Home » Language IDEs » ServerTools (WTP) » JSP save causes re-deployment and restart
JSP save causes re-deployment and restart [message #190152] |
Tue, 20 March 2007 07:12  |
it'd be great if somebody could help me to understand what's going on
here...
I have a fairly large dynamic web project featuring some JSPs, a large
Java code base and lots of support libraries. The problem is, when I save
a JSP page WTP thinks it has to trigger a complete rebuild, republish and
server restart. Naturally this takes ages (and my box is fast).
I'm using Eclipse 3.2.2, WTP 1.5.3 and Tomcat 4.1.
When I took up development a few weeks ago I used Exadel Studio Pro which
worked fine. JSP saving caused immediate replacement of the page only -
all happiness. Suddenly the behaviour changed; I'm not quite sure but it
may be after I added Struts support (from the Exadel plugin). Since then
I've tried the following:
- Uninstalled and re-installed the Exadel plugin
- Removed Struts support
- Removed the project from the server and added it again
- Deleted the server runtime and configured it again; deleted temp0
directories and publish.xml files several times
- Switched to another workspace and re-configured from scratch
- Re-installed Eclipse and used a new, clean workspace
- Got rid of the Exadel plugin and installed WTP 1.5.3 directly
- Starting Eclipse with and without option "-clean"
- Changed global preference settings and validation/builder settings in
the project preferences; disabled all validators
... all to no avail.
I have a separate test project with only one test JSP; even saving this
page restarts and republishes the other project (the big one) if the test
project is registered with the same server.
Maybe somebody can tell me what's going on behind the curtains. WTP seems
to have become confused somewhere, but I don't know where to look further.
I have taken a look at the config files but these are not
self-documenting. If you know the rules for the project rebuild, please
let me know where to look; I don't mind looking at the source code if I
only knew where to start.
This issue has been described previously in this group but nobody took the
trouble to reply. Sorry for posting it again - I'd be grateful for your
advice.
Thanks & regards, Leo
Re: JSP save causes re-deployment and restart [message #190168 is a reply to message #190152] |
Tue, 20 March 2007 09:40   |
The problem is that is that no one really knows exactly what's "special"
about your Eclipse setup and workspace that's leading to this behavior.
I'm afraid I don't have any good guesses. If you are willing, I would
recommended installing or upgrading to the JST SDK to get source for the
org.eclipse.jst.server.tomcat.core plug-in, if you don't have the SDK
already. You could then create a new workspace and import this plug-in.
The next step would be to run that plug-in in a debug session and
under that debug session's workspace, import your project and see if you
can duplicate the problem. If so I can help with debugging to see if
more than just the changed JSP is being copied during the publish.
Maybe what is being published will provide a clue as to who's making
changes beyond the saved JSP. My only shot in the dark is that it
sounds like some builder in your project is making changes, perhaps
unnecessarily, that is triggering this behavior.
Larry
Leo wrote:
> Hello,
> here...
> save a JSP page WTP thinks it has to trigger a complete rebuild,
> republish and server restart. Naturally this takes ages (and my box is
> fast).
> which worked fine. JSP saving caused immediate replacement of the page
> only - all happiness. Suddenly the behaviour changed; I'm not quite sure
> but it may be after I added Struts support (from the Exadel plugin).
> Since then I've tried the following:
> .. all to no avail.
> test project is registered with the same server.
> seems to have become confused somewhere, but I don't know where to look
> further. I have taken a look at the config files but these are not
> the trouble to reply. Sorry for posting it again - I'd be grateful for
> your advice.
Re: JSP save causes re-deployment and restart [message #190177 is a reply to message #190168] |
Tue, 20 March 2007 11:35   |
Hi Larry,
thanks for your help. I appreciate that you take the problem seriously.
"Larry Isaacs" <Larry.Isaacs@sas.com> schrieb im Newsbeitrag
news:etoo8d$hgn$1@utils.eclipse.org...
Yes. I know that the matter is complicated, and that I can't expect
definitive answers. I'm also willing to put some more effort into this.
> The next step would be to run that plug-in in a debug session and under
> that debug session's workspace, import your project and see if you can
> duplicate the problem. If so I can help with debugging to see if more
> than just the changed JSP is being copied during the publish. Maybe what
> is being published will provide a clue as to who's making changes beyond
> the saved JSP. My only shot in the dark is that it sounds like some
> builder in your project is making changes, perhaps unnecessarily, that is
The strange thing is: only the JSP is being replaced. I have checked the
timestamps of the files. Even more confusing (for me) is the fact that some
_folders_ below WEB-INF/classes have their "modified" timestamps changed to
the publish time - but none of the files within these folders are changed,
though Windows indicates that they have been accessed at publish time.
The publish.xml file gets a new timestamp, too. I have diffed two subsequent
versions of publish.xml. The only difference is the entry for the JSP.
It looks like something causes a WTP component to recursively traverse the
folder structure and modify the timestamps of the folders (or has this been
done by the OS?) while not touching the files at all (maybe it's doing a
comparison).
In my opinion there is nothing wrong with the publishing process at all -
the problem seems to be in the triggering logic.
There are three builders configured for the project: Java Builder, Faceted
Project Validation Builder, and Validation. I have disabled all of them and
still get the same behaviour. I have also suspended all validators, with no
improvement.
Thanks for your help offer. I will get the JST sources and try to debug
them; however, I foresee that it might be a rather lengthy undertaking ;-)
I'll post again here if I have more questions or answers.
Leo
> Cheers,
> Larry
> Leo wrote:
>> Hello,
>> here...
>> .. all to no avail.
>> your advice.
Re: JSP save causes re-deployment and restart [message #190188 is a reply to message #190177] |
Tue, 20 March 2007 12:11   |
If you don't already have the JST SDK, you can use the Update Manager to
get it from the Web Tools Platform Update site. Once you have the
SDK, use File -> Switch Workspace to create new workspace. After any
routine setup you do for your workspaces, select File -> Import ->
"Plug-in Development" -> "Plug-ins and Fragments" and click Next.
Change "Import as" to "Projects with source folders" and click Next.
Wait for the "Plug-ins and Fragments Found" list to fully populate, then
scroll down and double-click org.eclipse.jst.server.tomcat.core, then
click Finish. Ignore the "Discouraged Access" warnings that may appear
in the Problems view. Right-click on the new project and select "Debug
As" -> "Eclipse Application". It will start a debug session of Eclipse
using a workspace named "runtime-EclipseApplication" located as a
sibling of the workspace containing the tomcat plug-in. Getting to this
point is fairly simple. The trick now is to duplicate the problem in
this debug workspace. Once you get that point, post back and we'll
figure out the next step.
Larry
Leo Meyer wrote:
> Hi Larry,
> comparison).
> improvement.
> Regards,
> Leo
>> Cheers,
>> Larry
>> Leo wrote:
>>> Hello,
>>> here...
>>> .. all to no avail.
>>> your advice.
Re: JSP save causes re-deployment and restart [message #190195 is a reply to message #190188] |
Tue, 20 March 2007 12:22   |
Thanks for the instructions!
I'll post back.
Regards, Leo
news:etp134$lop$1@utils.eclipse.org...
> get it from the Web Tools Platform Update site. Once you have the SDK,
> use File -> Switch Workspace to create new workspace. After any routine
> setup you do for your workspaces, select File -> Import -> "Plug-in
> Development" -> "Plug-ins and Fragments" and click Next. Change "Import
> as" to "Projects with source folders" and click Next. Wait for the
> "Plug-ins and Fragments Found" list to fully populate, then scroll down
> and double-click org.eclipse.jst.server.tomcat.core, then click Finish.
> Ignore the "Discouraged Access" warnings that may appear in the Problems
> view. Right-click on the new project and select "Debug As" -> "Eclipse
> Application". It will start a debug session of Eclipse using a workspace
> named "runtime-EclipseApplication" located as a sibling of the workspace
> containing the tomcat plug-in. Getting to this point is fairly simple.
> The trick now is to duplicate the problem in this debug workspace. Once
> you get that point, post back and we'll figure out the next step.
> Cheers,
> Larry
> Leo Meyer wrote:
>> Hi Larry,
>> some _folders_ below WEB-INF/classes have their "modified" timestamps
>> changed to the publish time - but none of the files within these folders
>> are changed, though Windows indicates that they have been accessed at
>> publish time.
>> subsequent versions of publish.xml. The only difference is the entry for
>> the JSP.
>> the folder structure and modify the timestamps of the folders (or has
>> this been done by the OS?) while not touching the files at all (maybe
>> it's doing a comparison).
>> Faceted Project Validation Builder, and Validation. I have disabled all
>> of them and still get the same behaviour. I have also suspended all
>> validators, with no improvement.
>> Regards,
>> Leo
>>> Cheers,
>>> Larry
>>> Leo wrote:
>>>> Hello,
>>>> here...
>>>> fast).
>>>> sure but it may be after I added Struts support (from the Exadel
>>>> plugin). Since then I've tried the following:
>>>> .. all to no avail.
>>>> your advice.
Re: JSP save causes re-deployment and restart [message #190225 is a reply to message #190188] |
Wed, 21 March 2007 04:11   |
Hi Larry,
thanks for your excellent instructions. I have been able to set up the debug
workspace and I can reproduce the problem.
I have set the "Restart server when necessary" preference to on. Just for
clarity, here's the behaviour again:
When I edit and save a JSP page the project is being rebuilt ("Building
workspace" appears for a moment in the task panel), though all builders and
validators are deactivated. The server is being stopped and restarted.
The expected behaviour is: Publish JSP page to the web content folder, and
nothing more.
I have been able to set a breakpoint in PublishTask.getTask(), and I'm now
trying to track down the problem.
I'll post back if I find out more.
Regards, Leo
> Cheers,
> Larry
> Leo Meyer wrote:
>> Hi Larry,
>> publish time.
>> the JSP.
>> Regards,
>> Leo
>>> Cheers,
>>> Larry
>>> Leo wrote:
>>>> Hello,
>>>> here...
>>>> fast).
>>>> .. all to no avail.
>>>> your advice.
Re: JSP save causes re-deployment and restart [message #190236 is a reply to message #190225] |
Wed, 21 March 2007 05:59   |
Hi Larry,
I have found out that the server restart is handled by the class
RestartServerJob in the package org.eclipse.wst.server.core.internal. I
can't say, however, how this job is put into the job pool.
I haven't found any references to it in the
org.eclipse.jst.server.tomcat.core plugin. Since the publish task seems to
be triggered by the RestartServerJob (via Server.restart()) I suspect that
nothing is wrong with the tomcat plugin but the fault is with the component
that places the RestartServerJob in the worker pool.
If possible, please point me to the location where the saving of JSPs is
handled. I suppose that the rub is there.
Many thanks for your help so far!
Regards, Leo
"Leo Meyer" <leomeyer@gmx.de> schrieb im Newsbeitrag
news:etqp77$nsh$1@utils.eclipse.org...
> Hi Larry,
> debug workspace and I can reproduce the problem.
> and validators are deactivated. The server is being stopped and restarted.
> nothing more.
> Regards, Leo
>> Cheers,
>> Larry
>> Leo Meyer wrote:
>>> Hi Larry,
>>>> "special" about your Eclipse setup and workspace that's leading to this
>>>> behavior.
>>>> the org.eclipse.jst.server.tomcat.core plug-in, if you don't have the
>>>> SDK already. You could then create a new workspace and import this
>>>> plug-in. The next step would be to run that plug-in in a debug session
>>>> and under that debug session's workspace, import your project and see
>>>> if you can duplicate the problem. If so I can help with debugging to
>>>> see if more than just the changed JSP is being copied during the
>>>> publish. Maybe what is being published will provide a clue as to who's
>>>> making changes beyond the saved JSP. My only shot in the dark is that
>>>> it sounds like some builder in your project is making changes, perhaps
>>> publish time.
>>> the JSP.
>>> all - the problem seems to be in the triggering logic.
>>> Regards,
>>> Leo
>>>> Cheers,
>>>> Larry
>>>> Leo wrote:
>>>>> Hello,
>>>>> here...
>>>>> fast).
>>>>> in the project preferences; disabled all validators
>>>>> .. all to no avail.
>>>>> this page restarts and republishes the other project (the big one) if
>>>>> the test project is registered with the same server.
>>>>> look further. I have taken a look at the config files but these are
>>>>> not self-documenting. If you know the rules for the project rebuild,
>>>>> please let me know where to look; I don't mind looking at the source
>>>>> code if I only knew where to start.
>>>>> your advice.
Re: JSP save causes re-deployment and restart [message #190264 is a reply to message #190236] |
Wed, 21 March 2007 08:42   |
You may want to import the org.eclipse.wst.server.core plug-in as well
since that is where a lot of the server infrastructure is found,
including RestartServerJob. Just to be sure, if you double-click the
Tomcat server in the Servers view to open the server editor, is the "Run
modules directly..." checkbox checked or unchecked? If checked, you
could put a breakpoint in the execute() method of PublishOperation2 to
step through exactly what is being published for a module. If the
checkbox is unchecked, the breakpoint would go in the publishModule()
method of TomcatServerBehavior.
Larry
Leo Meyer wrote:
> Hi Larry,
> Regards, Leo
>> Hi Larry,
>> nothing more.
>> Regards, Leo
>>> Cheers,
>>> Larry
>>> Leo Meyer wrote:
>>>> Hi Larry,
>>>>> behavior.
>>>> publish time.
>>>> the JSP.
>>>> Regards,
>>>> Leo
>>>>> Cheers,
>>>>> Larry
>>>>> Leo wrote:
>>>>>> Hello,
>>>>>> here...
>>>>>> fast).
>>>>>> .. all to no avail.
>>>>>> your advice.
Re: JSP save causes re-deployment and restart [message #190281 is a reply to message #190264] |
Wed, 21 March 2007 11:08   |
Hi Larry,
I have imported the plugin you suggested.
The "Run modules directly..." box is checked, so I debugged
PublishOperation2.execute().
Somewhere down the line there's an instruction:
IModuleResourceDelta[] delta = server.getPublishedResourceDelta(module);
After execution delta contains two elements: a ModuleFolder "WEB-INF" (!)
with sub-elements and my modified JSP file.
I have stepped through the code a bit and found the following:
publish.xml contains duplicate entries, e.g.:
<folder name="util" path="WEB-INF/classes/com/***/action/custom/***">
<file name="FieldNameFunction.class"
path="WEB-INF/classes/com/***/action/custom/***/util"
stamp="1174411121871"/>
stamp="1174410533354"/>
</folder>
The timestamp of the file FieldNameFunction.class in the build output folder
is 1174410533(xxx) (2007-03-20 18:08:53). The timestamp of the published
file is the same. This corresponds with the second entry.
The first timestamp (1174411121871) corresponds to the date "Tue Mar 20
18:18:41". I have closed the workbench, deleted the publish.xml file,
started up and published again. The duplicate entries were there again, with
the identical timestamp (Tue Mar 20 18:18:41).
There are many more duplicate entries, but all are below the com package
folder. Other top level folders are not affected.
Now I realize what happened. I had two versions of the compiled classes in
my project: one in the build/classes folder (which was set as the output
folder) and one in the folder WEB-INF/classes. The WEB-INF/classes folder
does not show up in the Package Explorer view, which is why I didn't realize
it was there. It shows up in the Navigator view, however. For some reason
the file list that goes into publish.xml contains entries for all of the
paths.
I don't know how I managed to get these two output folders. Maybe the
settings were changed when I added Struts support from the Exadel plugin.
At first I thought it was a bug in WTP but now I see that it was a curious
coincidence. Add my inexperience to it and you get those strange effects.
Still I suggest that WTP may be modified such that duplicate entries in
publish.xml are prohibited. Logically it makes no sense to have two sources
for the same target, and their presence may indicate that something is wrong
with the project configuration.
I will try to file a feature request. Many thanks for your help again!
Regards, Leo
news:etr984$qcb$1@utils.eclipse.org...
> since that is where a lot of the server infrastructure is found, including
> RestartServerJob. Just to be sure, if you double-click the Tomcat server
> in the Servers view to open the server editor, is the "Run modules
> directly..." checkbox checked or unchecked? If checked, you could put a
> breakpoint in the execute() method of PublishOperation2 to step through
> exactly what is being published for a module. If the checkbox is
> unchecked, the breakpoint would go in the publishModule() method of
> Cheers,
> Larry
> Leo Meyer wrote:
>> Hi Larry,
>> to be triggered by the RestartServerJob (via Server.restart()) I suspect
>> that nothing is wrong with the tomcat plugin but the fault is with the
>> component that places the RestartServerJob in the worker pool.
>> Regards, Leo
>>> Hi Larry,
>>> for clarity, here's the behaviour again:
>>> restarted.
>>> and nothing more.
>>> now trying to track down the problem.
>>> Regards, Leo
>>>> to get it from the Web Tools Platform Update site. Once you have the
>>>> then scroll down and double-click org.eclipse.jst.server.tomcat.core,
>>>> then click Finish. Ignore the "Discouraged Access" warnings that may
>>>> appear in the Problems view. Right-click on the new project and select
>>>> "Debug As" -> "Eclipse Application". It will start a debug session of
>>>> Eclipse using a workspace named "runtime-EclipseApplication" located as
>>>> a sibling of the workspace containing the tomcat plug-in. Getting to
>>>> this point is fairly simple. The trick now is to duplicate the problem
>>>> in this debug workspace. Once you get that point, post back and we'll
>>>> Cheers,
>>>> Larry
>>>> Leo Meyer wrote:
>>>>> Hi Larry,
>>>>> seriously.
>>>>>> this behavior.
>>>>> this.
>>>>>> would recommended installing or upgrading to the JST SDK to get
>>>>>> source for the org.eclipse.jst.server.tomcat.core plug-in, if you
>>>>>> don't have the SDK already. You could then create a new workspace
>>>>>> and import this plug-in. The next step would be to run that plug-in
>>>>>> in a debug session and under that debug session's workspace, import
>>>>>> your project and see if you can duplicate the problem. If so I can
>>>>>> help with debugging to see if more than just the changed JSP is being
>>>>>> copied during the publish. Maybe what is being published will provide
>>>>>> a clue as to who's making changes beyond the saved JSP. My only shot
>>>>>> in the dark is that it sounds like some builder in your project is
>>>>>> making changes, perhaps unnecessarily, that is triggering this
>>>>>> behavior.
>>>>> the timestamps of the files. Even more confusing (for me) is the fact
>>>>> that some _folders_ below WEB-INF/classes have their "modified"
>>>>> timestamps changed to the publish time - but none of the files within
>>>>> these folders are changed, though Windows indicates that they have
>>>>> for the JSP.
>>>>> all of them and still get the same behaviour. I have also suspended
>>>>> all validators, with no improvement.
>>>>> debug them; however, I foresee that it might be a rather lengthy
>>>>> undertaking ;-)
>>>>> Regards,
>>>>> Leo
>>>>>> Cheers,
>>>>>> Larry
>>>>>> Leo wrote:
>>>>>>> Hello,
>>>>>>> on here...
>>>>>>> large Java code base and lots of support libraries. The problem is,
>>>>>>> when I save a JSP page WTP thinks it has to trigger a complete
>>>>>>> rebuild, republish and server restart. Naturally this takes ages
>>>>>>> page only - all happiness. Suddenly the behaviour changed; I'm not
>>>>>>> quite sure but it may be after I added Struts support (from the
>>>>>>> Exadel plugin). Since then I've tried the following:
>>>>>>> .. all to no avail.
>>>>>>> if the test project is registered with the same server.
>>>>>>> took the trouble to reply. Sorry for posting it again - I'd be
>>>>>>> grateful for your advice.
Re: JSP save causes re-deployment and restart [message #190288 is a reply to message #190281] |
Wed, 21 March 2007 12:28   |
Good work! I'm glad you were able to find the cause. It's probably a
bug that publishing is silent about multiple files in a module being
copied to the same destination file. Please do file a report. Thanks.
Larry
Leo Meyer wrote:
> Hi Larry,
> </folder>
> paths.
> Regards, Leo
>> Cheers,
>> Larry
>> Leo Meyer wrote:
>>> Hi Larry,
>>> Regards, Leo
>>>> Hi Larry,
>>>> restarted.
>>>> and nothing more.
>>>> Regards, Leo
>>>>> Cheers,
>>>>> Larry
>>>>> Leo Meyer wrote:
>>>>>> Hi Larry,
>>>>>> seriously.
>>>>>>> this behavior.
>>>>>> this.
>>>>>>> behavior.
>>>>>> for the JSP.
>>>>>> undertaking ;-)
>>>>>> Regards,
>>>>>> Leo
>>>>>>> Cheers,
>>>>>>> Larry
>>>>>>> Leo wrote:
>>>>>>>> Hello,
>>>>>>>> on here...
>>>>>>>> .. all to no avail.
Re: JSP save causes re-deployment and restart [message #190334 is a reply to message #190288] |
Thu, 22 March 2007 05:28  |
Hi Larry,
the bug ID is 178586. Thanks for giving me a tutorial about how to debug
Eclipse plugins ;-)
Regards, Leo
news:etrmfu$m48$1@utils.eclipse.org...
> Good work! I'm glad you were able to find the cause. It's probably a bug
> that publishing is silent about multiple files in a module being copied to
> Cheers,
> Larry
> Leo Meyer wrote:
>> Hi Larry,
>> </folder>
>> folder is 1174410533(xxx) (2007-03-20 18:08:53). The timestamp of the
>> published file is the same. This corresponds with the second entry.
>> with the identical timestamp (Tue Mar 20 18:18:41).
>> in my project: one in the build/classes folder (which was set as the
>> output folder) and one in the folder WEB-INF/classes. The WEB-INF/classes
>> folder does not show up in the Package Explorer view, which is why I
>> didn't realize it was there. It shows up in the Navigator view, however.
>> For some reason the file list that goes into publish.xml contains entries
>> for all of the paths.
>> curious coincidence. Add my inexperience to it and you get those strange
>> effects.
>> sources for the same target, and their presence may indicate that
>> something is wrong with the project configuration.
>> Regards, Leo
>>> Cheers,
>>> Larry
>>> Leo Meyer wrote:
>>>> Hi Larry,
>>>> suspect that nothing is wrong with the tomcat plugin but the fault is
>>>> with the component that places the RestartServerJob in the worker pool.
>>>> is handled. I suppose that the rub is there.
>>>> Regards, Leo
>>>>> Hi Larry,
>>>>> ("Building workspace" appears for a moment in the task panel), though
>>>>> all builders and validators are deactivated. The server is being
>>>>> and nothing more.
>>>>> Regards, Leo
>>>>>> select "Debug As" -> "Eclipse Application". It will start a debug
>>>>>> session of Eclipse using a workspace named
>>>>>> simple. The trick now is to duplicate the problem in this debug
>>>>>> workspace. Once you get that point, post back and we'll figure out
>>>>>> the next step.
>>>>>> Cheers,
>>>>>> Larry
>>>>>> Leo Meyer wrote:
>>>>>>> Hi Larry,
>>>>>>> seriously.
>>>>>>>> this behavior.
>>>>>>> this.
>>>>>>>> being copied during the publish. Maybe what is being published will
>>>>>>>> provide a clue as to who's making changes beyond the saved JSP. My
>>>>>>>> only shot in the dark is that it sounds like some builder in your
>>>>>>> fact that some _folders_ below WEB-INF/classes have their "modified"
>>>>>>> within these folders are changed, though Windows indicates that they
>>>>>>> for the JSP.
>>>>>>> traverse the folder structure and modify the timestamps of the
>>>>>>> folders (or has this been done by the OS?) while not touching the
>>>>>>> files at all (maybe it's doing a comparison).
>>>>>>> undertaking ;-)
>>>>>>> Regards,
>>>>>>> Leo
>>>>>>>> Cheers,
>>>>>>>> Larry
>>>>>>>> Leo wrote:
>>>>>>>>> Hello,
>>>>>>>>> on here...
>>>>>>>>> is, when I save a JSP page WTP thinks it has to trigger a complete
>>>>>>>>> Pro which worked fine. JSP saving caused immediate replacement of
>>>>>>>>> the page only - all happiness. Suddenly the behaviour changed; I'm
>>>>>>>>> not quite sure but it may be after I added Struts support (from
>>>>>>>>> the Exadel plugin). Since then I've tried the following:
>>>>>>>>> temp0 directories and publish.xml files several times
>>>>>>>>> settings in the project preferences; disabled all validators
>>>>>>>>> .. all to no avail.
>>>>>>>>> WTP seems to have become confused somewhere, but I don't know
>>>>>>>>> where to look further. I have taken a look at the config files but
>>>>>>>>> these are not self-documenting. If you know the rules for the
>>>>>>>>> project rebuild, please let me know where to look; I don't mind
>>>>>>>>> looking at the source code if I only knew where to start.
Current Time: Wed Jul 23 18:13:15 EDT 2025
Powered by FUDForum. Page generated in 0.06798 seconds
