Home » Language IDEs » ServerTools (WTP) » Exception with 1.5.4
Exception with 1.5.4 [message #192203] Tue, 08 May 2007 03:29 Go to next message
Originally posted by: zkoppany.gmx.de
I have a very annoying exception with 1.5.3 and 1.5.4.
I work with subversion und use subclipse-1.2.1 and the the exception below
if I try to open an older revision of an xml file. This bug exists at least
for a year. Nobody else opens older revisions of xml files?
Zsolt
at
org.eclipse.wst.sse.ui.StructuredTextEditor.update(Structure dTextEditor.java:3047)
at
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:338)
at
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:505)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:276)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2595)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2477)
at
org.tigris.subversion.subclipse.ui.actions.OpenRemoteFileAct ion$1.run(OpenRemoteFileAction.java:59)
at
org.tigris.subversion.subclipse.ui.repository.RepositoryMana ger.run(RepositoryManager.java:375)
at
org.tigris.subversion.subclipse.ui.actions.SVNAction$1.run(S VNAction.java:226)
at
org.tigris.subversion.subclipse.ui.actions.SVNAction$2.run(S VNAction.java:235)
at
org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:232)
at
org.tigris.subversion.subclipse.ui.actions.OpenRemoteFileAct ion.execute(OpenRemoteFileAction.java:36)
at
org.tigris.subversion.subclipse.ui.actions.SVNAction.run(SVN Action.java:56)
at
org.tigris.subversion.subclipse.ui.history.SVNHistoryPage$26 .run(SVNHistoryPage.java:904)
at
org.tigris.subversion.subclipse.ui.history.SVNHistoryPage$11 .handleEvent(SVNHistoryPage.java:455)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Exception with 1.5.4 [message #192219 is a reply to message #192203] Tue, 08 May 2007 08:08 Go to previous messageGo to next message
That does look annoying. What do you mean "an older revision of xml files"?
We should be able to handle an xml file of any age :)
If you haven't yet, a but report with a sample file attached would help.
Re: Exception with 1.5.4 [message #192226 is a reply to message #192203] Tue, 08 May 2007 09:02 Go to previous messageGo to next message
Ah, and you might read bug 169906
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D169906
Looks related.
Re: Exception with 1.5.4 [message #192232 is a reply to message #192226] Tue, 08 May 2007 10:15 Go to previous messageGo to next message
David,
yes, it is the bug. I have this bug at least for a year and I'm pretty
surprised that nobody else found it.
Zsolt
"David Williams" <david_williams@us.ibm.com> schrieb im Newsbeitrag
news:op.tr0ehxtmac05ss@dmw2t23.ibm.com...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=169906
Looks related.
Re: Exception with 1.5.4 [message #192267 is a reply to message #192232] Wed, 09 May 2007 12:03 Go to previous messageGo to next message
Originally posted by: kosta.bea.com
Looks like the issue has been resolved in WTP 2.0 RC0. WTP 2.0 is
scheduled to be released at the end of June of 2007. If you want to
experiment with an "integration" build of WTP 2.0, you can download the
most recent build from the following web site. Just make sure to
download the correct versions of all the pre-requisites as listed on the
build page.
http://download.eclipse.org/webtools/committers/
- Konstantin
Re: Exception with 1.5.4 [message #192344 is a reply to message #192267] Thu, 10 May 2007 01:20 Go to previous message
Thank you Konstantin,
that builds needs the latest eclipse build (3.3-M7) and currently I'm happy
with eclipse-3.2.2. I just wonder why nobody else had this problem during
the last year.
Zsolt
"Konstantin Komissarchik" <kosta@bea.com> schrieb im Newsbeitrag
news:f1sra9$g01$1@build.eclipse.org...
> most recent build from the following web site. Just make sure to download
> the correct versions of all the pre-requisites as listed on the build
> page.
> - Konstantin
Previous Topic:can I dynamically contribute to the xml catalog programitically?
Next Topic:Resource Copy while through Project Explorer in j2EE Perspective
Current Time: Sat Jul 26 18:45:50 EDT 2025
Powered by FUDForum. Page generated in 0.07655 seconds
