Home » Language IDEs » Java Development Tools (JDT) » Different output folders for different source folders
Different output folders for different source folders [message #194628] Mon, 31 January 2005 09:53 Go to next message
Originally posted by: marcus.tangermann.web.de
in my plug-in I have different source folders depending
on special ids of devices. E.g. code for deviceUno is under
src/deviceUno and the code for device due is under src/due
These folders are added as source classpath entries to the
raw classpath of the java project.
The problem is that i don't know how to set a different output
path for each source folder (e.g. bin/deviceUno and bin/deviceDue).
Is this possible with the JDT by a plug-in?
Bye
Marcus
Re: Different output folders for different source folders [message #194637 is a reply to message #194628] Mon, 31 January 2005 09:55 Go to previous messageGo to next message
Yes it is possible. Do you need it to it through code or through the UI?
If through code, you create a classpath entry like:
<classpathentry
output="bin_beaninfocommon"
kind="src"
path="beaninfoCommon"/>
This says for the source folder beaninfoCommmon, that the output is in
the bin_beanininfocommon folder.
To create such an entry use
JavaCore.newSourceEntry(IPath path, IPath[] exclusionPatterns, IPath
specificOutputLocation)
Rich Kulp
Re: Different output folders for different source folders [message #194644 is a reply to message #194628] Mon, 31 January 2005 09:56 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Marcus Tangermann wrote:
>Hi,
Open the project properties and select "Java Build Path". Click "Source"
and then check the "Allow output folders for source folders." check box.
Dani
>Bye
>Marcus
Re: Different output folders for different source folders [message #194652 is a reply to message #194637] Mon, 31 January 2005 10:23 Go to previous message
thank you, the functionality of setting output folders
for source folder in newSourceEntry was the one I was
looking for. Looks like it works now :-)
Bye
Marcus
P.S.: Your answer was realy fast :-)
> <classpathentry
> kind="src"
Previous Topic:General/Ant gripes and groans
Next Topic:Log error for Struts tag libraries
Current Time: Fri Sep 19 07:45:25 EDT 2025
Powered by FUDForum. Page generated in 0.08785 seconds
