Home » Modeling » GMF (Graphical Modeling Framework) » How to change edit part size
How to change edit part size [message #192820] |
Mon, 16 June 2008 07:15  |
Hello All,
I have a "BorderedBorderItemEditPart" extended class rectangle editpart. I
want to change the size of the same using coding. I have tried this using
different methods like
Method1:
ChangeBoundsRequest resizeRequest = new ChangeBoundsRequest(
org.eclipse.gef.RequestConstants.REQ_RESIZE);
resizeRequest.setEditParts(iGeditPart);
resizeRequest.setSizeDelta(new Dimension(widthDelta,heightDelta));
Command cmd = editPart.getCommand(resizeRequest);
cc.add(cmd);
Method2:
((BorderedNodeFigure)iGeditPart.getFigure()).setPreferredSiz e(new
Method3:
((BorderedNodeFigure)iGeditPart.getFigure()).setSize(new
But it is not changing size of it. Please help me how change size of
component programatically?.
Re: How to change edit part size [message #193006 is a reply to message #192985] |
Tue, 17 June 2008 03:31   |
Originally posted by: luetze.cs.tu-berlin.de
well, just add 2 memebers (including setters) to the figure-class:
int size_x;
int size_y;
public void setMySize(int x, int y){
size_x = x;
size_y = y;
use your action to set your "new" size:
figure.setMySize(100,100);
....and finally, you include the call of
setPreferredSize(size_x,size_y);
within your overwritten paintFigure(Graphics g)-method!
hope that will work out for you!
Take care, Marco
Nagesh schrieb:
> Hello luetze,
> Thank you for reply. I have overrided the paintFigure(Graphics) method.
> This has been changed the size of the component on initial run. But from
> other class how to call this paint method or change the size?.
> I want this change in size of component by an action. How can I do it
> programatically?. Please help me.
> Thanks In Advance,
> Nagesh
> luetze wrote:
>> Hi Nagesh.
>> Overwrite the paintFigure(Graphics g) method of
>> the figure class you are using! just add
>> this.setPreferredSize(x,y) there and you will be fine!
>> Marco
>> Nagesh schrieb:
>>> Hello All,
>>> editpart. I want to change the size of the same using coding. I have
>>> tried this using different methods like
>>> Method1:
>>> Command cmd =
>>> cc.add(cmd);
>>> Method2:
>>> Method3:
Re: How to change edit part size [message #193050 is a reply to message #193006] |
Tue, 17 June 2008 08:14   |
Hi Marco,
Thanks for solution. From my action class now I am setting sizes and
calling paintFigure(Graphics g). But how can I get graphics object for
parameter?.
Nagesh.
> int size_x;
> int size_y;
> size_x = x;
> size_y = y;
> Take care, Marco
> Nagesh schrieb:
>> Hello luetze,
>> Thanks In Advance,
>> Nagesh
>> luetze wrote:
>>> Hi Nagesh.
>>> Marco
>>> Nagesh schrieb:
>>>> Hello All,
>>>> Method1:
>>>> Command cmd =
>>>> cc.add(cmd);
>>>> Method2:
>>>> Method3:
Re: How to change edit part size [message #193113 is a reply to message #193050] |
Tue, 17 June 2008 12:57   |
that's the beauty if it :-) ...you don't need that anymore! you do not
need to call paintFigure()! ...just call YOURFIGURE.repaint()
and paintFigure(Graphics g) is called automatically!
tell me if you made it!
Cheers, Marco
Nagesh schrieb:
> Hi Marco,
> parameter?.
> Nagesh.
>> int size_x;
>> int size_y;
>> size_x = x;
>> size_y = y;
>> Take care, Marco
>> Nagesh schrieb:
>>> Hello luetze,
>>> method. This has been changed the size of the component on initial
>>> run. But from other class how to call this paint method or change the
>>> size?.
>>> Thanks In Advance,
>>> Nagesh
>>> luetze wrote:
>>>> Hi Nagesh.
>>>> Marco
>>>> Nagesh schrieb:
>>>>> Hello All,
>>>>> have tried this using different methods like
>>>>> Method1:
>>>>> Command cmd
>>>>> cc.add(cmd);
>>>>> Method2:
>>>>> Method3:
>>>>> of component programatically?.
Re: How to change edit part size [message #193169 is a reply to message #193113] |
Wed, 18 June 2008 01:50   |
Hi Marco,
Great!!! it works. Thanks alot.
This size change not makes figure as dirty ie changes can't be saved. How
can I make this option on size change?.
Nagesh.
> Cheers, Marco
> Nagesh schrieb:
>> Hi Marco,
>> parameter?.
>> Nagesh.
>>> int size_x;
>>> int size_y;
>>> size_x = x;
>>> size_y = y;
>>> Take care, Marco
>>> Nagesh schrieb:
>>>> Hello luetze,
>>>> size?.
>>>> Thanks In Advance,
>>>> Nagesh
>>>> luetze wrote:
>>>>> Hi Nagesh.
>>>>> Marco
>>>>> Nagesh schrieb:
>>>>>> Hello All,
>>>>>> Method1:
>>>>>> Command cmd
>>>>>> cc.add(cmd);
>>>>>> Method2:
>>>>>> Method3:
Re: How to change edit part size [message #193704 is a reply to message #193169] |
Thu, 19 June 2008 09:58  |
Huh, difficult one! ...due to the fact, that you are saving
these things, you need to update your model with a size-attribute,
because otherwise reloaded diagramms will have initial values for size!
in the case of a model representation you just perform an update
model-action and the model is dirty again! have you thought about
that possibility (saving size to the model-file) ?
Nagesh schrieb:
> Hi Marco,
> Great!!! it works. Thanks alot. This size change not makes figure as
> dirty ie changes can't be saved. How can I make this option on size
> change?.
> Nagesh.
>> Cheers, Marco
>> Nagesh schrieb:
>>> Hi Marco,
>>> for parameter?.
>>> Nagesh.
>>>> int size_x;
>>>> int size_y;
>>>> size_x = x;
>>>> size_y = y;
>>>> Take care, Marco
>>>> Nagesh schrieb:
>>>>> Hello luetze,
>>>>> the size?.
>>>>> it programatically?. Please help me.
>>>>> Thanks In Advance,
>>>>> Nagesh
>>>>> luetze wrote:
>>>>>> Hi Nagesh.
>>>>>> Marco
>>>>>> Nagesh schrieb:
>>>>>>> Hello All,
>>>>>>> Method1:
>>>>>>> Command
>>>>>>> cc.add(cmd);
>>>>>>> Method2:
>>>>>>> Method3:
Current Time: Fri Jul 18 15:51:19 EDT 2025
Powered by FUDForum. Page generated in 0.09481 seconds
