Home » Language IDEs » Java Development Tools (JDT) » What happened to 'Open Call Hierarchy'
What happened to 'Open Call Hierarchy' [message #191498] Tue, 04 January 2005 05:22 Go to next message
Originally posted by: sbierman.idfix.nl
I work with 3.1M4 (Win2K/j2se1.5) and recently my 'Open Call Hierarchy' has
stopped working, it shows zero calls for every method I select.
In 3.1M3 I had the same thing and when I upgraded to M4 it worked fine
again. I concluded it was probably a bug in M3.
Now the same thing has happened in M4.
Did anyone experience the same or does anyone know how to fix it?
Silvio Bierman
Re: What happened to 'Open Call Hierarchy' [message #191546 is a reply to message #191498] Tue, 04 January 2005 14:09 Go to previous messageGo to next message
> Hierarchy' has stopped working, it shows zero calls for every method
> I select.
It works for me (J2SE 1.5.1, Eclipse 3.1M4, Linux) and afair it always
worked. Running 'eclipse -clean' doesn't do any good? (or opening new
workspace)
a.
Re: What happened to 'Open Call Hierarchy' [message #191580 is a reply to message #191546] Tue, 04 January 2005 17:22 Go to previous messageGo to next message
>> Hierarchy' has stopped working, it shows zero calls for every method I
>> select.
> workspace)
I had this problem. It cleared up after I started with a fresh
workspace. There is a bug report out there but it got closed as
unreproducable.
Neil Swingler
Re: What happened to 'Open Call Hierarchy' [message #191588 is a reply to message #191546] Tue, 04 January 2005 20:06 Go to previous messageGo to next message
"Adam Kruszewski" <spambox@kruszewski.name> wrote in message
news:crepl6$cak$1@www.eclipse.org...
> > I select.
> workspace)
> Cheers,
> a.
This may sound stupid but I have no idea how to create a new workspace...
Eclipse -clean did not do anything noticable to me.
Silvio Bierman
Re: What happened to 'Open Call Hierarchy' [message #191634 is a reply to message #191588] Wed, 05 January 2005 04:25 Go to previous messageGo to next message
>>>I select.
>>workspace)
>>Cheers,
>> a.
Try to reset the perspective (Window > Reset Perspective)
Dani
>Silvio Bierman
Re: What happened to 'Open Call Hierarchy' [message #191649 is a reply to message #191580] Wed, 05 January 2005 04:35 Go to previous messageGo to next message
>>> I select.
>> workspace)
> unreproducable.
The bug report is https://bugs.eclipse.org/bugs/show_bug.cgi?id=80487
Silvio, did you check that the Call Hierarchy's settings are correct? I.e.
- 'Show Caller Hierarchy' is active
- Search Scope is set to Workspace (Context menu, or view toolbar menu
(Ctrl+F10))
HTH
Markus
Re: What happened to 'Open Call Hierarchy' [message #191700 is a reply to message #191649] Wed, 05 January 2005 11:42 Go to previous messageGo to next message
Hello Markus,
Thanks for replying, I answered your questions inline...
"Markus Keller" <markus_keller@ch.ibm.com> wrote in message
news:crgccc$57i$1@www.eclipse.org...
Yes, it is active (I have never changed that)
> (Ctrl+F10))
Yes, that is set to Workspace, never changed that either.
> HTH
> Markus
Silvio
Re: What happened to 'Open Call Hierarchy' [message #191748 is a reply to message #191588] Wed, 05 January 2005 19:19 Go to previous message
It's easy. "File -> Switch Workspace" and enter a directory name that
doesn't yet exist - it'll be created automagically.
Andrew Jr.
IBM Phoenix Labs (OTI)
2929 North Central Avenue
Phoenix, Arizona, USA 85012
Previous Topic:CVS pre-commit hook
Next Topic:Very Quick Navigator Question
Current Time: Wed Nov 05 08:24:38 EST 2025
Powered by FUDForum. Page generated in 0.04428 seconds
