Home » Language IDEs » ServerTools (WTP) » WST XML editor schema finding using name of the schema
WST XML editor schema finding using name of the schema [message #191902] Wed, 02 May 2007 02:04 Go to next message
is there anyway to configure WST XML editor in a way that all the XML files
in an eclipse prject locate to the schema files at the project root?? The
project may have subfolders to hold XMl files. What I want is to just
mention the name of the schema file and don't want to mention the project
relative path. Your comment in this regard will be helpfull.
Kashif
Re: WST XML editor schema finding using name of the schema [message #191918 is a reply to message #191902] Wed, 02 May 2007 07:15 Go to previous messageGo to next message
Kashif,
I don't know the details, but I'm quite sure WTP supports an XML catalog
that allows you to specify the location of the schema for each target
namespace. So look for a way to configure the catalog.
kashif wrote:
> Kashif
Re: WST XML editor schema finding using name of the schema [message #191927 is a reply to message #191918] Wed, 02 May 2007 08:00 Go to previous messageGo to next message
Hi Ed Merks,
Let me explain my problem....
My project structure looks like this
Project
a.. TemplateFolder
a.. Template1.xml
b.. Template2.xml
a.. MenuFolder
a.. Menu1.xml
b.. Menu2.xml
a.. Project.xml
b.. Tokens.xml
c.. Settings.xml
d.. SchemaFolder
a.. Schema for Template XML files
b.. Schema for Menu XML files
c.. Schema for Project XML files
d.. Schema for Tokens XMl files
e.. .....
f.. .....
What I really wanted to do is to just have a subfolder at the project level
say "schema". This is the folder which will have the schema files for all
the different types of XML files (template, menu, project, tokens and
settings). I don't want to put absolute the location of the schema file. If
I mention the absolute location of the schema file in the XML file then all
the projects does not preserve the shareable nature. It means if in my
project the location of the schema file is
F:\Infelxion_handheld\schema\temp\uiTemplate.xsd
This same location will not be valid for other user at his system. What I
can do is for the user I can place all my schema files in the in the project
root and might be XML editor allow me some sort of configuration mechanism
to resolve these schema files placed under the project root. If it does have
already built in mechanism that will be great which I don't know.
I got know that it can resolve the schema file location if I use
<uiMenu xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="../uiMenu.xsd">
uiMenu is the root element in my XMl file. This XML file is placed under the
Menu folder in the Project. But this is too an issue as user is allowed to
move file from one directory to another and then we have to track the
copying operation as well which seems not to be realistic.
I would really appreciate your valuable comments to solve the above problem.
Kashif
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:f19rs6$pib$4@build.eclipse.org...
> Kashif,
> kashif wrote:
>> Hi,
>> files in an eclipse prject locate to the schema files at the project
>> root?? The project may have subfolders to hold XMl files. What I want is
>> to just mention the name of the schema file and don't want to mention the
>> project relative path. Your comment in this regard will be helpfull.
>> Thanks,
>> Kashif
Re: WST XML editor schema finding using name of the schema [message #191930 is a reply to message #191918] Wed, 02 May 2007 08:14 Go to previous messageGo to next message
Hi Ed Merks,
I just created a namespace entry thorugh catlog
URI: platform:/resource/Spiderman Theme/uiMenu.xsd
Key Type: Namespace Name
Key: Test1
My XMl file the looks like this
xsi:schemaLocation="http://www.w3.org/2001/XMLSchema-instance Test">
I found the following warning message "No grammer constraint detected for
the Document"
May be I am missing something which needs to be address. When I use schema
location option it says there needs to be full path to the location is
required which does not fit wiht the requirement which I mentioned in the
Last email. Any thoughts at this??
Kashif
> Kashif,
> kashif wrote:
>> Hi,
>> Thanks,
>> Kashif
Re: WST XML editor schema finding using name of the schema [message #191940 is a reply to message #191930] Wed, 02 May 2007 08:37 Go to previous messageGo to next message
--------------080807010501050207020208
Kashif,
I'm really not familiar with how WTP manages the catalog but if relative
paths don't make you happy, and paths of the form
platform:/resource/project/My.xsd don't make you happy (maybe you don't
know about those?), then your last alternative appears to be the
catalog. In general a relative path like "Test" will/should be resolved
against the containing document's URI. I.e., if the example below were
in resource with URI platform:/resource/project/my.xml then the schema's
location should resolve to platform:/resource/project/Test and that
should be what's looked up in the XML catalog.
kashif wrote:
> Hi Ed Merks,
> Location: Spiderman Theme/uiMenu.xsd
> Key: Test1
> the Document"
> Kashif
>> Kashif,
>> kashif wrote:
>>> Hi,
>>> Thanks,
>>> Kashif
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Kashif,<br>
<br>
relative paths don't make you happy, and paths of the form
catalog.&nbsp; In general a relative path like "Test" will/should be
resolved against the containing document's URI.&nbsp; I.e., if the example
below were in resource with URI platform:/resource/project/my.xml then
the schema's location should resolve to platform:/resource/project/Test
and that should be what's looked up in the XML catalog.<br>
<br>
<br>
kashif wrote:
<blockquote cite="midf19vc2$2eb$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed Merks,
Key: Test1
&lt;uiMenu xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xsi:schemaLocation=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instanceTest">"http://www.w3.org/2001/XMLSchema-instance Test"</a>&gt;
the Document"
Kashif
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:f19rs6$pib$4@build.eclipse.org">news:f19rs6$pib$4@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Kashif,
kashif wrote:
</pre>
<pre wrap="">Hi,
Kashif
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------080807010501050207020208--
Re: WST XML editor schema finding using name of the schema [message #191949 is a reply to message #191940] Wed, 02 May 2007 13:02 Go to previous messageGo to next message
Please note that the XML Catalog only supports keys that are 'qualified'
locations.
So creating an entry like this...
'http://www.example.org/myschema.xsd' --> 'D:/foo/myschema/xsd'
.. is supported but creating an entry lis this...
'myschema.xsd' --> 'D:/foo/myschema/xsd'
.. is not supported.
For more info see this feature request...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=104001
BTW, you can likely achieve exactly what you want by providing a
URIResolver extension. That means having to write a bit of plugin code.
But it should be very do-able. Table a look at wst.common.uriresolver
Re: WST XML editor schema finding using name of the schema [message #191972 is a reply to message #191949] Thu, 03 May 2007 01:43 Go to previous messageGo to next message
Hi Criag,
This seems to be a cool idea. I try to implement URIResolver interface but a
null pointer exception occurs while getting the resolver. May be I am
missing something here??
at
org.eclipse.wst.common.uriresolver.internal.URIResolverExten sionDescriptor.getResolver(URIResolverExtensionDescriptor.ja va:81)
at
org.eclipse.wst.common.uriresolver.internal.URIResolverExten sionRegistry.getMatchingURIResolvers(URIResolverExtensionReg istry.java:153)
at
org.eclipse.wst.common.uriresolver.internal.ExtensibleURIRes olver.resolvePhysicalLocation(ExtensibleURIResolver.java:105 )
at
org.eclipse.wst.xml.core.internal.validation.ValidatorHelper $MyContentHandler.startElement(ValidatorHelper.java:257)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
at org.apache.xerces.impl.dtd.XMLDTDValidator.startElement(Unkn own Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentScannerImpl$ContentDispatc her.scanRootElementHook(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatcher.dispatch(Unknown
Source)
at
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at
org.eclipse.wst.xml.core.internal.validation.ValidatorHelper .computeValidationInformation(ValidatorHelper.java:144)
at
org.eclipse.wst.xml.core.internal.validation.XMLValidator.va lidate(XMLValidator.java:264)
at
org.eclipse.wst.xml.core.internal.validation.eclipse.Validat or.validate(Validator.java:70)
at
org.eclipse.wst.xml.core.internal.validation.core.AbstractNe stedValidator.validate(AbstractNestedValidator.java:241)
at
org.eclipse.wst.xml.core.internal.validation.core.AbstractNe stedValidator.validateInJob(AbstractNestedValidator.java:88)
at
org.eclipse.wst.xml.ui.internal.validation.DelegatingSourceV alidator.validate(DelegatingSourceValidator.java:211)
at
org.eclipse.wst.sse.ui.internal.reconcile.validator.Reconcil eStepForValidator.validate(ReconcileStepForValidator.java:27 7)
at
org.eclipse.wst.sse.ui.internal.reconcile.validator.Reconcil eStepForValidator.reconcileModel(ReconcileStepForValidator.j ava:243)
at
org.eclipse.jface.text.reconciler.AbstractReconcileStep.reco ncile(AbstractReconcileStep.java:96)
at
org.eclipse.wst.sse.ui.internal.reconcile.validator.Validato rStrategy.reconcile(ValidatorStrategy.java:204)
at
org.eclipse.wst.sse.ui.internal.reconcile.DocumentRegionProc essor.process(DocumentRegionProcessor.java:183)
at
org.eclipse.wst.sse.ui.internal.reconcile.StructuredRegionPr ocessor.process(StructuredRegionProcessor.java:302)
at
org.eclipse.wst.sse.ui.internal.reconcile.DirtyRegionProcess or.run(DirtyRegionProcessor.java:636)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
Kashif
"craig" <csalter@ca.ibm.com> wrote in message
news:3665b0905a32b826f4060987d6c3a0a5$1@www.eclipse.org...
> locations.
> . is not supported.
Re: WST XML editor schema finding using name of the schema [message #191983 is a reply to message #191972] Thu, 03 May 2007 05:58 Go to previous messageGo to next message
Hi Criag,
Please ignore my Last URIResolver exception problem. I just removed the id
and name and it works fine. Seems it might be a bug. Anyway it works without
id and name for resolver
But now I am curious to know if it works or not as I just return the file
system path for the specific schema file but it does not work. It looks like
that cutomize resolver has no significance impact over the help tooltip,
content assist and error messages. They showed up if I just return wrong
path.
Looks like there is something else which I need to implement??
Kashif
"kashif" <kashif_shahzad@mentor.com> wrote in message
news:f1bspb$7uf$1@build.eclipse.org...
> Hi Criag,
> a null pointer exception occurs while getting the resolver. May be I am
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Kashif
>> locations.
>> . is not supported.
Re: WST XML editor schema finding using name of the schema [message #191992 is a reply to message #191983] Thu, 03 May 2007 08:52 Go to previous messageGo to next message
Thanks All.
I am fixed my problem and it's up now
Kashif
news:f1cbot$j68$1@build.eclipse.org...
> Hi Criag,
> without id and name for resolver
> like that cutomize resolver has no significance impact over the help
> tooltip, content assist and error messages. They showed up if I just
> return wrong path.
> Kashif
>> Hi Criag,
>> but a null pointer exception occurs while getting the resolver. May be I
>> am missing something here??
>> at
>> at
>> at
>> at
>> Source)
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks,
>> Kashif
>>> locations.
>>> . is not supported.
Re: WST XML editor schema finding using name of the schema [message #192027 is a reply to message #191992] Thu, 03 May 2007 12:47 Go to previous message
Kashif,
Glad to hear you managed to get things working. If you have time to
contribute a short tutorial on the Eclipse WIKI [1] to describe the steps
you needed to take to achieve this I'm sure community would appreciate it.
[1] http://wiki.eclipse.org/index.php/Web_Tools_Project
kashif wrote:
> Thanks All.
> Kashif
Previous Topic:Doubt about the kind of web project to start
Next Topic:XMl attribute value validation
Current Time: Fri Sep 12 23:42:13 EDT 2025
Powered by FUDForum. Page generated in 0.04511 seconds
