Home » Newcomers » Newcomers » Change font size in Java (source code) editor ?
Change font size in Java (source code) editor ? [message #190590] Mon, 29 January 2007 13:31 Go to next message
Can the size of the font used in the Java source code editor be changed?
If yes, how?
Charlie
Re: Change font size in Java (source code) editor ? [message #190616 is a reply to message #190590] Mon, 29 January 2007 13:38 Go to previous messageGo to next message
Originally posted by: wayne.beaton._NOSPAM_eclipse.org
> If yes, how?
> Thanks
> Charlie
Window > Preferences > General > Appearance > Colors and Fonts > Java >
Java Editor Text Font
HTH,
Wayne
Re: Change font size in Java (source code) editor ? [message #190621 is a reply to message #190616] Mon, 29 January 2007 13:50 Go to previous messageGo to next message
Hi Wayne,
Worked perfectly.
Charlie
Wayne Beaton wrote:
>> If yes, how?
>> Thanks
>> Charlie
> HTH,
> Wayne
Re: Change font size in Java (source code) editor ? [message #190782 is a reply to message #190621] Tue, 30 January 2007 09:31 Go to previous messageGo to next message
> Wayne Beaton wrote:
>>> If yes, how?
>>> Thanks
>>> Charlie
is there a way to change all the fonts? In particular I'd like them to
be smaller (e.g., in linux fonts are much bigger than in windows).
Lorenzo Bettini, PhD in Computer Science, DSI, Univ. di Firenze
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Change font size in Java (source code) editor ? [message #190843 is a reply to message #190782] Tue, 30 January 2007 13:05 Go to previous messageGo to next message
Originally posted by: jacekp.siat.pl
Hi!
most of the fonts used in eclipse user interface are taken from OS. In
linux this means, you can change all fonts by modifying gtk
configuration. Search the internet for .gtkrc, it's quite often topic.
cheers
Jacek
Lorenzo Bettini napisał(a):
>> Wayne Beaton wrote:
>>>> changed?
>>>> If yes, how?
>>>> Thanks
>>>> Charlie
Re: Change font size in Java (source code) editor ? [message #190875 is a reply to message #190843] Tue, 30 January 2007 13:38 Go to previous messageGo to next message
Hi Jacek,
Thanks for your reply.
The reply that Wayne Beaton posted to my question yesterday, solved the
problem for me.
Charlie
Jacek Pospychala wrote:
> Hi!
> cheers
> Jacek
>>> Wayne Beaton wrote:
>>>>> changed?
>>>>> If yes, how?
>>>>> Thanks
>>>>> Charlie
>>>> Java > Java Editor Text Font
>> to be smaller (e.g., in linux fonts are much bigger than in windows).
Re: Change font size in Java (source code) editor ? [message #190968 is a reply to message #190843] Wed, 31 January 2007 08:14 Go to previous messageGo to next message
> Hi!
> cheers
> Jacek
>>> Wayne Beaton wrote:
>>>>> changed?
>>>>> If yes, how?
>>>>> Thanks
>>>>> Charlie
I'm using kde and not gnome, and I don't have such a file...
so it's not possible to change the overall font size from eclipse?
Re: Change font size in Java (source code) editor ? [message #190985 is a reply to message #190968] Wed, 31 January 2007 08:29 Go to previous messageGo to next message
>> Hi!
>> cheers
>> Jacek
>>>> Wayne Beaton wrote:
>>>>>> changed?
>>>>>> If yes, how?
>>>>>> Thanks
>>>>>> Charlie
Eclipse is compiled with gtk, so it requires gtk libs to run. That
doesn't mean you should switch to gnome :)
Essentially work that you have to do is to find, where the .gtkrc file
should be located and what should be inside.
Have a look at here, for similar problem, but with buttons:
http://ubuntuforums.org/archive/index.php/t-16083.html
And here an example gtkrc file:
http://dev.eclipse.org/newslists/news.eclipse.tools/msg37977 .html
let me know if you have any further questions
Jacek
Re: Change font size in Java (source code) editor ? [message #191076 is a reply to message #190968] Wed, 31 January 2007 10:25 Go to previous messageGo to next message
Hi Lorenzo,
What happens when you change Preferences as described below:
>> Hi!
>> cheers
>> Jacek
>>>> Wayne Beaton wrote:
>>>>>> changed?
>>>>>> If yes, how?
>>>>>> Thanks
>>>>>> Charlie
Re: Change font size in Java (source code) editor ? [message #191294 is a reply to message #191076] Thu, 01 February 2007 06:14 Go to previous message
Charle Kelly wrote:
> Hi Lorenzo,
it only changes the size of the font of the text editor...
Previous Topic:Update manager keeps prompting even though update installed
Next Topic:TPTP automated GUI testing for SWING applications
Current Time: Tue Oct 21 22:23:51 EDT 2025
Powered by FUDForum. Page generated in 0.11542 seconds
