
I take a look on xpt files but it wasn't clear for me.
Thanks, regards,
Olivier
Re: Exception when generating diagram code from .gmfgen [message #195609 is a reply to message #195568] |
Thu, 03 July 2008 07:33   |
> Hello Olivier,
>> unfortunatly, I got the same exception error with this modification in
>> my xpt file :(
> Can you copy a trace here?
> Is it something related to template resource encoding? It should be
> ISO-8859-1.
> Alex Shatalin
Did you mean a trace of my xpt file?
Here an excerpt of the DocumentProvider.xpt
«DEFINE throwIncorrectInputException FOR gmfgen::GenDiagram-»
throw new org.eclipse.core.runtime.CoreException(new
org.eclipse.core.runtime.Status(org.eclipse.core.runtime.ISt atus.ERROR,
«editorGen.plugin.getActivatorQualifiedClassName()».ID, 0,
org.eclipse.osgi.util.NLS.bind(
«EXPAND
xpt::Externalizer::accessorCall(i18nKeyForDocumentProviderIn correctInputError())
FOR editorGen»,
new Object[] {element, «IF null == editorGen.application»"«EXPAND
fileEditorInputClassFQName»", «ENDIF»"«EXPAND
uriEditorInputClassFQName»"}), «EXPAND xpt::Common::nonNLS(1)»«IF null
== editorGen.application» «EXPAND xpt::Common::nonNLS(2)»«ENDIF»
null));
«ENDDEFINE»
«DEFINE fileEditorInputClassFQName FOR
gmfgen::GenDiagram»org.eclipse.ui.part.FileEditorInput«END DEFINE»
«DEFINE uriEditorInputClassFQName FOR
gmfgen::GenDiagram»org.eclipse.emf.common.ui.URIEditorInput «ENDDEFINE»
How is this problem related with encoding issue? The ISO-8829-1 encoding
is for the xpt files ?
Thanks again for helping
Re: Exception when generating diagram code from .gmfgen [message #195709 is a reply to message #195624] |
Thu, 03 July 2008 11:47   |
> Hello Olivier,
>>>> in my xpt file :(
> I have to read it more carefully. :-) I thought exception was thrown by
> xpand editor.. Sorry.
> If you posted here whole content of
> aspects/xpt/editor/DocumentProvider.xpt (xutom template) I do not see
> the reason for this template at all - it is just copying original
> template contents..
> I suggest you to remove "DEFINE uriEditorInputClassFQName", "DEFINE
> fileEditorInputClassFQName" and call it using fully-qualified names like:
> «EXPAND xpt::editor::DocumentProvider::uriEditorInputClassFQName ....
> Alex Shatalin
I paste here the DocumentProvider.xpt
* Copyright (c) 2007 Borland Software Corporation
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Alexander Shatalin (Borland) - initial API and implementation
«IMPORT "http://www.eclipse.org/gmf/2006/GenModel"»
«EXTENSION xpt::editor::Utils»
«AROUND doSaveDocument FOR gmfgen::GenDiagram-»
«EXPAND xpt::Common::generatedMemberComment»
protected void doSaveDocument(org.eclipse.core.runtime.IProgressMonitor
monitor, Object element,
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .IDocument
document, boolean overwrite) throws org.eclipse.core.runtime.CoreException {
ResourceSetInfo info = getResourceSetInfo(element);
if (info != null) {
if (!overwrite && !info.isSynchronized()) {
«IF null ==
editorGen.application»org.eclipse.core.resources.IResourceS tatus.OUT_OF_SYNC_LOCAL«ELSE»org.eclipse.core.runtime.ISta tus.ERROR«ENDIF»,
«EXPAND
xpt::Externalizer::accessorCall(i18nKeyForDocumentUnsynchron izedFileSaveError())
FOR editorGen»,
null));
«IF null == editorGen.application-»
info.stopResourceListening();
«ENDIF-»
fireElementStateChanging(element);
java.util.List resources = info.getResourceSet().getResources();
try {
monitor.beginTask(«EXPAND
xpt::Externalizer::accessorCall(i18nKeyForDocumentSaveDiagra mTask()) FOR
editorGen», resources.size() + 1 + 1); //"Saving diagram"
monitor.subTask("Validating on save");
org.eclipse.gmf.runtime.notation.Diagram diagram =
(org.eclipse.gmf.runtime.notation.Diagram) document.getContent();
ValidateAction.runValidation(diagram); // delegate validation
monitor.worked(1);
for (java.util.Iterator it = resources.iterator(); it.hasNext();) {
org.eclipse.emf.ecore.resource.Resource nextResource =
(org.eclipse.emf.ecore.resource.Resource) it.next();
monitor.setTaskName(org.eclipse.osgi.util.NLS.bind(
«EXPAND
xpt::Externalizer::accessorCall(i18nKeyForDocumentSaveNextRe sourceTask())
FOR editorGen»,
nextResource.getURI()));
if (nextResource.isLoaded() &&
!info.getEditingDomain().isReadOnly(nextResource)) {
try {
nextResource.save(«EXPAND xpt::Common::getSaveOptions»);
} catch (java.io.IOException e) {
fireElementStateChangeFailed(element);
org.eclipse.gmf.runtime.diagram.ui.resources.editor.internal .EditorStatusCodes.RESOURCE_FAILURE,
e.getLocalizedMessage(), null));
monitor.worked(1);
monitor.done();
info.setModificationStamp(computeModificationStamp(info));
} catch (RuntimeException x) {
throw x;
} «IF null == editorGen.application» finally {
info.startResourceListening();
} «ENDIF»
} else {
org.eclipse.emf.common.util.URI newResoruceURI;
java.util.List affectedFiles = null;
«IF null == editorGen.application»if (element instanceof «EXPAND
fileEditorInputClassFQName») {
org.eclipse.core.resources.IFile newFile = ((«EXPAND
fileEditorInputClassFQName») element).getFile();
affectedFiles = java.util.Collections.singletonList(newFile);
newResoruceURI =
org.eclipse.emf.common.util.URI.createPlatformResourceURI(ne wFile.getFullPath().toString(),
true);
} else «ENDIF»if(element instanceof «EXPAND uriEditorInputClassFQName») {
newResoruceURI = ((«EXPAND uriEditorInputClassFQName») element).getURI();
} else {
«EXPAND throwIncorrectInputException-»
if (false == document instanceof
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .IDiagramDocument)
"Incorrect document used: " + document + " instead of
org.eclipse.gmf.runtime.diagram.ui.resources.editor.document .IDiagramDocument ",
null)); «EXPAND xpt::Common::nonNLS(1)» «EXPAND xpt::Common::nonNLS(2)»
diagramDocument =
(org.eclipse.gmf.runtime.diagram.ui.resources.editor.documen t.IDiagramDocument)
document;
final org.eclipse.emf.ecore.resource.Resource newResource =
diagramDocument.getEditingDomain().getResourceSet().createRe source(newResoruceURI);
final org.eclipse.gmf.runtime.notation.Diagram diagramCopy =
org.eclipse.emf.ecore.util.EcoreUtil.copy(diagramDocument.ge tDiagram());
try {
new
org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand(diagramDocument.getEditingDomain(),
org.eclipse.osgi.util.NLS.bind(«EXPAND
xpt::Externalizer::accessorCall(i18nKeyForDocumentSaveAs()) FOR
editorGen», diagramCopy.getName()), affectedFiles) {
protected org.eclipse.gmf.runtime.common.core.command.CommandResult
doExecuteWithResult(org.eclipse.core.runtime.IProgressMonito r monitor,
org.eclipse.core.runtime.IAdaptable info) throws
org.eclipse.core.commands.ExecutionException {
newResource.getContents().add(diagramCopy);
return
org.eclipse.gmf.runtime.common.core.command.CommandResult.ne wOKCommandResult();
}.execute(monitor, null);
newResource.save(«EXPAND xpt::Common::getSaveOptions»);
} catch (org.eclipse.core.commands.ExecutionException e) {
newResource.unload();
«ENDAROUND»
«EXPAND
FOR editorGen»,
null));
«ENDDEFINE»
If I understood you correctly, this template do nothing at all. It juste
copy things ? I'll try to modify things as you said but I didn't know
the xpt usage.
Goodbye,
Re: Exception when generating diagram code from .gmfgen [message #195773 is a reply to message #195726] |
Fri, 04 July 2008 07:46  |
Hello Olivier,
> Is it a good way to solve this issue?
Well, the "tail" of this template (throwIncorrectInputException, fileEditorInputClassFQName
, uriEditorInputClassFQName) looks not necessary because you are just copying
original template.. Here you can either call original DEFINEs orcreate your
custom one with different parameters... "aspects" folder was designed to
hold "arounds" for the original templates + some custom DEFINEs. If you'd
like to override original DEFINE completely you can put corresponding custom
template in a folder without "aspects" top-level folder...
> What is this code used for?
It is a question to an author of this custom template.. ;-)
Alex Shatalin
Current Time: Sun Jul 27 02:09:41 EDT 2025
Powered by FUDForum. Page generated in 0.28749 seconds
