Home » Newcomers » Newcomers » What is the hot key to copy the whole line in Eclipse?
What is the hot key to copy the whole line in Eclipse? [message #191082] Wed, 31 January 2007 10:35 Go to next message
Originally posted by: www.nospam.net
I am wondering what is the hot key is for copying the whole line in Eclipse?
I know Ctr-D deletes the whole line. How about copying?
Thank you.
Re: What is the hot key to copy the whole line in Eclipse? [message #191097 is a reply to message #191082] Wed, 31 January 2007 10:45 Go to previous messageGo to next message
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Ctrl-Shift-L ;)
You may try Ctrl-Alt-Down and Ctrl-Alt-Up, however it seems there is a
bug, because those shortcuts dont work in 3.3.
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191104 is a reply to message #191097] Wed, 31 January 2007 10:50 Go to previous messageGo to next message
and they does not work because of:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=162524
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191112 is a reply to message #191097] Wed, 31 January 2007 10:50 Go to previous messageGo to next message
Krzysztof Daniel wrote:
> Ctrl-Shift-L ;)
No. It opens the hot key menu. Like you said below, I have tried
Ctrl-Alt-Down, but it does not work either.
> Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191185 is a reply to message #191112] Wed, 31 January 2007 15:32 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
NotDashEscaped: You need GnuPG to verify this message
www uitte de volgende tekst op 01/31/2007 04:50 PM:
>> Ctrl-Shift-L ;)
How come that doesn’t surprise me? Sometimes, you have to learn to read
between the lines. Like, the smiley.
Ctrl-Alt-Down/Up moves the current line up/down, doing some fancy things
with indentation.
H.
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
www.lieverleven.be
http://aouw.org
http://catb.org/~esr/faqs/smart-questions.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2 (GNU/Linux)
iD8DBQFFwPzhe+7xMGD3itQRAszTAJ4ni2FhxZk/T2o8oF3Fd73HWrFu1QCc C+TK
2HfZOWUnwtkbpgPwmLqt90M=
=O4gL
-----END PGP SIGNATURE-----
Re: What is the hot key to copy the whole line in Eclipse? [message #191247 is a reply to message #191185] Wed, 31 January 2007 18:51 Go to previous messageGo to next message
Originally posted by: kwarner.uneedspeed.net
> Hash: SHA1
>>>Ctrl-Shift-L ;)
> with indentation.
> H.
I've been trying to figure out how to select the whole line since I started using Eclipse a month ago.
Still haven't figured it out.
Re: What is the hot key to copy the whole line in Eclipse? [message #191270 is a reply to message #191247] Thu, 01 February 2007 04:29 Go to previous messageGo to next message
End -> Shift+Home
Home -> Shift+End
is such a big problem ? ;)
bartek michalik
Re: What is the hot key to copy the whole line in Eclipse? [message #191385 is a reply to message #191185] Thu, 01 February 2007 08:54 Go to previous messageGo to next message
> with indentation.
> H.
I guess we all need to learn reading!
Like I said, in my hand, Ctrl-Alt-Down does not work. The other person
said the it is buggy in the current version. Did you read it?
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191455 is a reply to message #191270] Thu, 01 February 2007 13:53 Go to previous messageGo to next message
> End -> Shift+Home
> Home -> Shift+End
> bartek michalik
In most visual editors that I have used -- like the one I use to type this message -- three mouse clicks will select the whole line. Which then can be dragged to another location. Real handy gesture...
Can't do that in Java editor or VE. That's what I mean.
Alternatively, clicking in one spot on the line and then using a key stroke combination to select the whole line would be good if one could then click on the line and drag it.
The way you describe is more primitive than vi in an x-term.
Surely, Eclipse can do better than that.
Re: What is the hot key to copy the whole line in Eclipse? [message #191606 is a reply to message #191455] Fri, 02 February 2007 07:51 Go to previous messageGo to next message
And what about alt-up and alt-down? also on multiline selection?
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191614 is a reply to message #191385] Fri, 02 February 2007 08:02 Go to previous messageGo to next message
Actually I have posted reason why it does not work right after
proposition, just a few things to do and it works for me ;).
To be clear:
Alt-Up/Down moves lines
Ctrl-Alt-Up/Down copy current line and places it before/after the
current one.
Cheers
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191638 is a reply to message #191614] Fri, 02 February 2007 13:34 Go to previous messageGo to next message
> To be clear:
> current one.
> Cheers
> Chris
That's not what we are talking about....
Re: What is the hot key to copy the whole line in Eclipse? [message #191944 is a reply to message #191638] Sat, 03 February 2007 12:36 Go to previous messageGo to next message
Originally posted by: krzysztofHMMMdaniel.gmail.com
I cannot agree. My personal opinion is, that those key shortcuts cover
copying line and moving it into different place of method/class.
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #191951 is a reply to message #191944] Sat, 03 February 2007 13:34 Go to previous messageGo to next message
> Chris
I tell you that's not what I want -- and you tell me it is...
Re: What is the hot key to copy the whole line in Eclipse? [message #192249 is a reply to message #191455] Tue, 06 February 2007 11:46 Go to previous messageGo to next message
Drag-and-drop text editing is an open enhancement request in Bugzilla.
I'm not familiar with the details nor why it has not been implemented,
but I'm sure there are good reasons and a healthy discussion (to which
you can contribute) if you find the relevant Bugzilla report:
http://bugs.eclipse.org
Hope this helps,
Eric
Re: What is the hot key to copy the whole line in Eclipse? [message #192263 is a reply to message #192249] Tue, 06 February 2007 11:58 Go to previous messageGo to next message
This will be in M5.
Dani
> Hope this helps,
> Eric
Re: What is the hot key to copy the whole line in Eclipse? [message #192420 is a reply to message #192263] Tue, 06 February 2007 23:34 Go to previous messageGo to next message
> This will be in M5.
> Dani
>> Hope this helps,
>> Eric
uhhh...what's M5 he asked sheepishly....
Re: What is the hot key to copy the whole line in Eclipse? [message #192436 is a reply to message #192420] Wed, 07 February 2007 02:30 Go to previous messageGo to next message
M5 is 5th Milestone of Eclipse. It is currently being tested.
If you look here
http://download.eclipse.org/eclipse/downloads/
you can see that milestone is released every ca 6 weeks, so M5 should be
available in 2 :)
Chris
Re: What is the hot key to copy the whole line in Eclipse? [message #192559 is a reply to message #192436] Wed, 07 February 2007 13:07 Go to previous messageGo to next message
> If you look here
> available in 2 :)
> Regards,
> Chris
Thanks for the reply Chris...
I'm using 3.2.1 right now. I am reluctant to spend the time and energy to keep my installation current with each new "Stream Stable Build".
I will wait for the next "Latest Release" to upgrade. One can spend a lot of time trying to keep current...
Re: What is the hot key to copy the whole line in Eclipse? [message #192604 is a reply to message #192559] Wed, 07 February 2007 18:08 Go to previous messageGo to next message
>> If you look here
>> be available in 2 :)
>> Regards,
>> Chris
That is definitely true. Just so you know, the M-builds are generally
very stable and reliable; you might want to consider getting M5 since it
will have a particular feature you are looking for. That doesn't mean
you have to keep it up to date, you can just use it until the GA release
of 3.3.
If you do that, keep in mind two things:
a) Don't install 3.3M5 (or any version) on top of (in the same
directory) as your existing 3.2 installation - put it in a separate
location.
b) Once you open your existing workspace with 3.3, it will no longer be
compatible with 3.2. To mitigate this, back up your workspace before
opening it with 3.3. That way you can always go back to using 3.2 if you
don't like 3.3. You can also try copying the workspace to a new location
and opening that copy with 3.3, but that can cause some minor problems
if there are absolute paths stored anywhere in the workspace.
Hope this helps,
Eric
Re: What is the hot key to copy the whole line in Eclipse? [message #192683 is a reply to message #192604] Thu, 08 February 2007 06:40 Go to previous messageGo to next message
>>> If you look here
>>> should be available in 2 :)
>>> Regards,
>>> Chris
>> Build". I will wait for the next "Latest Release" to upgrade. One
> it will have a particular feature you are looking for.
Just to clarify: the milestone builds (like 3.3 M5) are called stable
builds and hence S-builds. M-builds are maintenance builds, see
http://eclipsebuildserv.ottawa.ibm.com/downloads/master/down loads/build_types.html
for more details.
Dani
> That doesn't mean you have to keep it up to date, you can just use it
> until the GA release of 3.3.
> location.
> be compatible with 3.2. To mitigate this, back up your workspace
> before opening it with 3.3. That way you can always go back to using
> 3.2 if you don't like 3.3. You can also try copying the workspace to a
> new location and opening that copy with 3.3, but that can cause some
> minor problems if there are absolute paths stored anywhere in the
> workspace.
> Hope this helps,
> Eric
Re: What is the hot key to copy the whole line in Eclipse? [message #192834 is a reply to message #192683] Thu, 08 February 2007 13:56 Go to previous messageGo to next message
I learn more every day. Thanks guys....
>>>> If you look here
>>>> Regards,
>>>> Chris
> for more details.
> Dani
>> location.
>> workspace.
>> Hope this helps,
>> Eric
Re: What is the hot key to copy the whole line in Eclipse? [message #192924 is a reply to message #192683] Thu, 08 February 2007 16:34 Go to previous message
>>>> If you look here
>>>> Regards,
>>>> Chris
> for more details.
Hmm, I never knew that nomenclature existed. Whoever decided to use the
Mx name for builds in light of the fact that "M-build" is a name that
means something else, should be beaten with a cold fish. :-)
Eric
Previous Topic:unable to import javax.mail.* into java files in Eclipse
Next Topic:Automatic Perspective Switching
Current Time: Thu Aug 07 17:29:17 EDT 2025
Powered by FUDForum. Page generated in 0.09068 seconds
