selectionProvider in MultiPageEditor [message #194394] |
Thu, 01 September 2005 13:07  |
Originally posted by: gef.oppacher.ca
I was having problems with the MultiPageEditorPart and the Gef editors
that I embedded into the MultiPageEditorPart, specifically getting
selection changes. To fix this whenever I
MulitPageEditorPart#setActivePage() is called I set the selection provider
of the MultiPageEditor to be the GraphicalViewer of the newly selected
EditorPart. This all seems to work fine. So I was wondering if I'm
causing, or will cause problems by setting the selectionProvider? The
selectionProvider seems to be null before I set it and runs fine
afterwards. Any comments would be great.
Yandu
Re: selectionProvider in MultiPageEditor [message #194624 is a reply to message #194601] |
Fri, 02 September 2005 08:12  |
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
There already is a org.eclipse.ui.part.MultiPageSelectionProvider which
does this for you. If your multi-page editor extends MultiPageEditorPart
and you call the appropriate methods when adding new GraphicalEditors,
your problem should automagically be taken care of.
M.
zhaojiangbin wrote:
> i think you'd better to install a MultiPageSelectionProvider for a
> MultiPageEditorPart in init() method.
> consule the sample code bellow:
> site.setSelectionProvider(new EditorMultiPageSelectionProvider(this));
> and calss definition is:
> EditorMultiPage is the MultiPageEditorPart name in my application
> private static class EditorMultiPageSelectionProvider extends
> MultiPageSelectionProvider {
> private ISelection globalSelection;
> * @param multiPageEditor
> public EditorMultiPageSelectionProvider(EditorMultiPage editorMultiPage)
> super(editorMultiPage);
> public ISelection getSelection() {
> IEditorPart activeEditor = ((EditorMultiPage) getMultiPageEditor())
> .getActiveEditor();
> if (activeEditor != null) {
> ISelectionProvider selectionProvider = activeEditor.getSite()
> .getSelectionProvider();
> if (selectionProvider != null)
> return selectionProvider.getSelection();
> return globalSelection;
> * (non-Javadoc) Method declared on <code> ISelectionProvider </code> .
> public void setSelection(ISelection selection) {
> .getActiveEditor();
> selectionProvider.setSelection(selection);
> } else {
> this.globalSelection = selection;
> fireSelectionChanged(new SelectionChangedEvent(this,
> globalSelection));
> "Yandu" <gef@oppacher.ca> дÈëÏûÏ¢ÐÂÎÅ:d434fd29286e7e94745b887a5148ef04$1@www.eclipse.org...
>>Hi,
>>Yandu
FUDForum. Page generated in 0.04120 seconds
