Home » Eclipse Projects » Eclipse Platform » Adding a PropertySheetViewer-like control within an editor
| Adding a PropertySheetViewer-like control within an editor [message #191347] |
Mon, 09 February 2004 04:31   |
Eclipse User  |
Hi all,
I would like to integrate a control that is functionally equivalent to a
PropertySheetViewer directly into an editor.  Simply using the Properties
View is not an option, as this control must reside inside of a Composite
within my editor.
To the best of my knowledge at present, the only means of accomplishing
this is to roll my own TableTree component that provides the same
capabilities as Eclipse's PropertySheetViewer object.  PropertySheetViewer
has package-protected (default) visibility, so it's obviously not an
option to use it directly.
Is there a simpler means of building a property-editing widget than
rolling my own from scratch?
Best regards
--Tod Liebeck
| Re: Adding a PropertySheetViewer-like control within an editor [message #191550 is a reply to message #191347] |
Mon, 09 February 2004 13:48    |
Eclipse User  |
We had almost exactly the same requirement (except that we didn't have to have
the TableTree complication), and after much work, and several costly and
failed attempts to reuse PropertySheet-code, we simply wrote our own, from the
TableViewer up. The biggest, and still present, pain is dealing with the
cell-editors, since TableViewer assumes that a given column of the Table will
only have ONE (1) type of cell-editor ever, but the essence of a
PropertyViewer is to have different types of properties (boolean, text,
enumeration) in the same Viewer.
best of luck!
Paul
Tod Liebeck wrote:
> Hi all,
> within my editor.
> Best regards
> --Tod Liebeck
| Re: Adding a PropertySheetViewer-like control within an editor [message #192928 is a reply to message #191550] |
Wed, 11 February 2004 19:53   |
Eclipse User  |
Hi Paul,
Thanks for confirming my fears, just wanted to be sure I wasn't
re-inventing the wheel by writing my own property editing widget.  I've
got a first draft up-and-running and it seems to work okay.  My version's
based off Table rather than TableViewer though.  I didn't actually need
the hierarchal capabilities of TableTree either.  I've attached the source
of what I've written so far in case it might help you or anyone else here.
 It's not production quality code yet and still has a few issues but it
 does work for the most part.  Using it is as simple as adding it to the
 UI and setting the property source.  Thanks again for the info.
Best regards
--Tod Liebeck
  NextApp, Inc.
package nextapp.es.form.property;
import nextapp.es.Messages;
import org.eclipse.jface.viewers.CellEditor; import
org.eclipse.jface.viewers.ColumnWeightData; import
org.eclipse.jface.viewers.ICellEditorListener; import
org.eclipse.jface.viewers.ILabelProvider; import
org.eclipse.jface.viewers.TableLayout; import org.eclipse.swt.SWT; import
org.eclipse.swt.custom.TableEditor; import
org.eclipse.swt.events.KeyAdapter; import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.MouseAdapter; import
org.eclipse.swt.events.MouseEvent; import
org.eclipse.swt.events.SelectionAdapter; import
org.eclipse.swt.events.SelectionEvent; import
org.eclipse.swt.graphics.Point; import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Composite; import
org.eclipse.swt.widgets.Control; import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn; import
org.eclipse.swt.widgets.TableItem; import
org.eclipse.ui.views.properties.IPropertyDescriptor; import
org.eclipse.ui.views.properties.IPropertySource;
 * Displays an editable table of properties based on an *
 <code>IPropertySource</code>.
public class PropertyTable extends Composite {
     * Listener for the active <code>CellEditor</code>. */
    private final ICellEditorListener activeEditorListener = new
    ICellEditorListener() {
         * @see
          org.eclipse.jface.viewers.ICellEditorListener#cancelEditor() */
        public void cancelEditor() {
            deactivateCellEditor();
         * @see
          org.eclipse.jface.viewers.ICellEditorListener#editorValueCha nged(boolean,
         boolean) */
        public void editorValueChanged(boolean oldValidState, boolean
        newValidState) { }
         * @see
          org.eclipse.jface.viewers.ICellEditorListener#applyEditorVal ue()
        public void applyEditorValue() {
            PropertyTable.this.applyEditorValue(); deactivateCellEditor();
     * The <code>Table</code> used to display properties. */
    private Table table;
     * The <code>TableEditor</code> used to edit properties. */
    private TableEditor tableEditor;
     * The currently active <code>CellEditor</code>. */
    private CellEditor cellEditor;
     * The <code>IPropertySource</code> from which property data is
     pulled. */
    private IPropertySource propertySource;
     * Creates a new <code>PropertyTable</code>. * * @param parent The
     parent container. */
    public PropertyTable(Composite parent) {
        super(parent, SWT.NONE);
        setLayout(new FillLayout());
        table = new Table(this, SWT.FULL_SELECTION | SWT.SINGLE |
        SWT.HIDE_SELECTION); table.setLinesVisible(true);
        table.setHeaderVisible(true);
        TableColumn nameColumn = new TableColumn(table, SWT.NONE);
        nameColumn.setText(Messages.getString("ComponentProperties.NameHeader "));
        TableColumn valueColumn = new TableColumn(table, SWT.NONE);
        valueColumn.setText(Messages.getString("ComponentProperties.ValueHeader "));
        TableLayout tableLayout = new TableLayout();
        tableLayout.addColumnData(new ColumnWeightData(40, false));
        tableLayout.addColumnData(new ColumnWeightData(60, true));
        table.setLayout(tableLayout);
        tableEditor = new TableEditor(table);
        table.addSelectionListener(new SelectionAdapter() {
             * @see
              org.eclipse.swt.events.SelectionListener#widgetDefaultSelect ed(org.eclipse.swt.events.SelectionEvent)
            public void widgetDefaultSelected(SelectionEvent e) {
                processSelection((TableItem) e.item);
        table.addMouseListener(new MouseAdapter() {
             * @see
              org.eclipse.swt.events.MouseListener#mouseDown(org.eclipse.s wt.events.MouseEvent)
            public void mouseDown(MouseEvent e) {
                Point point = new Point(e.x, e.y);
                TableItem item = table.getItem(point); if (item != null) {
                    processSelection(item);
        table.addKeyListener(new KeyAdapter() {
             * @see
              org.eclipse.swt.events.KeyListener#keyReleased(org.eclipse.s wt.events.KeyEvent)
            public void keyReleased(KeyEvent e) {
                if (e.character == SWT.ESC) {
                } else if (e.character == SWT.F5) {
                    updateProperties();
     * Activates the cell editor for the specified item. */
    private void activateCellEditor(TableItem item) {
        table.showSelection();
        IPropertyDescriptor propertyDescriptor = (IPropertyDescriptor)
        item.getData(); cellEditor =
        propertyDescriptor.createPropertyEditor(table);
        if (cellEditor == null) {
            // No editor provided.
            return;
         cellEditor.setValue(propertySource.getPropertyValue(property Descriptor.getId()));
        cellEditor.activate();
        Control control = cellEditor.getControl(); if (control == null) {
            cellEditor.deactivate();
            cellEditor = null;
            return;
        //BUGBUG. Temporary workaround...underlying problem is that only
        // the text portion of the label is being overwritten during
        editing, // so this workaround simply blots out the existing
        image. item.setImage(1, null);
        cellEditor.addListener(activeEditorListener);
        CellEditor.LayoutData layoutData = cellEditor.getLayoutData();
        tableEditor.horizontalAlignment = layoutData.horizontalAlignment;
        tableEditor.grabHorizontal = layoutData.grabHorizontal;
        tableEditor.minimumWidth = layoutData.minimumWidth;
        tableEditor.setEditor(control, item, 1);
        cellEditor.setFocus();
     * Applies the value of the currently editing item to the *
    private void applyEditorValue() {
        TableItem item = tableEditor.getItem(); if (item == null ||
        item.isDisposed()) {
            return;
        item.getData(); Object oldValue =
         propertySource.getPropertyValue(propertyDescriptor.getId());
        Object newValue = cellEditor.getValue(); if (oldValue != newValue
        && (oldValue == null || !oldValue.equals(newValue))) {
            propertySource.setPropertyValue(propertyDescriptor.getId(),
            newValue);
     * Deactivates the active editor.
    private void deactivateCellEditor() {
        tableEditor.setEditor(null, null, 1); if (cellEditor != null) {
            cellEditor.removeListener(activeEditorListener); cellEditor =
            null;
        if (item != null && !item.isDisposed()) {
            updateItem(item);
     * Handles the selection of an item within the table. * * @param item
     The newly selected item. */
    private void processSelection(TableItem item) {
            applyEditorValue();
        activateCellEditor(item);
     * Sets the <code>IPropertySource</code> from which property data is *
     pulled.
     * @param propertySource The new <code>IPropertySource</code>. */
    public void setPropertySource(IPropertySource propertySource) {
        this.propertySource = propertySource; updateProperties();
     * Updates the value of a single <code>TableItem</code> to reflect the
     * updated state of its represented property. * * @param item The
     <code>TableItem</code> to update. */
    private void updateItem(TableItem item) {
        item.getData();
        ILabelProvider labelProvider =
        propertyDescriptor.getLabelProvider(); if (labelProvider == null)
        } else {
            Object propertyValue =
            item.setText(0, propertyDescriptor.getDisplayName()); if
            (propertyValue != null) {
                item.setText(1, labelProvider.getText(propertyValue));
                item.setImage(1, labelProvider.getImage(propertyValue));
     * Updates all properties.
    private void updateProperties() {
        applyEditorValue();
        table.removeAll();
        if (propertySource != null) {
            IPropertyDescriptor[] propertyDescriptors =
            propertySource.getPropertyDescriptors(); for (int index = 0;
            index < propertyDescriptors.length; ++index) {
                TableItem item = new TableItem(table, SWT.NONE);
                item.setData(propertyDescriptors[index]);
                updateItem(item);
> to have the TableTree complication), and after much work, and several
> costly and failed attempts to reuse PropertySheet-code, we simply wrote
> our own, from the TableViewer up. The biggest, and still present, pain
> is dealing with the cell-editors, since TableViewer assumes that a given
> column of the Table will only have ONE (1) type of cell-editor ever, but
> the essence of a PropertyViewer is to have different types of properties
> (boolean, text, enumeration) in the same Viewer.
> best of luck!
> Paul
> Tod Liebeck wrote:
>> Hi all,
>> a PropertySheetViewer directly into an editor.  Simply using the
>> Properties View is not an option, as this control must reside inside of
>> a Composite within my editor.
>> PropertySheetViewer has package-protected (default) visibility, so it's
>> obviously not an option to use it directly.
>> Best regards
>> --Tod Liebeck
 Current Time: Mon Nov 03 22:06:21 EST 2025
 Powered by  FUDForum. Page generated in 0.03708 seconds
