Home » Newcomers » Newcomers » Problem with Eclipse in Linux.
Problem with Eclipse in Linux. [message #191033] Wed, 31 January 2007 09:15 Go to next message
Originally posted by: smieci79.o2.pl
I am developing simple java gui project.
The problem i am having is that after starting eclipse i can run the
project but after couple times i am getting error:
Exception occurred executing command line.
Don't know what to do??
How I get what kind of exception is this?
Problem is in eclipse or in system . It happens in different projects so
it is not matter of project.
Re: Problem with Eclipse in Linux. [message #191043 is a reply to message #191033] Wed, 31 January 2007 09:25 Go to previous messageGo to next message
Hi Krzysztof,
Could you look if there are any new entries in .log file in .metadata
folder of your eclipse after the error like that?
regards,
Jakub Jurkiewicz
Re: Problem with Eclipse in Linux. [message #191068 is a reply to message #191043] Wed, 31 January 2007 10:05 Go to previous messageGo to next message
I didn't know how to find log file. Thanks for this info.
After this error adds this to log:
!ENTRY org.eclipse.debug.core 4 120 2007-01-31 15:01:33.574
!MESSAGE Exception occurred executing command line.
!STACK 0
java.io.IOException: java.io.IOException: Cannot allocate memory
at java.lang.ConcreteProcess.<init> (libgcj.so.7)
at java.lang.Runtime.execInternal (libgcj.so.7)
at java.lang.Runtime.exec (libgcj.so.7)
at org.eclipse.debug.core.DebugPlugin.exec (DebugPlugin.java:744)
at org.eclipse.jdt.launching.AbstractVMRunner.exec
(AbstractVMRunner.java:70)
at org.eclipse.jdt.internal.launching.StandardVMRunner.run
(StandardVMRunner.java:241)
at org.eclipse.jdt.launching.JavaLaunchDelegate.launch
(JavaLaunchDelegate.java:104)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch
(LaunchConfiguration.java:639)
(LaunchConfiguration.java:565)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch
(DebugUIPlugin.java:754)
at org.eclipse.debug.internal.ui.DebugUIPlugin$6.run
(DebugUIPlugin.java:944)
at org.eclipse.core.internal.jobs.Worker.run (Worker.java:58)
Caused by: java.io.IOException: Cannot allocate memory
at java.lang.ConcreteProcess.nativeSpawn (libgcj.so.7)
at java.lang.ConcreteProcess.spawn (libgcj.so.7)
at java.lang.ConcreteProcess$ProcessManager.run (libgcj.so.7)
Re: Problem with Eclipse in Linux. [message #191090 is a reply to message #191068] Wed, 31 January 2007 10:44 Go to previous message
Originally posted by: eclipse5.rizzoweb.com
The stack trace below indicates that you are running Eclipse under GCJ,
which is not supported. you need to install the Sun JVM and then specify
to Eclipse to use that JVM.
There are many previous newsgroup threads that talk about how to specify
the VM for Eclipse to use, search for eclipse.ini in particular.
Hope this helps,
Eric
> !STACK 0
Previous Topic:How to activate emacs keybindings in dialogs
Next Topic:Redirect actions with a MultiPageEditorActionBarContributor
Current Time: Sun Jul 20 20:46:43 EDT 2025
Powered by FUDForum. Page generated in 0.05807 seconds
