Home » Language IDEs » ServerTools (WTP) » Web Service pure java client
Web Service pure java client [message #190532] Wed, 28 March 2007 06:03 Go to next message
Originally posted by: ouri.poupko.gmail.com
I would like to use a web service as a client in a simple java
application. I tried using the Web Service Client wizard but it requires a
server like Tomcat to be installed. Can I create a client that does not
rely on any server and can be simply called from a simple java application?
Ouri.
Re: Web Service pure java client [message #190555 is a reply to message #190532] Wed, 28 March 2007 11:11 Go to previous messageGo to next message
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Ouri,
I think the server is only required for running the wizard, but you won't need
it for running your application.
Hope this helps
Wolfgang
Ouri wrote:
> a server like Tomcat to be installed. Can I create a client that does
> not rely on any server and can be simply called from a simple java
> application?
> Ouri.
Re: Web Service pure java client [message #190663 is a reply to message #190555] Thu, 29 March 2007 03:50 Go to previous messageGo to next message
Thanks Wolfgang.
I managed to verify this on a computer that is not behind a firewall. This
convinced me that my original client does not work because of firewall
proxy settings.
I read somewhere that the proxy needs to be defined for the JRE that my
client is using. I tried this in two ways:
1- through "control panel" -> Java -> Open -> General -> "network
settings"
2- through eclipse -> run -> environment (adding http.proxyHost and
http.proxyPort)
Both ways did not help.
Does anyone know how to define proxy settings for java applications
running in eclipse?
Ouri.
Re: Web Service pure java client [message #191127 is a reply to message #190555] Thu, 05 April 2007 08:56 Go to previous message
This is a multipart message in MIME format.
--=_alternative 00470C60852572B4_=
Content-Type: text/plain; charset="US-ASCII"
Ouri,
if you are creating an Apache Axis 1.3 client, then you do not even need
to have Tomcat installed. The Web Service Client wizard supports
generating Axis code into a plain Java project with no installed servers
present. I double checked this using WTP 1.5.3. Note that the story may
differ if using other Web service runtimes.
Thanks - CB.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Ouri,</font>
<br><font size=2 face="sans-serif">if you are creating an Apache Axis 1.3
client, then you do not even need to have Tomcat installed. The Web Service
Client wizard supports generating Axis code into a plain Java project with
no installed servers present. I double checked this using WTP 1.5.3. Note
that the story may differ if using other Web service runtimes.</font>
<br>
<br><font size=2 face="sans-serif">Thanks - CB.</font>
--=_alternative 00470C60852572B4_=--
Previous Topic:[Plugin Dev]Get source folder of the Dynamic Web Project
Next Topic:HTTP or SOAP protocol for Port
Current Time: Sun Jul 27 16:18:22 EDT 2025
Powered by FUDForum. Page generated in 0.02644 seconds
