Home » Language IDEs » ServerTools (WTP) » WebLogic Server 9.0 starts; then mysteriously stops!
WebLogic Server 9.0 starts; then mysteriously stops! [message #189888] Thu, 15 March 2007 13:03 Go to next message
Originally posted by: eclipse.newsgroups.javafreelancer.net
hi all,
please, can anybody help me fix the problem i describe below?
i'm an intellij idea man myself. everything is just so easy and intuitive
with intellij. but i'm not fanatical about it; so i figured i would see
what life is like on the other side of the tracks ;¬)
i recently installed eclipse sdk 3.2.2 (eclipse-SDK-3.2.2-solaris-gtk.zip;
Build id: M200701212-1330) on my solars/sparc box; along with WST 1.5.3;
plus all the pre-reqs listed for wst here:
http://download.eclipse.org/webtools/downloads/drops/R1.5/R- 1.5.3-200702082048/
i already had bea weblogic server 9.0 installed on that box. so, i added a
"generic bea weblogic server v9.0" configuration to my first wtp j2ee
project. that server setup was configured with all the defaults (changing
drive letters, filename extensions, etc. where appropriate).
i created an ejb project; added it to the wls 9.0 server in eclipse's
server view, then clicked the server view's "start" button. i can see wls
9.0 starting up in the console. the console reports log entries as far as
this:
<Notice>...<Server state changed to STARTING>
then eclipse automatically switches focus to the server tab and i can see
"Stopping" | "Publishing"
i also see "Publishing to Generic" in the botton right hand corner of the
server tab.
then the console goes quiet for a few seconds. then i see the
"stopWebLogic.sh" script automatically appear in the console's title bar
looking in the server's filesystem logs, i can see more log entries that
appear after the above "<STARTING>" entry:
<Notice>... <Started WebLogic Admin Server "examplesServer" for domain
"wl_server" running in Development Mode>
<Notice>...<Server state changed to RUNNING>
<Notice>...<Server started in RUNNING mode>
<Warning>...<The URL pattern : /index.jsp has a pre-existing stub :
weblogic.servlet.jsp.JavelinxJSPStub@7c9625 - /index.jsp class:
'jsp_servlet.__index' . Hence the new stub :
weblogic.servlet.jsp.JavelinxJSPStub@16564b8 - /index.jsp class:
'jsp_servlet.__index' will be destroyed.>
<Info>...<75% of the total memory in the server is free>
<Info>...<Graceful shutdown of examplesServer was issued remotely from
127.0.0.1>
<Alert>...<Server shutdown has been requested by weblogic>
<Notice>...<Server state changed to SUSPENDING>
<Notice>...<Server state changed to ADMIN>
<Notice>...<Server state changed to SHUTTING_DOWN>
<Notice>...<Channel "Default" listening on 127.0.0.1:7001 was shutdown.>
<Notice>...<Channel "DefaultSecure" listening on 127.0.0.1:7002 was
shutdown.>
that's what i see in the actual filesystem logs. but in the eclipse
console view, this suddenly appears:
"Stopping Weblogic Server...
Initializing WebLogic Scripting Tool (WLST) ...
Welcome to WebLogic Server Administration Scripting Shell
Type help() for help on available commands
Connecting to weblogic server instance running at t3://localhost:7001 as
username weblogic ...
Problem invoking WLST - Traceback (innermost last):
File "<iostream>", line 1, in ?
File "<iostream>", line 11, in connect
WLSTException: 'Error occured while performing connect : Error getting
the initial context. There is no server running at t3://localhost:7001 Use
dumpStack() to view the full stacktrace'
Done"
please, help me figure out how to fix this? thanks in advance for your
help.
cheers,
sun_certified
Re: WebLogic Server 9.0 starts; then mysteriously stops! [message #189928 is a reply to message #189888] Thu, 15 March 2007 13:49 Go to previous messageGo to next message
hi again,
in case it helps, here are my configuration details, plus the eclipse
error log:
error log:
!SESSION 2007-03-15 12:51:32.293
eclipse.buildId=M20070212-1330
java.version=1.5.0_03
BootLoader constants: OS=solaris, ARCH=sparc, WS=gtk, NL=en_US
Command-line arguments: -data /development/projects -os solaris -ws gtk
-arch sparc -clean
!ENTRY org.eclipse.core.filesystem 1 1 2007-03-15 12:51:57.449
!MESSAGE Could not load library: liblocalfile_1_0_0.so. This library
provides platform-specific optimizations for certain file system
operations. This library is not present on all platforms, so this may not
be an error. The resources plug-in will safely fall back to using
java.io.File functionality.
!ENTRY org.eclipse.ui.browser 2 0 2007-03-15 13:09:49.457
!MESSAGE Internal browser is not available: No more handles [Unknown
Mozilla path (MOZILLA_FIVE_HOME not set)]
!SESSION 2007-03-15 13:14:53.098
Command-line arguments: -os solaris -ws gtk -arch sparc -clean
!ENTRY org.eclipse.core.filesystem 1 1 2007-03-15 13:15:28.606
!ENTRY org.eclipse.debug.core 4 120 2007-03-15 15:15:37.760
!MESSAGE Error logged from Debug Core:
!STACK 0
java.io.IOException: Stream closed
at java.io.BufferedInputStream.getBufIfOpen(BufferedInputStream .java:145)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:2 53)
at java.io.BufferedInputStream.read(BufferedInputStream.java:31 3)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:2 54)
at java.io.FilterInputStream.read(FilterInputStream.java:90)
at
org.eclipse.debug.internal.core.OutputStreamMonitor.read(Out putStreamMonitor.java:138)
at
org.eclipse.debug.internal.core.OutputStreamMonitor.access$1 (OutputStreamMonitor.java:128)
at
org.eclipse.debug.internal.core.OutputStreamMonitor$1.run(Ou tputStreamMonitor.java:194)
at java.lang.Thread.run(Thread.java:595)
!ENTRY org.eclipse.debug.core 4 120 2007-03-15 15:16:59.662
!STACK 0
java.io.IOException: Bad file number
at java.io.FileInputStream.available(Native Method)
at
java.lang.UNIXProcess$DeferredCloseInputStream.available(UNI XProcess.java:239)
at java.io.BufferedInputStream.read(BufferedInputStream.java:32 1)
at
at
at
!SESSION 2007-03-15 15:45:35.204
!ENTRY org.eclipse.core.filesystem 1 1 2007-03-15 15:46:03.451
!ENTRY org.eclipse.ant.ui 4 120 2007-03-15 16:22:29.541
!MESSAGE Error logged from Ant UI:
!STACK 0
java.net.SocketTimeoutException: Accept timed out
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(PlainSocketImpl.java:384)
at java.net.ServerSocket.implAccept(ServerSocket.java:450)
at java.net.ServerSocket.accept(ServerSocket.java:421)
at
org.eclipse.ant.internal.ui.launchConfigurations.RemoteAntBu ildListener$ServerConnection.run(RemoteAntBuildListener.java :95)
!ENTRY org.eclipse.ant.ui 4 120 2007-03-15 16:23:14.944
!STACK 0
at
!ENTRY org.eclipse.debug.core 4 120 2007-03-15 16:23:52.703
!STACK 0
at
at
at
*** Date: Thu Mar 15 17:43:29 GMT 2007
*** Platform Details:
*** System properties:
eclipse.commands=-os
solaris
-ws
gtk
-arch
sparc
-launcher
/development/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
2bc
-clean
-vm
/development/bea/jdk150_03/jre/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1173973535204
eclipse.vm=/development/bea/jdk150_03/jre/bin/java
eclipse.vmargs=-Xmx1024M
-jar
/development/eclipse/startup.jar
eof=eof
file.encoding=ISO8859-1
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/development/eclipse/startup.jar
java.class.version=49.0
java.endorsed.dirs=/development/bea/jdk150_03/jre/lib/endors ed
java.ext.dirs=/development/bea/jdk150_03/jre/lib/ext
java.home=/development/bea/jdk150_03/jre
java.io.tmpdir=/var/tmp/
java.library.path=/development/bea/jdk150_03/jre/lib/sparc/c lient:/development/bea/jdk150_03/jre/lib/sparc:/development/ bea/jdk150_03/jre/../lib/sparc:/u01/app/oracle/product/9.2.0 .1.0/lib32:/usr/lib
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_03-b07
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_03-b07
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=SunOS
org.osgi.framework.os.version=5.9
org.osgi.framework.processor=sparc
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=sparc
os.name=SunOS
os.version=5.9
osgi.arch=sparc
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/development/eclipse/configuration/org.ecli pse.osgi/bundles
osgi.clean=true
osgi.configuration.area=file:/development/eclipse/configurat ion/
osgi.framework=file:/development/eclipse/plugins/org.eclipse .osgi_3.2.2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/development/eclipse/
osgi.instance.area=file:/development/projects/
osgi.instance.area.default=file:/home/bebop/workspace/
osgi.logfile=/development/projects/.metadata/.log
osgi.manifest.cache=/development/eclipse/configuration/org.e clipse.osgi/manifests
osgi.nl=en_US
osgi.os=solaris
osgi.splashLocation=/development/eclipse/plugins/org.eclipse .platform_3.2.2.r322_v20070117b/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/development/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/development/bea/jdk150_03/jre/lib/rt.ja r:/development/bea/jdk150_03/jre/lib/i18n.jar:/development/b ea/jdk150_03/jre/lib/sunrsasign.jar:/development/bea/jdk150_ 03/jre/lib/jsse.jar:/development/bea/jdk150_03/jre/lib/jce.j ar:/development/bea/jdk150_03/jre/lib/charsets.jar:/developm ent/bea/jdk150_03/jre/classes
sun.boot.library.path=/development/bea/jdk150_03/jre/lib/spa rc
sun.cpu.endian=big
sun.cpu.isalist=sparcv9+vis sparcv9 sparcv8plus+vis sparcv8plus sparcv8
sparcv8-fsmuld sparcv7 sparc
sun.io.unicode.encoding=UnicodeBig
sun.jnu.encoding=ISO8859-1
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/dumpthis/eclipse-SDK-3.2.2
user.home=/home/bebop
user.language=en
user.name=bebop
user.timezone=GB
*** Features:
org.eclipse.cdt (3.1.2.200702150621) "Eclipse C/C++ Development Tools"
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.2.2.v200702131851) "Eclipse Modeling Framework
(EMF) Programmers Guide"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.2.1.v200702131851) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.2.1.v200702131851) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.source (2.2.2.v200702131851) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.2.2.v20070208) "Graphical Editing Framework
Developer Resources"
org.eclipse.gef.source (3.2.2.v20070208) "Graphical Editing Framework
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.3.v20070130_R----6zXJK-L2U8VZ) "Java EMF Model"
org.eclipse.jem.sdk (1.2.3.v20070130_R-G95EUlhcE39c_dh) "Java EMF Model
SDK"
org.eclipse.jem.source (1.2.3.v20070130_R----6zXJK-L2U8VZ) "Java EMF Model
Source"
org.eclipse.jst (1.5.3.v200701251935-kW-NqztJbMj98Vy) "J2EE Standard Tools
(JST)"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse Project
SDK"
org.eclipse.wst (1.5.3.v200701251935-X3Tn7ug44nfs8AE) "Web Standard Tools
(WST)"
org.eclipse.xsd (2.2.2.v200702131851) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.2.1.v200702131851) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.source (2.2.2.v200702131851) "XML Schema Infoset Model
(XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for Unicode
for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Active]
org.apache.axis (1.3.0.v200608161946) "Apache Axis 1.3.0" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in"
[Resolved]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200608161946) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Active]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Active]
[Resolved]
org.eclipse.cdt.core (3.1.2.200702150621) "C/C++ Development Tools Core"
[Resolved]
org.eclipse.cdt.core.solaris (3.1.2.200702150621) "C/C++ Development Tools
Core for Solaris" [Resolved]
org.eclipse.cdt.debug.core (3.1.2.200702150621) "C/C++ Development Tools
Debug Model" [Resolved]
org.eclipse.cdt.debug.mi.core (3.1.2.200702150621) "C/C++ Development
Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.2.200702150621) "C/C++ Development Tools
GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.2.200702150621) "C/C++ Development Tools
org.eclipse.cdt.doc.user (3.1.2.200702150621) "C/C++ Development User
Guide" [Resolved]
org.eclipse.cdt.launch (3.1.2.200702150621) "C/C++ Development Tools
Launching Support" [Resolved]
org.eclipse.cdt.make.core (3.1.2.200702150621) "C/C++ Standard make Build
Core" [Resolved]
org.eclipse.cdt.make.ui (3.1.2.200702150621) "C/C++ Standard make Build
UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.2.200702150621) "C/C++ Managed
Builder Core" [Resolved]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.2.200702150621) "GNU Managed
Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.2.200702150621) "C/C++ Managed
Builder UI" [Resolved]
org.eclipse.cdt.refactoring (3.1.2.200702150621) "C/C++ Refactoring"
[Resolved]
org.eclipse.cdt.ui (3.1.2.200702150621) "C/C++ Development Tools UI"
[Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems"
[Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.draw2d (3.2.2.v20070208) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.2.0.v20060626) "Draw2D Documentation"
[Resolved]
org.eclipse.emf (2.2.0.v200702131851) "Eclipse Modeling Framework (EMF)"
[Resolved]
org.eclipse.emf.ant (2.2.0.v200702131851) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.cheatsheets (2.2.0.v200702131851) "EMF Cheat Sheets"
[Resolved]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200702131851) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200702131851) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200702131851) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200702131851) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert
Support" [Resolved]
(EMF) Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.2.2.v200702131851) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore Change
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit Support"
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200702131851) "Sample Ecore Editor"
[Resolved]
(SDO)" [Resolved]
Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Editor" [Resolved]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.2.v200702131851) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.2.v200702131851) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.2.1.v200702131851) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export Support"
[Resolved]
org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import Support"
[Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore Importer"
[Resolved]
org.eclipse.emf.importer.java (2.2.1.v200702131851) "EMF Annotated Java
Importer" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200702131851) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200702131851) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851) "Ecore to
Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200702131851) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200702131851) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI"
[Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200702131851) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200702131851) "XSD to
(EMF) Source" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry
Support" [Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.2.0.v20060626) "Graphical Editing Framework
Documentation" [Resolved]
Developer Resources" [Resolved]
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp"
[Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Resolved]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Resolved]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development Tools
Launching Support" [Active]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.2.v20061027_M) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Resolved]
org.eclipse.jem.sdk (1.2.0.v20060918_M) "Java EMF Model SDK" [Resolved]
Source" [Resolved]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Active]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities"
[Active]
org.eclipse.jem.workbench (1.2.3.v20070130_R) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)"
[Resolved]
org.eclipse.jst.common.annotations.controller (1.1.1.v200609132124)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.1.v200609132124) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.1.v200609132124) "Annotations
UI Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.1.4.v200702021430) "Integration
Plug-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.1.0.v200608141517) "Project
Facet Core (Java Support)" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.203.v200609221649) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.1.1.v200609132124) "WTP EJB UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee (1.1.3.v200702071605) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.1.52.v200701241140) "J2EE Core Component"
[Active]
org.eclipse.jst.j2ee.doc.user (1.0.203.v200609182036) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.3.v200701241140) "EJB component Plug-in"
[Active]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.1.v200609140551) "EJB
Annotation Model Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.1.v200609140551) "EJB
Emitter Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.1.v200609070230) "EJB
Annotations Ui Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.1.v200609141515)
"Xdoclet Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.202.v200609150300) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.1.3.v200701241140) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.1.1.v200609132124) "WTP JCA UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.1.2.v200702021430) "J2EE Extensions
to Common Navigator" [Resolved]
org.eclipse.jst.j2ee.ui (1.1.2.v200702071605) "WTP J2EE UI Plug-in"
[Active]
org.eclipse.jst.j2ee.web (1.1.3.v200701242244) "Web Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice (1.1.3.v200612131540) "Web Service
Plug-in" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.1.2.v200610162137) "WTP Webservice
UI Plug-in" [Active]
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.1.v200609140551) "XDocletRuntime
Plug-in" [Resolved]
org.eclipse.jst.jsp.core (1.1.102.v200701252050) "Structured Source JSP
Model" [Resolved]
org.eclipse.jst.jsp.ui (1.1.100.v200608142042) "SSE JSP Source Editor"
[Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools infopops"
[Resolved]
org.eclipse.jst.server.core (1.0.105.v20070202b) "Java Server Support"
[Active]
org.eclipse.jst.server.generic.core (1.0.101.v200608301011) "Generic
Server Plugin" [Active]
org.eclipse.jst.server.generic.jboss (1.5.2.v200702030302) "JBoss Generic
server definitions" [Resolved]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS Generic
Server definitions" [Resolved]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200606130315) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.100.v200608221634) "Generic Server
Plugin UI" [Resolved]
org.eclipse.jst.server.generic.weblogic (1.5.1.v200609141504) "Weblogic
generic server definitions" [Resolved]
org.eclipse.jst.server.installable (1.5.2.v20061018) "Installable servers"
[Resolved]
org.eclipse.jst.server.tomcat.core (1.0.104.v20070202b) "Apache Tomcat
Support" [Resolved]
org.eclipse.jst.server.tomcat.ui (1.0.103.v20060906) "Apache Tomcat UI
Support" [Resolved]
org.eclipse.jst.server.ui (1.0.103.v20060809) "Java Server UI Support"
[Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.2.v200605040115) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.101.v200609140551) "WebSphere
org.eclipse.jst.servlet.ui (1.1.2.v200702021430) "WTP Servlet UI Plug-in"
[Resolved]
org.eclipse.jst.servlet.ui.infopop (1.0.201.v200606130315) "Servlet
infopop" [Resolved]
org.eclipse.jst.ws (1.0.103.v200701230512) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.103.v200701152245) "Web
service Axis Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.102.v200608301709) "Webservice
Axis Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.104.v200702061836) "Webservice
Axis Creation UI" [Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.201.v200605152241) "Web services Axis
UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.203.v200609221649) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.103.v200701241747) "Web Services
Consumption" [Resolved]
org.eclipse.jst.ws.consumption.infopop (1.0.202.v20070131) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.104.v200701301546) "Web Services
Consumption Graphical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.202.v200609221649) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200606130315) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.104.v200702021949) "Web Services
Creation Graphical User Interface" [Resolved]
org.eclipse.jst.ws.doc.user (1.0.203.v200609221649) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.201.v200605162034) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.100.v200608221651) "Web Services
Universal Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.101.v200608302120) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core"
[Resolved]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI"
[Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
Development User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment
Runtime" [Active]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.solaris.gtk.sparc
(3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.solaris.sparc (3.2.2.v3236) "Standard Widget Toolkit
for GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools"
[Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.2.R322_v20061214) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome"
[Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator
Workbench Components" [Active]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.workbench (3.2.2.M20070119-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.2.R32x_v20070111) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.3.R32x_v20070118) "Install/Update Core"
[Active]
org.eclipse.update.scheduler (3.2.2.R32x_v20061214) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.2.R32x_v20070111) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.103.v200702021949) "Environment Command
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.102.v200702021949) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.doc.user (1.5.0.v20060831345) "Web services
Axis Ant task documentation" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services
UI" [Resolved]
org.eclipse.wst.command.env.ui (1.0.102.v200608222020) "Environment
Command Framework (GUI)" [Resolved]
org.eclipse.wst.common.core (1.1.100.v200608220540) "WST Common Core
Plug-in" [Resolved]
org.eclipse.wst.common.emf (1.1.3.v200612061436) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.1.4.v200702021430) "EMF
Workbench Edit Plug-in" [Active]
org.eclipse.wst.common.environment (1.0.100.v200608251934) "Enviornment
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.1.3.v200702071605) "Common
Frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (1.1.2.v200702071605) "WTP UI
Plug-in" [Active]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST infopops"
[Resolved]
org.eclipse.wst.common.modulecore (1.1.52.v200701251700) "Modulecore
Plug-in" [Active]
org.eclipse.wst.common.project.facet.core (1.1.1.v200608112156) "Project
Facet Core" [Active]
org.eclipse.wst.common.project.facet.ui (1.1.2.v200701192142) "Project
Facet UI" [Active]
org.eclipse.wst.common.snippets (1.1.1.v200609140550) "Snippets View"
[Resolved]
org.eclipse.wst.common.ui (1.1.101.v200702021750) "Eclipse Base UI
extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.101.v200609140551) "Common
Properties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.1.101.v200702021717) "Common URI
Resolver Framework" [Active]
org.eclipse.wst.css.core (1.1.1.v200609140550) "Structured Source CSS
Model" [Resolved]
org.eclipse.wst.css.ui (1.0.101.v200609140550) "SSE CSS Source Editor"
[Resolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.203.v200608310305)
"Data documentation" [Resolved]
org.eclipse.wst.datatools.data.ui.doc.user (1.0.203.v200608310305) "Data
tools data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.203.v200608310305) "Data
org.eclipse.wst.datatools.server.ui.doc.user (1.0.203.v200608310305)
"Database Explorer documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.203.v200608231821) "Master User Doc TOC"
[Resolved]
org.eclipse.wst.dtd.core (1.1.1.v200609210600) "Structured Source DTD
Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.102.v200702021750) "SSE DTD Source Editor"
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor infopops"
[Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.203.v200609221649) "DTD Editor
org.eclipse.wst.html.core (1.1.2.v200612200820) "Structured Source HTML
Model" [Resolved]
org.eclipse.wst.html.standard.dtds (1.0.1.v200608220315) "Known DTDs"
[Resolved]
org.eclipse.wst.html.ui (1.0.102.v200702021750) "HTML UI Source Editor"
[Resolved]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor
infopops" [Resolved]
org.eclipse.wst.internet.cache (1.0.103.v200612070353) "Cache URI Resolver
Plug-in" [Resolved]
org.eclipse.wst.internet.monitor.core (1.0.103.v20060809) "Monitor"
[Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.103.v20060809) "TCP/IP Monitor"
[Resolved]
org.eclipse.wst.internet.proxy (1.0.101.v200702021949) "Internet Proxy
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet
Proxy Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.1.v200609140550) "Structured Source
JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.2.v200701250230) "SSE JavaScript Source
Editor" [Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.1.v200605040131) "Javascript
infopop" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.106.v200701032244) "RDB
Connection.ui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0.v200605040131) "New
Connection wizard infopops" [Resolved]
org.eclipse.wst.rdb.core (1.1.119.v200702062139) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.108.v200701032153) "Core UI plugin"
[Resolved]
org.eclipse.wst.rdb.data.core (1.0.107.v200612130213) "Data Core Plugin"
[Resolved]
org.eclipse.wst.rdb.data.ui (1.0.110.v200612130213) "Data UI Plugin"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.105.v200610161941) "DB2
UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.107.v200702021852) "DB2 UDB
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.104.v200610161905) "DB2
UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.104.v200610161905) "Derby
Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.generic.jdbc (1.0.101.v200605040131)
"DBDefinition Generic JDBC Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.104.v200610261819)
"Informix Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.101.v200610161905)
"DBDefinition Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.103.v200702062139) "Oracle
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.105.v200610161905) "SQL
Server Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.106.v200610261819) "Sybase
org.eclipse.wst.rdb.derby (1.0.106.v200612130213) "RDB Derby Plug-in"
[Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.103.v200612130213) "RDB Derby Ui
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.104.v200612130213) "FE UI Plug-in"
[Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.103.v200612130213) "FE Ui Actions
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200605040131) "Generate DDL
org.eclipse.wst.rdb.models.dbdefinition (1.0.103.v200702062139)
"DBDefinition Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.104.v200612130213) "SQLModel Plug-in"
[Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.103.v200612130213) "SQLModel Edit
Plug-in" [Resolved]
org.eclipse.wst.rdb.mysql (1.0.104.v200612130213) "RDB Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview (1.0.107.v200612130213) "Data Output
Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0.v200605040131) "Data Output
view infopops" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.105.v200612130213) "Server
Explorer Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.110.v200701242205) "Server Explorer
plugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200605040131) "Server
Explorer view infopops" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.106.v200612130213) "SQL Source Editor
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200605040131) "SQL infopops"
[Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.103.v200612130213) "Sqlscrapbook
Plug-in" [Resolved]
org.eclipse.wst.server.core (1.0.105.v20070202b) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.105.v20070124b) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.203.v200609221649) "Server Tools
documentation for Web Standard Tools" [Resolved]
org.eclipse.wst.server.ui.infopop (1.0.3.v200609140551) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sqleditor.doc.user (1.0.2.v200608310308) "SQL Editor
org.eclipse.wst.sse.core (1.1.101.v200611210021) "Structured Text Model"
[Active]
org.eclipse.wst.sse.doc.user (1.0.203.v200608300230) "Structured text
editor and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.202.v200701252330) "Structured Source Editor"
[Resolved]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops"
[Resolved]
org.eclipse.wst.validation (1.1.3.v200702021430) "Validation Framework"
[Active]
org.eclipse.wst.validation.infopop (1.0.201.v200606130645) "WST validation
infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.2.v200612061436) "Validation Framework
UI" [Resolved]
org.eclipse.wst.web (1.1.2.v200610182223) "Simple Web Plug-in" [Active]
org.eclipse.wst.web.ui (1.1.1.v200609132124) "Simple Web UI Plug-in"
[Active]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web
infopop" [Resolved]
org.eclipse.wst.webtools.doc.user (1.0.203.v200609221649) "Web tools
org.eclipse.wst.ws (1.0.102.v200702021949) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (1.0.104.v200701250524) "Web Services
Explorer" [Resolved]
org.eclipse.wst.ws.infopop (1.0.202.v20070131) "Web Services UI" [Resolved]
org.eclipse.wst.ws.parser (1.0.101.v200609062128) "Web Services
Description Parser" [Resolved]
org.eclipse.wst.ws.ui (1.0.102.v200702021555) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (1.0.103.v200702021033) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.1.101.v200702082034) "WSDL UI" [Resolved]
org.eclipse.wst.wsdl.ui.doc.user (1.0.203.v200609221649) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.1.101.v200701260245) "WSDL Validator"
[Resolved]
org.eclipse.wst.wsi (1.0.104.v200702021430) "WSI Conformance Tools"
[Resolved]
org.eclipse.wst.wsi.ui (1.0.101.v20060850312) "Soap Monitor" [Resolved]
org.eclipse.wst.wsi.ui.doc.user (1.0.202.v200609221649) "WS-I Validation
org.eclipse.wst.xml.core (1.1.100.v200702021717) "Structured Source XML
Model" [Active]
org.eclipse.wst.xml.ui (1.0.201.v200702021717) "XML UI Plugin" [Resolved]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200605040131) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.203.v200609221649) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.101.v200701312359) "XSD Core Plugin"
[Resolved]
org.eclipse.wst.xsd.ui (1.1.102.v200701312359) "XML Schema Editor"
[Resolved]
org.eclipse.wst.xsdeditor.doc.user (1.0.203.v200609221649) "XML schema
editor" [Resolved]
[Resolved]
org.eclipse.xsd.cheatsheets (2.2.0.v200702131851) "XML Schema Infoset
Model (XSD) Cheat Sheets" [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.1.v200702131851) "XML Schema Exporter
for EMF" [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200702131851) "XML Schema Importer
for EMF" [Resolved]
org.eclipse.xsd.edit (2.2.1.v200702131851) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200702131851) "XML Schema Editor" [Resolved]
(XSD) Source" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Resolved]
org.uddi4j (2.0.5.v200608231542) "UDDI4J 2.0.5" [Resolved]
org.wsdl4j (1.4.0.v200702061629) "WSDL4J 1.4" [Resolved]
system.bundle (3.2.2.R32x_v20070118) "OSGi System Bundle" [Active]
*** User Preferences:
#Thu Mar 15 17:43:29 GMT 2007
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/webdo clet.weblogic.destdir.include=true
@org.eclipse.debug.ui=3.2.2.r322_v20070202
/instance/org.eclipse.wst.server.core/module-start-timeout=3 00000
@org.eclipse.wst.internet.cache=1.0.103.v200612070353
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/webdo clet.weblogic.mergedir=${web.dd.dir}
/project/JST_EJB_Tutorial/org.eclipse.jdt.core/org.eclipse.j dt.core.compiler.source=1.5
/project/GettingThere/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.problem.enumIdentifier=warning
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1173838039746 "
defaultVMConnector\="">\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\n<vm
id\="1173838039746"
javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/" name\="jdk150_03"
path\="/development/bea/jdk150_03"/>\n</vmType>\n</vmSettings >\n
@org.eclipse.pde.core=3.2.1.v20060915-0800
@org.eclipse.cdt.ui=3.1.2.200702150621
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/ejbdo clet.weblogic.validatexml.include=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/webdo clet.weblogic.xmlencoding.include=true
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/webdo clet.weblogic.contextroot.include=true
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/XDOCL ETHOME=/development/xdoclet-1.2.3
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/ejbdo clet.weblogic.createtables.include=true
/project/GettingThere/org.eclipse.jst.common.project.facet.c ore/classpath.helper/org.eclipse.jdt.launching.JRE_CONTAINER \:\:org.eclipse.jdt.internal.debug.ui.launcher.StandardVMTyp e\:\:jdk150_03/owners=jst.java\:1.4
/instance/org.eclipse.pde.runtime/activate=true
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/XDOCL ETVERSION=1.2.3
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/ejbdo clet.weblogic.destdir.include=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.2.2.r322_v20070124
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.2.2.R32x_v20061218
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.pde.core/platform_path=/development/ec lipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.ant.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jst.j2ee.ejb.annotations.xdoclet/ejbdo clet.weblogic.databaseType=POINTBASE
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.ui.workbench=3.2.2.M20070119-0800
file_export_version=3.0
/project/GettingThere/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.codegen.targetPlatform=1.2
@org.eclipse.jdt.launching=3.2.2.r322_v20061114
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.pde.runtime=3.2.0.v20060605
/project/JST_EJB_Tutorial/org.eclipse.jst.common.project.fac et.core/classpath.helper/org.eclipse.jst.server.core.contain er\:\:org.eclipse.jst.server.generic.runtimeTarget\:\:Generi c\
BEA\ WebLogic\ Server\ v9.0/owners=jst.ejb\:2.1
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.cdt.managedbuilder.core/properties/lea rning_cpp.cdt.managedbuild.target.gnu.solaris.so.1853677413/ cdt.managedbuild.config.gnu.solaris.so.debug.2035133518=\#\n \#Thu
Mar 15 15\:38\:48 GMT
2007\ncdt.managedbuild.tool.gnu.solaris.c.compiler.so.debug. 1636237902\=\\\#\\n\\\#Thu
Mar 15 15\\\:38\\\:48 GMT
2007\\nrebuildState\\\=false\\n\ncdt.managedbuild.tool.gnu.s olaris.cpp.compiler.so.debug.1639100021\=\\\#\\n\\\#Thu
2007\\nrebuildState\\\=true\\n\ncdt.managedbuild.config.gnu. solaris.so.debug.2035133518\=\\\#\\n\\\#Thu
2007\\nrcState\\\=0\\nrebuildState\\\=false\\n\ncdt.managedb uild.tool.gnu.assembler.so.debug.1289302345\=\\\#\\n\\\#Thu
2007\\nrebuildState\\\=false\\n\ncdt.managedbuild.toolchain. gnu.solaris.so.debug.1745976250\=\\\#\\n\\\#Thu
2007\\nrebuildState\\\=false\\n\ncdt.managedbuild.tool.gnu.c .linker.so.debug.1605585142\=\\\#\\n\\\#Thu
2007\\nrebuildState\\\=true\\n\ncdt.managedbuild.tool.gnu.cp p.linker.so.debug.219664958\=\\\#\\n\\\#Thu
Mar 15 15\\\:38\\\:48 GMT 2007\\nrebuildState\\\=true\\n\n
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|ad obe-courier|12|0|GTK|1|;
/instance/org.eclipse.wst.server.core/runtimes=<?xml version\="1.0"
encoding\="UTF-8"?>\n<runtimes>\n<runtime id\="Generic BEA WebLogic Server
v9.0" location\="/development/bea/weblogic90/samples/domains/wl_server "
name\="Generic BEA WebLogic Server v9.0"
runtime-type-id\="org.eclipse.jst.server.generic.runtime.weblogic90 "
server_definition_id\="org.eclipse.jst.server.generic.runtime.weblogic90 "
timestamp\="5" vm-install-id\="1173838039746"
vm-install-type-id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\n<map
key\="generic_server_instance_properties"
serverRootDirectory\="/development/bea/weblogic90"/>\n</runtime >\n</runtimes>\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
@org.eclipse.wst.sse.ui=1.0.202.v200701252330
/project/GettingThere/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.problem.assertIdentifier=warning
Re: WebLogic Server 9.0 starts; then mysteriously stops! [message #192497 is a reply to message #189928] Tue, 15 May 2007 13:18 Go to previous message
mystery solved:
http://forums.bea.com/bea/thread.jspa?threadID=400003839& ;tstart=0&mod=1179179236840
thanks again, rob!
Previous Topic:HTTPS Vs Eclipse WTP Internal Web Browser
Next Topic:New Axis2 Web services tools in WTP 2.0
Current Time: Sat Jul 26 18:45:27 EDT 2025
Powered by FUDForum. Page generated in 0.07352 seconds
