Home » Modeling » GMF (Graphical Modeling Framework) » Question about property sheet
Question about property sheet [message #193206] Wed, 18 June 2008 04:20 Go to next message
Hello everybody,
I have two questions about property sheet:
1. Can I use another editor (a plug-in or my own editor) instead of the
editor which is given by GMF when I set Multi-line = true? Generally, can
I customize a property field (of any type not only string type) to call to
an plug-in to set its value? If yes, how can I do that?
2. How can I filter the element list appearing in the dialog of
multi-valued attribute. For example I have 3 classes A, B, C following:
_____________ __________ _________
|Class A |attrsB |Class B | |Class C |
| | 0..*| | | |
|____________| |_________| |________|
Class A has a relation association with class B, and Class C inherits from
class B. How can I restrict the list in the dialog multi-valued attribute
setting the value attrsB of class A to show only instances of the class B
and not those of the class C?
Thanks in advanced!
Toan.
Re: Question about property sheet [message #193255 is a reply to message #193206] Wed, 18 June 2008 06:31 Go to previous messageGo to next message
--------------020105040902060506030509
Toan,
Have a look at
3.1 Recipe: Create your own property editor in a generated
application
< http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application>
Here's an example from ETypedElementItemProvider where we filter the choices
protected void addETypePropertyDescriptor(Object object)
itemPropertyDescriptors.add
(new ItemPropertyDescriptorWithUniqueChoiceOfValueLabels
(((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(),
getResourceLocator(),
getString("_UI_ETypedElement_eType_feature"),
getString("_UI_ETypedElement_eType_description"),
EcorePackage.Literals.ETYPED_ELEMENT__ETYPE,
true,
false,
true,
null,
null,
null)
public Collection<?> getChoiceOfValues(Object object)
Toan wrote:
> Hello everybody,
> the editor which is given by GMF when I set Multi-line = true?
> Generally, can I customize a property field (of any type not only
> string type) to call to an plug-in to set its value? If yes, how can I
> do that?
> | | 0..*| | | |
> from class B. How can I restrict the list in the dialog multi-valued
> attribute setting the value attrsB of class A to show only instances
> of the class B and not those of the class C?
> Thanks in advanced!
> Toan.
<html>
<head>
http-equiv="Content-Type">
</head>
Toan,<br>
<br>
Have a look at<br>
<blockquote><a
href=" http://wiki.eclipse.org/EMF/Recipes#Recipe:_Create_your_own_ property_editor_in_a_generated_application"><span
class="tocnumber">3.1</span> <span class="toctext">Recipe: Create
your own property editor in a generated application</span></a><br>
</blockquote>
choices<br>
<blockquote><small>
Re: Question about property sheet [message #193435 is a reply to message #193255] Thu, 19 June 2008 04:04 Go to previous messageGo to next message
Thanks Ed Merks,
I can now filter the choices but I haven't succeeded to create my own
property editor. I follow exactly the guide in 3.1 Recipe and also in the
blog but I don't know why that doesn't work. Can you help me, please?
Thanks in advanced!
Toan.
Re: Question about property sheet [message #193475 is a reply to message #193435] Thu, 19 June 2008 04:45 Go to previous messageGo to next message
I test with EMF, it works! Do I have to do other configurations in order
to make it work in GMF and what are those configurations? Thanks!
Toan.
Re: Question about property sheet [message #193680 is a reply to message #193475] Thu, 19 June 2008 08:34 Go to previous messageGo to next message
Toan,
I would have thought it would work for both, but if not, I don't know
why not... Sorry...
> order to make it work in GMF and what are those configurations? Thanks!
> Toan.
Re: Question about property sheet [message #193885 is a reply to message #193680] Fri, 20 June 2008 05:16 Go to previous messageGo to next message
Hi Ed Merks,
Now I know where to modify to make it work. That's in the methode
public IPropertySource getPropertySource(Object object) {}
of file xxxPropertySection.java in the package xxx.diagram.sheet in which
xxx is name of my project. The methode look like this:
if (object instanceof IPropertySource) {
return (IPropertySource) object;
AdapterFactory af = getAdapterFactory(object);
if (af != null) {
IItemPropertySource ips = (IItemPropertySource) af.adapt(object,
IItemPropertySource.class);
if (ips != null) {
return new PropertySource(object, ips)
protected IPropertyDescriptor
createPropertyDescriptor(IItemPropertyDescriptor itemPropertyDescriptor)
return
new PropertyDescriptor(object, itemPropertyDescriptor)
public CellEditor createPropertyEditor(Composite composite)
// Test for your case based on the feature or the type of the
feature.
// See the super method for details.
Object feature = temPropertyDescriptor.getFeature(this.object);
return super.createPropertyEditor(composite);
if (object instanceof IAdaptable) {
return (IPropertySource) ((IAdaptable) object)
.getAdapter(IPropertySource.class);
return null;
I have a question: Does the plug-in must depend on the packages graphic of
eclipse or not? Can I use any existing widget in Java which is not based
on eclipse packages graphic or not? If yes, how can I call the widget from
this method? Thanks in advance!
Toan.
Re: Question about property sheet [message #193916 is a reply to message #193885] Fri, 20 June 2008 08:18 Go to previous message
Toan,
Comments below.
Toan wrote:
> Hi Ed Merks,
> which xxx is name of my project. The methode look like this:
> if (af != null) {
> if (ips != null) {
In AdapterFactoryContent provider this call is factored into a separate
method so that it's possible to override the creation without
duplicating the rest of the logic. I think it would be reasonable to
open a bugzilla enhancement request to factor out the "new
PropertySource" into a separate method. Looking closely at the
generated code, it makes me wonder why this method is even generated.
There's nothing specific to the model here and it could just as easily
be moved up to the base class (I think).
> @Override
> return new
> @Override
> public CellEditor
> the type of the feature.
> Object feature =
> return null;
Thanks for sharing the solution. Would you consider updating the wiki
recipe with an additional "in GMF you have to do it like this" section?
> graphic of eclipse or not?
Well, the argument is Composite so you have to create something that has
that composite as the parent.
> Can I use any existing widget in Java which is not based on eclipse
Not sure, but it does need to be parented by Composite since that's
where the result will be "hosted".
> If yes, how can I call the widget from this method? Thanks in advance!
> Toan.
Previous Topic:Re: Border Item Rectilinear router
Next Topic:UML diagram change tracking
Current Time: Sat Nov 08 16:29:29 EST 2025
Powered by FUDForum. Page generated in 0.05335 seconds
