Home » Eclipse Projects » GEF » Figure.setBackgroundColor() and GEF 3.1
Figure.setBackgroundColor() and GEF 3.1 [message #192233] Wed, 17 August 2005 08:14 Go to next message
I used org.eclipse.draw2d.Figure.setBackgroundColor() with no problem in GEF
3.0, but when using the new GEF 3.1 all my figures get a transparent
background.
Even I tried Figure.setOpaque(true);
Any one knows if anything have changed between 3.0 and 3.1 to explain this
behaviour, or is it a bug? Perhaps I missing something and it is my fault...
Any help would be greatly appreciated.
Jose M Beleta
Re: Figure.setBackgroundColor() and GEF 3.1 [message #192283 is a reply to message #192233] Wed, 17 August 2005 16:14 Go to previous messageGo to next message
In 3.1, figures have no size when created (0,0) instead of (64,32) in 3.0.
"Jose M Beleta" <beleta@attglobal.net> wrote in message
news:ddv9pv$se6$1@news.eclipse.org...
>GEF 3.0, but when using the new GEF 3.1 all my figures get a transparent
>background.
> this behaviour, or is it a bug? Perhaps I missing something and it is my
> fault...
> Jose M Beleta
Re: Figure.setBackgroundColor() and GEF 3.1 [message #192321 is a reply to message #192283] Wed, 17 August 2005 18:33 Go to previous messageGo to next message
Randy,
Thank you for your reply, but...
Do you think that this explain the behaviour I have seen.
Do you mean that I have to resize the figure before changing colors, and if
I resize the figure again I will have to call setBackgroundColor another
time. Is that correct?
Jose M Beleta
"Randy Hudson" <none@us.ibm.com> escribi
Re: Figure.setBackgroundColor() and GEF 3.1 [message #192418 is a reply to message #192321] Thu, 18 August 2005 13:45 Go to previous messageGo to next message
news:de0e05$cck$1@news.eclipse.org...
> Randy,
>> 3.0.
It's the only thing I thought of. It could only explain the behavior if you
_never_ set the size of your figures.
Please post a snippet showing the problem.
Re: Figure.setBackgroundColor() and GEF 3.1 [message #192520 is a reply to message #192418] Fri, 19 August 2005 05:08 Go to previous message
Randy,
I found the problem. My figure extends Polygon and this extends Polyline,
you have changed Polyline and added setFill(false) to the instance
initializer:
public class Polyline extends Shape
PointList points = new PointList();
private static final int TOLERANCE = 2;
private static final Rectangle LINEBOUNDS = Rectangle.SINGLETON;
setFill(false); // This line is new 3.1
bounds = null;
Jose M Beleta
Previous Topic:AWT in Draw2D
Next Topic:heavyweight/lightweight (Randy, please help...)
Current Time: Fri Jul 18 20:36:04 EDT 2025
Powered by FUDForum. Page generated in 0.04060 seconds
