| request and Action [message #192633] |
Sat, 20 August 2005 17:25   |
Eclipse User  |
Originally posted by: tankun.web.de
hi all,
i have a problem about the relation between request(editpolicy) and Action.
is there a essential relation between the request(editpolicy) and Action?
because i see all the Actions(for examlpe in logic) get the their command
via editpart(request).
can actions directly initial their command and then excucte()?
because i have done some experiment about this,but there is a streng
problem:
i excute a action via contextmenu,but the correlative command will not be
excuted.at first i think the command is not in the commandstack.but then i
find,wenn i click "undo",the undo() in the command will be excuted,and the
redo() too.
can u give me a tipp,where i mistake made.
thanks
| Re: request and Action [message #192641 is a reply to message #192633] |
Sun, 21 August 2005 12:14    |
Eclipse User  |
tan kun schrieb am 20.08.2005 23:25:
> hi all,
> command via editpart(request).
A request is given to an Editpart which ask all his edipolicies, if one does understand it. If an editpolicy understands a request it will
create a command for it.
yes. at least the logic example handles it that way. If you implement you action, you can get the command for example like this:
private Command getCommand() {
	List editparts = getSelectedObjects();
	CompoundCommand cc = new CompoundCommand();
	cc.setDebugLabel("Increment/Decrement LEDs");//$NON-NLS-1$
	for (int i=0; i < editparts.size(); i++) {
		EditPart part = (EditPart)editparts.get(i);
		cc.add(part.getCommand(request));
	return cc;
you execute the command within the run()-method of the action:
public void run() {
	execute(getCommand());
This is taken from IncrementDecrementAction which extends org.eclipse.gef.ui.actions.SelectionAction and it works for me ;-)
> problem:
> be excuted.at first i think the command is not in the commandstack.but
> then i find,wenn i click "undo",the undo() in the command will be
> excuted,and the redo() too.
set a breakpoint in the execute()-method of your command or even in the corresponding getCommand()-method of your editpolicy and see, if all
informations a correctly set.
FUDForum. Page generated in 0.06459 seconds
