Home » Eclipse Projects » GEF » self-referencing connections
self-referencing connections [message #190522] |
Thu, 04 August 2005 09:27  |
Originally posted by: christian.sell.netcologne.de
does GEF support self-referencing connections? I am currently experiencing
problems, in that self-referecing connections are displayed with the
outgoing end pointing into the free diagram space, instead of back to the
originating table.
Just wanted to ask before I delve into the GEF (and my own) codebase.
thanks,
christian
Re: self-referencing connections [message #190610 is a reply to message #190602] |
Thu, 04 August 2005 18:48   |
Pratik,
I have looked into the problem, and have found that the solution is more
in the reponsibility of the connection anchor. All I need to do is to
add special handling for the self-reference case in the getLocation(xx)
method and make sure the source and target anchors are positioned such
that the connection router will draw a nice line between them.
At least the ManhattanConnectionRouter does a rather nice job if,for
example, I place the source and target anchors at getBounds().getLeft()
and getBounds().getTop(), respectively.
There do however remain enough challenges in the connection
routing/anchoring field..
regards,
chris
Pratik Shah wrote:
> Regardless of your solution, you should open a feature request for better
> handling of self-referencing connections.
> "Christian Sell" <christian.sell@netcologne.de> wrote in message
> news:45e12a03a06aa040188f6003ca70e669$1@www.eclipse.org...
>>never mind. There is no problem with self-referencing connections as such.
>>However, the ManhattanConnectionRouter does a pretty bad job in
>>visualizing them. Does anyone have a better suggestion, or do I have to
>>roll my own?
>>thanks,
>>chris
Re: self-referencing connections [message #190684 is a reply to message #190610] |
Fri, 05 August 2005 12:03   |
Originally posted by: none.unknown.com
You can fix it that way, but I wouldn't say it's the ConnectionAnchor's
responsibility to avoid this case. Even if the start and endpoints are the
same exact point, the router should be able to show the connection in a
clear manner. Plus, I don't think anchors like ChopboxAnchor can do what
you suggest (at least not without violating some OO principles -- your
anchor probably does that too).
news:dcu60u$kvm$1@news.eclipse.org...
> Pratik,
> regards,
> chris
better
such.
> >>roll my own?
> >>thanks,
> >>chris
Re: self-referencing connections [message #190754 is a reply to message #190684] |
Fri, 05 August 2005 14:47   |
> clear manner.
well, it may be up to the router what to do in a case where start and
end are the same, but it is the the connection anchors that make (or
bear) the decision where start and end are located. In the case of a
self-referencing relationship, I would not want to have start and end at
the same point anyway, so IMO it is the connection anchors that have to
take action. My solution is this:
In method NodeEditPart#get[Source/Target]ConnectionAnchor() I can easily
determine whether this is a self-referencing connection by comparing the
parameter editpart with the editpart that receives the message:
public ConnectionAnchor getSourceConnectionAnchor(ConnectionEditPart c)
return new CustomChopboxAnchor(getFigure(), connection.getTarget()
== this);
Note that there is no complex coordinate computation needed. My
CustomChopboxAnchor only specifically handles the self-reference case
(in method getLocation()), by placing the connection source at the top
center and the connection target at the right. All other cases are
passed to the inherited implementation. That way, self-referencing
connections go around the top right corner of the figure.
I dont see how this violates OO principles, or even how the Router could
do a better job at this. Again, it is the routers job to determine the
path between 2 points, but it is the anchors job to set the points. My
problem is (was) about the points, not the route.
I still need to figure out a way to handle multiple self-references, by
spreading out their connections. I could use help from the router here,
because at least the ManhattanRouter draws connections that have the
same source and target points so close to eachother that they are hardly
distinguishable.
My feeling is that this subject of routing/anchoring still bears a good
number of challenges, at least for my use case.
Christian
>>Pratik,
>>regards,
>>chris
> better
> such.
>>>>roll my own?
>>>>thanks,
>>>>chris
Re: self-referencing connections [message #190872 is a reply to message #190754] |
Sat, 06 August 2005 16:10   |
news:dd0c9v$sfd$1@news.eclipse.org...
the
> > clear manner.
> == this);
Fair enough. I suspected you might be having the anchor somehow determine
whether the connection is self-referencing, but your solution sounds fine.
However, I still think the router would be a better place to fix this
because then you wouldn't need multiple chopbox anchors for the same
editpart. Plus, the router would fix this in an anchor-independent manner.
Also, it would be able to handle the case where the start and end locations
were the same exact point.
> distinguishable.
> Christian
> >>Pratik,
> >>regards,
> >>chris
> > better
> > such.
to
> >>>>roll my own?
> >>>>thanks,
> >>>>chris
Re: self-referencing connections [message #190908 is a reply to message #190872] |
Sat, 06 August 2005 18:02   |
well, if I look at org.eclipse.gef.examples.flow.parts.BottomAnchor,
line 34, it looks to me like it is doing just what you mention
(determining a self-reference). I did it that way at first, but then
switched to my solution.
As I see it, I will always need separate anchors for self-references, as
I want to have them show up around the top-right corner of the figure.
Also, the ChopboxAnchor is unusable in such a context, as it uses an
outside reference point to compute the direction of the connection -
which is meaningless in the case of a self-reference.
It would, of course, be good if the router also took care of
self-references and of the special case where start and end location are
identical, e.g. by avoiding the figure area. But IMO this is a feature
of each individual router implementation - it is not prescribed by the
ConnectionRouter interface. Every router may handle it completely
differently.
I am open to further directions. I am looking for a router with
orthogonal, moveable segments. If I dont find a one, I may have to
tackle that issue anyway.
regards,
christian
Re: self-referencing connections [message #191115 is a reply to message #190908] |
Mon, 08 August 2005 15:47  |
> well, if I look at org.eclipse.gef.examples.flow.parts.BottomAnchor, line
> 34, it looks to me like it is doing just what you mention (determining a
> self-reference). I did it that way at first, but then switched to my
> solution.
My guess is that it looks to see if it is connected to something inside
itself like a child. Your solution sounds fine and it's one of the reasons
why we haven't had to actually handle self-connection in a robust way ...
yet.
Current Time: Wed Sep 17 03:53:39 EDT 2025
Powered by FUDForum. Page generated in 0.33745 seconds
