Content pane will grow but won't shrink [message #194726] |
Mon, 05 September 2005 08:34  |
Greetings,
I have a container edit part whose content pane's size should be always
as specified in the size properties of its model. Therefore, whenever
the edit part's model's size properties change, I'm setting the edit
part's content figure size using setMinimumSize(), setPreferredSize()
and setMaximumSize() (just setting the preferred size isn't enough, but
that's another story). This works fine whenever the model's size grows,
but doesn't work when it shrinks.
The edit part's figure looks as follows:
| title |
| layeredPane |
The title and layered pane are laid out using a ToolbarLayout. The
layeredPane contains three layers, one of which is the content pane. The
contentPane is the only figure with children, and it's using an XYLayout.
Why won't the edit part's figure shrink? How do I fix this?
Thank you very much in advance,
Martijn.
Re: Content pane will grow but won't shrink [message #194831 is a reply to message #194726] |
Tue, 06 September 2005 10:08   |
Originally posted by: none.unknown.com
Perhaps the other layers in the layered pane are returning preferred sizes
bigger than the content pane because they were previously sized to be that
big when the content pane reported that size.
"Martijn van Steenbergen" <mvsteenbergen@eljakim.nl> wrote in message
news:dfhe1k$je3$1@news.eclipse.org...
> Greetings,
> | title |
> | layeredPane |
> Martijn.
Re: Content pane will grow but won't shrink [message #195225 is a reply to message #194904] |
Thu, 08 September 2005 13:13  |
"Martijn van Steenbergen" <mvsteenbergen@eljakim.scratch-this.nl> wrote in
message news:dfkdi9$d1p$1@news.eclipse.org...
> Was this a bug in my code or in GEF's code?
In your code.
> It seems to be related to the fact that the layer doesn't have a layout
> manager. In that case Figure.getPreferredSize() returns getSize(). Why
> doesn't it return a (0, 0) dimension?
Since a figure's intial size is 0,0, it would have returned that; however,
since it had been resized it's returning that size as its preferred one
(which is a useful default). If you were to set the size of a
RectangleFigure to be 100x100, you'd want it to maintain that size. The
proper thing is to set the layer's preferred size or give it the capability
to calculate its actual preferred size (by setting a layout manager).
> Regards,
> Martijn.
> Martijn van Steenbergen wrote:
> > You are right. I solved it by calling setPreferredSize(0, 0) on the
> > layer at creation, and now it's working fine. Thank you so much. :)
FUDForum. Page generated in 0.07356 seconds
