Search word under cursor [message #189248] |
Wed, 04 February 2004 05:23  |
please bear with me when I ask this really basic question. I can't for my
life find an option to make the Eclipse Java editor to search the word
that currently contains the cursor without first selecting the word.
Please, can somebody tell me what I need to make this simple thing working?
I really hope the answer is not: "You always have to select the word to
search for it." I mean this is an absolute basic feature and supported in
every other editor with mouse support I ever used (and there were quite
some, I even wrote a few myself), so I cannot imagine this is intended.
Mike
www.delphi-gems.com
Re: Search word under cursor [message #189518 is a reply to message #189248] |
Wed, 04 February 2004 12:26   |
Originally posted by: eclipse-user.jibeinc.com
Mike Lischke wrote:
Couple of comments:
1) I am not familiar with the feature you describe. So I opened up
TextEdit and tried to find a way to place the cursor on a word and
search for it without selecting the word first - no can do. TextEdit is
a pretty popular editor, so I guess my point is that this does not seem
like such a common feature.
2) Is it a problem for you to simply double-click the word to select it
before doing a search? That seems like a very reasonable substitute for
the missing feature you're talking about.
3) If it is really important to you, then file a feature request in
Bugzilla and perhaps it will get implemented. Better yet, if you were so
inclined you could implement it yourself and submit the code as a patch
- working patches with tests seem to be readily incorporated by the
Eclipse development team.
HTH,
Eric
Eric Rizzo
Software Architect
Jibe, Inc.
http://www.jibeinc.com
Re: Search word under cursor [message #189872 is a reply to message #189518] |
Thu, 05 February 2004 04:24   |
Eric Rizzo wrote:
Thank you for your answer.
Well, well, the different worlds again. I never heard about TextEdit. I'm
usually working with editors like Delphi, MSVC, PHPEdit, UltraEdit, MS
Word etc. However, I realize MS Word does also not search for the word at
the cursor.
Right, this is what is implemented and I never thought about this feature
as it always worked where I needed it. But now that I don't have it I miss
it badly. I'm really surprised that nobody ever complained about that
(well, they might not know it). I mean, it's a big disadvantage to have to
use two hands to search for a word where it could be simple to implement
the needed feature. So yes, I have a problem with first selecting a word
before it can be searched.
Not a bad idea. I should do that.
I'm just a beginner with Java and Eclipse (otherwise I should already got
used to the kind search is performed ;-)). Currently I'm fighting with the
most basic things in Eclipse so I doubt I would be a real help in this
regard.
Mike
www.delphi-gems.com
Re: Search word under cursor [message #743026 is a reply to message #189518] |
Thu, 20 October 2011 23:58   |
It is a while since this thread was created, but I have to completely agree with Mike here. Not being able to instantly search for the word under the cursor is a big drag for me. In Vim/GVim, one can hit "#" or "*" to search up or down for the word under the cursor w/o typing in that word, or highlighting it with keyboard/mouse. Very fast, very powerful, you hate to loose it once you are used to it. I could live with a work around, and that would be that the word under the cursor could be pre-populated into the search window. That's equally annoying that you have to manually type in the word you want to find, or escape out of the find window, double-click the word you are after, and then bring up the search window again. A lot of programmers learn to ignore the mouse for 90% of what they do, so let's see some speed-ups in this reguard.
-David
FUDForum. Page generated in 0.08076 seconds
