Home » Language IDEs » ServerTools (WTP) » Changing the location of WebContent
Changing the location of WebContent [message #191772] Wed, 25 April 2007 13:03 Go to next message
Originally posted by: chris.lieb.gmail.com
I am trying to change the location of the WebContent folder the Eclipse
references so that I can get the project to correctly read the folder
hierarchy that Maven2 generates. In Maven, the source files for the web
pages (normally contained in the WebContent folder; classes folder
excluded) are stored at src/main/webapp and the compiled classes at
target/classes. Basically, the final directory structure would be:
project/
src/
main/
java/
[*.java source files]
webapp/
[*.html, *.jsp[x], *.tld, etc]
test/
java/
[*.java test source files]
target/
classes/
[compiled class files]
project.war
instead of:
project/
JavaSource/
WebContent/
WEB-INF/
classes/
I can't seem to find any settings to accomplish this in the project
Properties dialog box nor in any of the generated project config files.
BTW: I had no problem changing the Java source folders or the output
folder, just the WebContent folder.
Thanks in advance,
Chris Lieb
Re: Changing the location of WebContent [message #191790 is a reply to message #191772] Wed, 25 April 2007 15:32 Go to previous messageGo to next message
The relevant setting is stored in the following element in the
..settings/org.eclipse.wst.common.component file:
<wb-resource deploy-path="/" source-path="/WebContent"/>
(this element maps the contents of the "WebContent" folder into the root of
the published web module)
Although no UI support for changing this exists, I just released changes
(will be in this week's WTP 2.0 RC0 I-build) that will automatically update
this element when the user renames or moves the WebContent folder (this
actually applies to any non-Java src folder that is mapped in the
org.eclipse.wst.common.component file; such support already exists for
changes to mapped Java src folders)
-Rob
"Chris Lieb" <chris.lieb@gmail.com> wrote in message
news:f0o1la$vtb$1@build.eclipse.org...
> project/
> src/
> main/
> java/
> webapp/
> test/
> java/
> target/
> classes/
> project.war
> instead of:
> project/
> JavaSource/
> WebContent/
> WEB-INF/
> classes/
> Thanks in advance,
> Chris Lieb
Re: Changing the location of WebContent [message #191805 is a reply to message #191790] Wed, 25 April 2007 16:49 Go to previous message
I had tried changing that setting, but it didn't seem to have any
effect. It still tried creating a new WebContent folder every time I
opened the IDE. Maybe it's just one of those IBM "contributions" that
they make to Rational App Developer before releasing it for sale.
Chris Lieb
> -Rob
>> project/
>> src/
>> main/
>> java/
>> webapp/
>> test/
>> java/
>> target/
>> classes/
>> project.war
>> instead of:
>> project/
>> JavaSource/
>> WebContent/
>> WEB-INF/
>> classes/
>> Thanks in advance,
>> Chris Lieb
Previous Topic:Re: problems at pattern facet creation/validation
Next Topic:geronimo-web.xml
Current Time: Fri Jul 18 22:07:10 EDT 2025
Powered by FUDForum. Page generated in 0.04085 seconds
