Home » Language IDEs » C / C++ IDE (CDT) » get my current project object.
get my current project object. [message #193450] Mon, 18 June 2007 06:03 Go to next message
Originally posted by: oren_b1.verifone.com
How can I get the project object of the currently opened project on eclipse?
Oren.
Re: get my current project object. [message #193505 is a reply to message #193450] Mon, 18 June 2007 23:57 Go to previous messageGo to next message
Originally posted by: nzhong.amazon.com
I am not sure of a generic way. When I need to get hold of the project
object when developing a plug-in, the extension points's interface method
passes an ICProject parameter to me.
"oren barzilai" <oren_b1@verifone.com> wrote in message
news:f55l9b$ne8$1@build.eclipse.org...
> Hello,
> eclipse?
> Thanks
> Oren.
Re: get my current project object. [message #193535 is a reply to message #193505] Tue, 19 June 2007 04:29 Go to previous messageGo to next message
I can get hold on my project obj during creation process, But after I
restart the eclipse I can't find a way to get hold on my project object
again.
Let's say that currently there is 2 open projects on my workspace, I need a
method like "getCurrentlyActiveProject()" I can't think of any other way
because I don't know on which project the user is currently working on, I
don't even know the project's name.
Any idea? anyone?
"Nan Zhong" <nzhong@amazon.com> wrote in message
news:f57k7t$if4$1@build.eclipse.org...
>> Hello,
>> eclipse?
>> Thanks
>> Oren.
Re: get my current project object. [message #193569 is a reply to message #193535] Tue, 19 June 2007 14:32 Go to previous messageGo to next message
> again.
> Any idea? anyone?
You can get the currently selected one, but that will only tell you when
one is actually selected. It's possible to be logically working in a
project (e.g. editing a file) without actually having the project
selected in the project explorer. Without knowing what you are doing I
can't comment as to whether this heuristic (selection) works for your
situation or not, or if there is more to your workflow.
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: get my current project object. [message #193800 is a reply to message #193569] Fri, 22 June 2007 04:01 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
You can get the currently selected IResource, and from that you can get the project:
private IContainer getProject(IResource resource) {
IContainer container = null;
if (resource != null) {
int type = resource.getType();
switch (type) {
case IResource.FILE :
container = resource.getParent();
break;
case IResource.FOLDER :
container = resource.getProject();
break;
case IResource.PROJECT :
container = (IContainer) resource;
break;
case IResource.ROOT :
break;
return container;
Derek
>> object again.
>> need a method like "getCurrentlyActiveProject()" I can't think of any
>> other way because I don't know on which project the user is currently
>> working on, I don't even know the project's name.
>> Any idea? anyone?
> Chris Recoskie
> IBM Toronto
Re: get my current project object. [message #193913 is a reply to message #193800] Mon, 25 June 2007 10:00 Go to previous messageGo to next message
But how do I get the currently selected resource?
"Derek Morris" <dmsubs@NOSPAM.consertum.com> wrote in message
news:f5fvkf$tdq$1@build.eclipse.org...
> the project:
> switch (type) {
> break;
> break;
> break;
> break;
> return container;
> Derek
>>> again.
>>> Any idea? anyone?
>> Chris Recoskie
>> IBM Toronto
Re: get my current project object. [message #193943 is a reply to message #193913] Mon, 25 June 2007 11:58 Go to previous messageGo to next message
Here is some code that should help you get on your way...
public static final String S_C_PROJECTS_VIEW = "org.eclipse.cdt.ui.CView";
IStructuredSelection ssel = null;
IWorkbenchWindow activeWindow = PlatformUI.getWorkbench()
.getActiveWorkbenchWindow();
if (activeWindow != null) {
ISelection sel = activeWindow.getSelectionService()
.getSelection(S_C_PROJECTS_VIEW);
if (sel instanceof IStructuredSelection) {
ssel = (IStructuredSelection) sel;
IResource resource = null;
Object obj = ssel.getFirstElement();
if (obj instanceof IResource)
resource = (IResource) obj;
else if (obj instanceof IBinaryContainer) {
IBinaryContainer bincon = (IBinaryContainer) obj;
resource = bincon.getUnderlyingResource();
} else if (obj instanceof IAdaptable) {
IAdaptable adaptable = (IAdaptable) obj;
resource = (IResource) adaptable.getAdapter(IResource.class);
Derek
>> the project:
>> switch (type) {
>> break;
>> break;
>> break;
>> break;
>> return container;
>> Derek
>>>> again.
>>>> Any idea? anyone?
>>> Chris Recoskie
>>> IBM Toronto
Re: get my current project object. [message #193967 is a reply to message #193943] Mon, 25 June 2007 13:25 Go to previous message
Thanks.
news:f5oonr$nrq$1@build.eclipse.org...
> Derek
>>> the project:
>>> switch (type) {
>>> break;
>>> break;
>>> break;
>>> break;
>>> return container;
>>> Derek
>>>>> object again.
>>>>> Any idea? anyone?
>>>> when one is actually selected. It's possible to be logically working
>>>> in a project (e.g. editing a file) without actually having the project
>>>> Chris Recoskie
>>>> IBM Toronto
Previous Topic:Dependency calculation using gcc 2.95.3
Next Topic:Lock editor
Current Time: Fri Nov 07 22:54:32 EST 2025
Powered by FUDForum. Page generated in 0.04781 seconds
