server launch configuration, classpath user entries work? [message #191633] |
Thu, 19 April 2007 11:16  |
Originally posted by: jacek.pospychala.pl.ibm.com
I have some problems with running a web application A on WebLogic. It
requires my another project B so i add it to server launch configuration
(in user entries), but this project B is not sent to the server.
How should I set the project B to be uploaded to the server? It contains
some libraries shared among other web apps so has to be uploaded to a
user entries classpath, and not be included in web application.
Any suggestions appreciated!
Jacek
Re: server launch configuration, classpath user entries work? [message #191668 is a reply to message #191643] |
Fri, 20 April 2007 04:37   |
Thanks Rob!
do you think the shared library feature is stable/straight enough among
different versions of WLS (8,9,9.2) that it could be put right in the
launch configuration GUI, so others wouldn't have to bother themselves
reading docs? :)
Unfortunately i am not an expert in configuring WLS...
Rob Frost wrote:
> Hi Jacek,
> Editing that launch configuration classpath is not going to help you in this
> context (the generic WLS servers are launched as a separate process via
> startWeblogic.* and the classpath for that JVM is set in the script).
> You normally want to express such dependencies via the "J2EE Module
> Dependencies" properties page (for a standalone web project, these
> dependencies will placed the JAR for the referenced project in the
> WEB-INF/lib dir of the project).
> If you want a single copy of this WAR/JAR/EAR shared by multiple modules on
> WLS, then you can investigate the shared library feature of WLS (see the WLS
> docs for more information)
> -Rob
> "Jacek Pospychala" <jacek.pospychala@pl.ibm.com> wrote in message
> news:f08179$eu0$1@build.eclipse.org...
>> Hello,
>> some libraries shared among other web apps so has to be uploaded to a user
>> Jacek
Re: server launch configuration, classpath user entries work? [message #191683 is a reply to message #191668] |
Fri, 20 April 2007 10:18  |
hi Jacek,
If you are interested in leveraging shared library support easily from
within WTP right now, you should take a look at the BEA Workshop product
(http://dev2dev.bea.com/workshop/); this product is built on top of WTP and
includes integrated shared library support (for details on this support, see
http://edocs.bea.com/wlw/docs100/guide/ideuserguide/conJARLi braryDependencies.html;
for general information about shared library support in WLS, see
http://e-docs.bea.com/wls/docs100/programming/libraries.html).
-Rob
news:f09u6e$tsr$1@build.eclipse.org...
> Thanks Rob!
> reading docs? :)
> Rob Frost wrote:
>> Hi Jacek,
>> this context (the generic WLS servers are launched as a separate process
>> via startWeblogic.* and the classpath for that JVM is set in the script).
>> on WLS, then you can investigate the shared library feature of WLS (see
>> the WLS docs for more information)
>> -Rob
>>> Hello,
>>> Jacek
FUDForum. Page generated in 0.05442 seconds
