Home » Language IDEs » ServerTools (WTP) » Programming "style" question.
Programming "style" question. [message #191260] |
Tue, 10 April 2007 08:44  |
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
When I use the Eclipse "New servlet" wizard to create a new servlet
template, and end up not using some of the methods (Delete and Put,
mostly), is it considered good form to delete those stubs from my code,
or leave them stubbed, as they were originally created in the file?
Dave
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Programming "style" question. [message #191268 is a reply to message #191260] |
Tue, 10 April 2007 18:24   |
I don't have WTP active at the moment so I can't try, but I'm assuming
the generated class extends HttpServlet. If you look a the
implementations of doDelete() and doPut() in HttpServlet, you'll see
that they just return HTTP error codes in response. So if you remove the
stubs from your servlet class, those implementations will be used
instead. If you leave the stubs empty, clients that attempt DELETE or
PUT will get no response at all. It's up to you, but I never have any
implementation of those methods (ie, let the default impl in HttpServlet
handle them).
Hope this helps,
Eric
Re: Programming "style" question. [message #191303 is a reply to message #191268] |
Wed, 11 April 2007 08:05   |
The code for these methods just calls super.doWhatever, like:
protected void doDelete(HttpServletRequest request, HttpServletResponse
response) throws ServletException, IOException {
// TODO Auto-generated method stub
super.doDelete(request, response);
So I'm guessing it's safe to delete them, but I was just wondering what
most people do. I'm all for minimizing the code in my apps, if for no
other reason than reducing the attack surface, and reducing class size
and memory usage.
In article <evh2ra$8bl$3@build.eclipse.org>, eclipse5@rizzoweb.com
says...
> handle them).
> Hope this helps,
> Eric
Re: Programming "style" question. [message #191351 is a reply to message #191303] |
Wed, 11 April 2007 13:53  |
> and memory usage.
Yes, it is safe and advisable (useless code in a class just clutters it
and makes it harder to read) to remove them.
By the way, having the stubs will increase the .class file size
(although insignificantly, perhaps a few bytes) but has no affect on the
"attack surface" or memory usage of the code.
Hope this helps,
Eric
Current Time: Sat Jul 19 02:26:53 EDT 2025
Powered by FUDForum. Page generated in 0.24316 seconds
