Home » Language IDEs » ServerTools (WTP) » customize XMl validator
customize XMl validator [message #191917] |
Wed, 02 May 2007 03:42  |
I will appriciate if anyone let me know if it is possible to set a customize
validator to resolve the schema URL?? Might be there is a way to just using
the schema file name I can append the absolute path to the schema location.
My requirement is I don't want to have absolute or relative path with in the
XML file and just want ot have schema file name.
Kashif
Re: customize XMl validator [message #191925 is a reply to message #191922] |
Wed, 02 May 2007 07:57   |
--------------000505080705070406080702
Kashif,
It's always possible to use a relative path with an xsi:schemaLocation,
e.g., xsi:schemaLocation="../../My.xsd" so if the .xsd and .xml are in
the same project, that approach should work. If they are in different
projects, you'll need to refer to the project name somehow and if
indirection through the catalog isn't sufficient, I don't think there's
another way.
kashif wrote:
> Hi Merks,
> I used XMl catlog but it does add full path in the XML location attribute.
> Also it comes to another issue like it will not be poosible for the user to
> share his project for other user. As there might be every user has to
> configure a catlog entry. So my requirement is it hsould have solved in a
> generic way. Like just adding the name of the schema and there should be
> some other way through programmatically may be.
> Kashif
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:f19rtj$pib$5@build.eclipse.org...
>> Kashif,
>> I think the XML catalog would solve this problem too.
>> kashif wrote:
>>> Hi,
>>> customize validator to resolve the schema URL?? Might be there is a way
>>> to just using the schema file name I can append the absolute path to the
>>> schema location.
>>> the XML file and just want ot have schema file name.
>>> Thanks,
>>> Kashif
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Kashif,<br>
<br>
another way.<br>
<br>
<br>
kashif wrote:
<blockquote cite="midf19u3c$vef$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Merks,
Kashif
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:f19rtj$pib$5@build.eclipse.org">news:f19rtj$pib$5@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Kashif,
kashif wrote:
</pre>
<pre wrap="">Hi,
schema location.
Kashif
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------000505080705070406080702--
Re: customize XMl validator [message #191934 is a reply to message #191925] |
Wed, 02 May 2007 08:33   |
------=_NextPart_000_00B2_01C78CE0.0A9CF550
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Ed Merks,
Yes indeed this is what I was thinking but with this a new issue comes =
up that is. When I use xsi:schemaLocation=3D"../../My.xsd" then our =
user can have options to move this file to another folder that is not at =
the same level. Then user has to manually change the relative path which =
I don't want. I was thinking if I can do somehting prgrammatically to =
confugure the EntityResolver or something like that. Might be I =
internally can set the full URL just based on schema file name??
Kashif
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:f19ubg$bd$1@build.eclipse.org...
Kashif,
It's always possible to use a relative path with an =
xsi:schemaLocation, e.g., xsi:schemaLocation=3D"../../My.xsd" so if the =
..xsd and .xml are in the same project, that approach should work. If =
they are in different projects, you'll need to refer to the project name =
somehow and if indirection through the catalog isn't sufficient, I don't =
think there's another way.
kashif wrote:=20
Hi Merks,
I used XMl catlog but it does add full path in the XML location =
attribute.=20
Also it comes to another issue like it will not be poosible for the user =
to=20
share his project for other user. As there might be every user has to=20
configure a catlog entry. So my requirement is it hsould have solved in =
a=20
generic way. Like just adding the name of the schema and there should be =
Kashif
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
Kashif,
kashif wrote:
I will appriciate if anyone let me know if it is possible to set a=20
customize validator to resolve the schema URL?? Might be there is a way=20
to just using the schema file name I can append the absolute path to the =
schema location.
My requirement is I don't want to have absolute or relative path with in =
Kashif
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-1>
<META content=3D"MSHTML 6.00.2900.3059" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi Ed Merks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Yes indeed this is what I was thinking =
but with=20
this a new issue comes up that is. When I use <FONT=20
face=3D"Times New Roman" =
size=3D3>xsi:schemaLocation=3D"../../My.xsd" then=20
our user can have options to move this file to another folder that =
is not=20
at the same level. Then user has to manually change the relative path =
which I=20
confugure=20
the EntityResolver or something like that. Might be I internally can set =
the=20
full URL just based on schema file name??</FONT></FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Kashif</FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:f19ubg$bd$1@build.eclipse.org">news:f19ubg$bd$1@build.eclips=
e.org</A>...</DIV>Kashif,<BR><BR>It's=20
always possible to use a relative path with an xsi:schemaLocation, =
e.g.,=20
xsi:schemaLocation=3D"../../My.xsd" so if the .xsd and .xml are in the =
same=20
project, that approach should work. If they are in different =
projects,=20
you'll need to refer to the project name somehow and if indirection =
through=20
the catalog isn't sufficient, I don't think there's another=20
way.<BR><BR><BR>kashif wrote:=20
<BLOCKQUOTE cite=3Dmidf19u3c$vef$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Hi Merks,
attribute.=20
to=20
a=20
Kashif
"Ed Merks" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:merks@ca.ibm.com"><merks@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:f19rtj$pib$5@build.eclipse.org">news:f19rtj$pib$5@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Kashif,
kashif wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi,
schema location.
Kashif
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00B2_01C78CE0.0A9CF550--
Re: customize XMl validator [message #191941 is a reply to message #191934] |
Wed, 02 May 2007 08:38   |
--------------070500030009040608000303
Kashif,
I'm not sure if WTP provides refactoring support that would fix relative
locations when the document is moved, but that's certainly possible.
kashif wrote:
> Hi Ed Merks,
> up that is. When I use xsi:schemaLocation="../../My.xsd" then
> our user can have options to move this file to another folder that is
> not at the same level. Then user has to manually change the relative
> path which I don't want. I was thinking if I can do somehting
> prgrammatically to confugure the EntityResolver or something like
> that. Might be I internally can set the full URL just based on schema
> file name??
> Kashif
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:f19ubg$bd$1@build.eclipse.org...
> Kashif,
> xsi:schemaLocation, e.g., xsi:schemaLocation="../../My.xsd" so if
> the .xsd and .xml are in the same project, that approach should
> work. If they are in different projects, you'll need to refer to
> the project name somehow and if indirection through the catalog
> isn't sufficient, I don't think there's another way.
> kashif wrote:
>> Hi Merks,
>> Thanks,
>> Kashif
>>> Kashif,
>>> kashif wrote:
>>>> Hi,
>>>> schema location.
>>>> Thanks,
>>>> Kashif
<html>
<head>
</head>
Kashif,<br>
<br>
relative locations when the document is moved, but that's certainly
possible.<br>
<br>
<br>
kashif wrote:
<blockquote cite="midf1a0ff$511$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.3059" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">Hi Ed Merks,</font></div>
<div> </div>
<div><font face="Arial" size="2">Yes indeed this is what I was
thinking but with this a new issue comes up that is. When I use <font
face="Times New Roman" size="3">xsi:schemaLocation="../../My.xsd" then
prgrammatically to confugure the EntityResolver or something like that.
Might be I internally can set the full URL just based on schema file
name??</font></font></div>
<div> </div>
<div><font face="Arial" size="2">Thanks,</font></div>
<div><font face="Arial" size="2">Kashif</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
wrote in message <a href="news:f19ubg$bd$1@build.eclipse.org">news:f19ubg$bd$1@build.eclipse.org</a>...</div>
Kashif,<br>
<br>
another way.<br>
<br>
<br>
Kashif
</pre>
kashif wrote:
</pre>
<pre wrap="">Hi,
schema location.
Kashif
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070500030009040608000303--
Re: customize XMl validator [message #191945 is a reply to message #191941] |
Wed, 02 May 2007 09:07   |
------=_NextPart_000_00DC_01C78CE4.D04121B0
Hi Ed Merks,
Might be I can update the moving file through resource change listener. =
But their might be some resource opened in the Editor then I was =
thinking that it might be a conflict. If you have any idea before please =
do comment. Otherwise I will try to have fix for my problem in this =
direction.
Kashif
news:f1a0op$5he$2@build.eclipse.org...
Kashif,
I'm not sure if WTP provides refactoring support that would fix =
relative locations when the document is moved, but that's certainly =
possible.
kashif wrote:=20
Hi Ed Merks,
Yes indeed this is what I was thinking but with this a new issue =
comes up that is. When I use xsi:schemaLocation=3D"../../My.xsd" then =
our user can have options to move this file to another folder that is =
not at the same level. Then user has to manually change the relative =
path which I don't want. I was thinking if I can do somehting =
prgrammatically to confugure the EntityResolver or something like that. =
Might be I internally can set the full URL just based on schema file =
name??
Kashif
Kashif,
kashif wrote:=20
Hi Merks,
attribute.=20
to=20
a=20
Kashif
Kashif,
schema location.
Kashif
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3059" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Might be I can update =
the moving file=20
through resource change listener. But their might be some =
resource=20
opened in the Editor then I was thinking that it might be a conflict. If =
you=20
have any idea before please do comment. Otherwise I will try to have fix =
for my=20
problem in this direction.</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:f1a0op$5he$2@build.eclipse.org">news:f1a0op$5he$2@build.ecli=
pse.org</A>...</DIV>Kashif,<BR><BR>I'm=20
not sure if WTP provides refactoring support that would fix relative =
locations=20
possible.<BR><BR><BR>kashif=20
wrote:=20
<BLOCKQUOTE cite=3Dmidf1a0ff$511$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Yes indeed this is what I was =
thinking but with=20
our user can have options to move this file to another folder =
that is=20
path=20
prgrammatically to=20
internally=20
<DIV> </DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A=20
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>> wrote in =
message=20
<A=20
e.g.,=20
xsi:schemaLocation=3D"../../My.xsd" so if the .xsd and .xml are in =
the same=20
projects, you'll need to refer to the project name somehow and if=20
indirection through the catalog isn't sufficient, I don't think =
there's=20
another way.<BR><BR><BR>kashif wrote:=20
attribute.=20
to=20
a=20
Kashif
message=20
pse.org</A>...
</PRE>
kashif wrote:
</PRE>
schema location.
Kashif
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_00DC_01C78CE4.D04121B0--
Re: customize XMl validator [message #191946 is a reply to message #191945] |
Wed, 02 May 2007 11:05  |
--------------020401060108020202070607
Kashif,
I think Eclipse has a refactoring API that you can contribute to for
this type of thing, but I don't know even the first thing about how that
works.
kashif wrote:
> Hi Ed Merks,
> listener. But their might be some resource opened in the Editor then I
> was thinking that it might be a conflict. If you have any idea before
> please do comment. Otherwise I will try to have fix for my problem in
> this direction.
> Kashif
> message news:f1a0op$5he$2@build.eclipse.org...
> Kashif,
> certainly possible.
> kashif wrote:
>> Hi Ed Merks,
>> xsi:schemaLocation="../../My.xsd" then our user can have options
>> to move this file to another folder that is not at the same
>> level. Then user has to manually change the relative path which I
>> to confugure the EntityResolver or something like that. Might be
>> I internally can set the full URL just based on schema file name??
>> Thanks,
>> Kashif
>> in message news:f19ubg$bd$1@build.eclipse.org...
>> Kashif,
>> so if the .xsd and .xml are in the same project, that
>> approach should work. If they are in different projects,
>> kashif wrote:
>>> Hi Merks,
>>> Thanks,
>>> Kashif
>>>> Kashif,
>>>> kashif wrote:
>>>>> Hi,
>>>>> schema location.
>>>>> Thanks,
>>>>> Kashif
<html>
<head>
<title></title>
</head>
Kashif,<br>
<br>
that works.<br>
<br>
<br>
kashif wrote:
<blockquote cite="midf1a2ff$9qd$1@build.eclipse.org" type="cite">
<div> </div>
<div><font face="Arial" size="2">Might be I can update the moving
file through resource change listener. But their might be some resource
If you have any idea before please do comment. Otherwise I will try to
have fix for my problem in this direction.</font></div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<blockquote
wrote in message <a href="news:f1a0op$5he$2@build.eclipse.org">news:f1a0op$5he$2@build.eclipse.org</a>...</div>
Kashif,<br>
<br>
possible.<br>
<br>
<br>
<style></style>
<div> </div>
<div> </div>
<blockquote
Kashif,<br>
<br>
another way.<br>
<br>
<br>
Kashif
</pre>
kashif wrote:
</pre>
<pre wrap="">Hi,
schema location.
Kashif
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------020401060108020202070607--
Current Time: Fri Jul 25 22:05:10 EDT 2025
Powered by FUDForum. Page generated in 0.25808 seconds
