Home » Language IDEs » ServerTools (WTP) » Using exported jars from j2ee module dependency
Using exported jars from j2ee module dependency [message #193463] Tue, 29 May 2007 08:57 Go to next message
Originally posted by: pakulat.rostock.zgdv.de
I've setup a simple java project (TagLib) for some .jar files that
should be shared among several dynamic web projects. I selected all
those jars for export in the project properties and building the dynamic
web projects which list TagLib as J2EE Module Dependecy works fine (they
use classes from the exported jars). However starting tomcat with these
Web Projects doesn't work, I get a NoClassDefFound exception as it can't
find any of the classes from the jars that are exported in TagLib.
If I look into the
..metadata/.plugins/org.eclipse.wst.server.core/tmp3/webapps /WebModule/WEB-INF/lib/TagLib.jar
file I know why: None of the .jar's are put into TagLib.jar and thus
they can't be found by the jre that starts tomcat.
Is there a way to solve this so that I don't have to add the jars to
each web project individually?
Andreas
Re: Using exported jars from j2ee module dependency [message #193479 is a reply to message #193463] Tue, 29 May 2007 09:16 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Andreas,
Which version of WTP are you using? This should work on version 2.0, but
will not work on earlier releases.
- Konstantin
Re: Using exported jars from j2ee module dependency [message #193487 is a reply to message #193463] Tue, 29 May 2007 10:00 Go to previous messageGo to next message
Assuming I'm interpreting your use case correctly (WEB-INF/lib dependency on
a utility project that exports a set of library JARs), you need to ensure
that the "publish/export" classpath entry attribute has been set for each of
these JAR library cp entries (this will ensure that these JARs are packaged
with the published/exported web module).
You can do this via the "quick fix" on the warning that is generated for
each regarding the potential for runtime class resolution issues (using the
quick fix is necessary since the "J2EE Module Dependencies" UI is not
supported for utility projects referenced only by a dynamic web project: see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184094 for more information)
-Rob
"Andreas Pakulat" <pakulat@rostock.zgdv.de> wrote in message
news:f3h80u$vm3$1@build.eclipse.org...
> I've setup a simple java project (TagLib) for some .jar files that should
> be shared among several dynamic web projects. I selected all those jars
> for export in the project properties and building the dynamic web projects
> which list TagLib as J2EE Module Dependecy works fine (they use classes
> from the exported jars). However starting tomcat with these Web Projects
> doesn't work, I get a NoClassDefFound exception as it can't find any of
> If I look into the
> .metadata/.plugins/org.eclipse.wst.server.core/tmp3/webapps/ WebModule/WEB-INF/lib/TagLib.jar
> file I know why: None of the .jar's are put into TagLib.jar and thus they
> Is there a way to solve this so that I don't have to add the jars to each
> Andreas
Re: Using exported jars from j2ee module dependency [message #193494 is a reply to message #193479] Tue, 29 May 2007 10:54 Go to previous messageGo to next message
Konstantin Komissarchik wrote:
> Andreas,
I'm using 1.5.4 currently. I'll see if I can do an update to 2.0 tomorrow.
Andreas
Re: Using exported jars from j2ee module dependency [message #193510 is a reply to message #193487] Tue, 29 May 2007 11:08 Go to previous messageGo to next message
note: the functionality I outlined below requires 2.0 M6 or later
"Rob Frost" <rfrost@bea.com> wrote in message
news:f3hbm2$avs$1@build.eclipse.org...
> on a utility project that exports a set of library JARs), you need to
> ensure that the "publish/export" classpath entry attribute has been set
> for each of these JAR library cp entries (this will ensure that these JARs
> are packaged with the published/exported web module).
> the quick fix is necessary since the "J2EE Module Dependencies" UI is not
> see https://bugs.eclipse.org/bugs/show_bug.cgi?id=184094 for more
> information)
> -Rob
>> Hi,
>> projects which list TagLib as J2EE Module Dependecy works fine (they use
>> classes from the exported jars). However starting tomcat with these Web
>> Projects doesn't work, I get a NoClassDefFound exception as it can't find
>> If I look into the
>> Andreas
Re: Using exported jars from j2ee module dependency [message #193588 is a reply to message #193494] Wed, 30 May 2007 04:37 Go to previous messageGo to next message
>> Andreas,
Too bad, that needs eclipse 3.3 apparently which I can't use yet...
Re: Using exported jars from j2ee module dependency [message #194684 is a reply to message #193487] Tue, 19 June 2007 10:03 Go to previous messageGo to next message
Installed Eclipse 3.3 rc and Webtools rc as well. But I don't see any
warnings that could help here. Let me explain again:
I have project TagLib, which has a few classes (which are properly
exported) and a few jars in it. The jars contain base classes for the
classes in this project. And to ease the use of this TagLib project in
various web applications its a utility module. Now as I said the .jars
inside this utility project are not exported even though I selected them
for importing, this of course creates a problem when using the module in
a webapp.
So what exact warning should I see or what else do I have to do to
resolve this?
Andreas
Re: Using exported jars from j2ee module dependency [message #195145 is a reply to message #194684] Thu, 28 June 2007 17:09 Go to previous message
news:f58nov$34o$1@build.eclipse.org...
>> JARs are packaged with the published/exported web module).
>> information)
> for importing, this of course creates a problem when using the module in a
> webapp.
> So what exact warning should I see or what else do I have to do to resolve
> this?
The warning you should see is of the following form:
Classpath entry X will not be exported or published. Runtime
ClassNotFoundExceptions may result.
Note: this warning problem marker is only going to be generated if your
project is a "Utility" project rather than a plain Java project (and the
"Classpath Dependency Validator" is therefore enabled; you can check
Project->Properties->Validation to verify this)
-Rob
> Andreas
Previous Topic:mime:multipartRelated not properly serialized?
Next Topic:schema resolver
Current Time: Sat Jul 26 11:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.06849 seconds
