Eclipse 3.3.0 M5 web.xml namespace issue with Tomcat 6 [message #193227] |
Sat, 26 May 2007 18:10  |
Originally posted by: mikevoxcap.hotmail.com
If I perform an action with a dynamic web project in eclipse that results in
a deployment descriptor change, such as adding a servlet, eclipse will
convert my web.xml to use a namespace as shown below. When the project is
deployed to Tomcat 6, the servlet resource is not recognized. If I manually
change the web.xml back to not use the web namespace, the servlet is
recognized. Might be a dumb question, but is there a way to make Tomcat 6
namespace aware OR change eclipse to not convert my web.xml to use a
namespace?
-- before --
<servlet>
<description></description>
<display-name>TestServ</display-name>
<web:servlet-name>TestServ</web:servlet-name>
<web:servlet-class>com.llamabuy.servlet.TestServ</web:servlet-class >
</servlet>
-- after --
<web:servlet>
</web:servlet>
Thanks!
Michael Hoffman
mikevoxcap@hotmail.com
Re: Eclipse 3.3.0 M5 web.xml namespace issue with Tomcat 6 [message #193364 is a reply to message #193227] |
Mon, 28 May 2007 12:11   |
As a follow-up to the post below, this is the error I get when I try to
publish the web app to Tomcat 6 and run a basic servlet. It seems this is
related to project facets, but I cannot see why this does not work out of
the box. Please help!
May 28, 2007 11:07:29 AM org.apache.catalina.core.StandardContext
listenerStart
SEVERE: Error configuring application listener of class
|CONFIG_LISTEN_CLASS|
java.lang.ClassNotFoundException: |CONFIG_LISTEN_CLASS|
at
org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1358)
at
org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1204)
at
org.apache.catalina.core.StandardContext.listenerStart(Stand ardContext.java:3770)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4334)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:719)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:516)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:566 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
listenerStart
SEVERE: Skipped installing application listeners due to previous error(s)
May 28, 2007 11:07:29 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/LlamaBestBuy] startup failed due to previous errors
"Mike Hoffman" <mikevoxcap@hotmail.com> wrote in message
news:f3ab91$875$1@build.eclipse.org...
> in a deployment descriptor change, such as adding a servlet, eclipse will
> manually change the web.xml back to not use the web namespace, the servlet
> is recognized. Might be a dumb question, but is there a way to make Tomcat
> 6 namespace aware OR change eclipse to not convert my web.xml to use a
> namespace?
> -- before --
> <servlet>
> </servlet>
> -- after --
> <web:servlet>
> </web:servlet>
> Thanks!
> Michael Hoffman
Re: Eclipse 3.3.0 M5 web.xml namespace issue with Tomcat 6 [message #193380 is a reply to message #193364] |
Mon, 28 May 2007 16:12  |
Re-installed and it fixed the problem.
news:f3euv4$9vu$1@build.eclipse.org...
> listenerStart
> at
> at
> at
> at
> at
> listenerStart
>> servlet is recognized. Might be a dumb question, but is there a way to
>> make Tomcat 6 namespace aware OR change eclipse to not convert my web.xml
>> to use a namespace?
>> -- before --
>> <servlet>
>> </servlet>
>> -- after --
>> <web:servlet>
>> </web:servlet>
>> Thanks!
>> Michael Hoffman
FUDForum. Page generated in 0.04406 seconds
