Viewing post parameters during debugging [message #189773] |
Thu, 15 March 2007 02:35  |
I am using Eclipse and Tomcat 5.5 and would like to inspect the post
parameters in the request object during debugging. So far I found the
raw post data (as integers, not text) under postData.
Is there a place in the request object where I can see the parameters
the way they appear in the original HTTP request received from the
client or just a more friendly display (name=value or something like
that) instead of a series of integers?
If that is not possible, what is the most convenient way to get to those
parameters during debugging within Eclipse?
Shahim
Re: Viewing post parameters during debugging [message #190040 is a reply to message #190032] |
Fri, 16 March 2007 13:42   |
Now that I know where to look, I went back and tried to find out why my
search for a variable/object with the name "parameters" didn't show it.
It turned out that I must open an object at least once for the search
function to be able to find its children.
This didn't make much sense to me. If I am using a search function to
find something, it usually means that I don't know where it is. My be I
am using the wrong search method but the one in the variables view
doesn't seem very helpful.
Am I missing something?
Is there a better way to search the variables in the variables view
during debugging?
Shahim
Shahim wrote:
> That's what I was looking for. Thanks Larry
> I have not looked at the source yet and I'm still new to Eclipse. I need
> to learn more about how to use Eclipse effectively to navigate through
> large projects. I'm slowly getting there :-)
> Shahim
> Larry Isaacs wrote:
>> It probably wouldn't hurt download source for Tomcat and add source
>> directories to the Tomcat server's launch configuration. It is easy
>> to make incorrect assumptions about the Tomcat internals you are
>> looking at. I did a quick check and I believe the parameters object
>> you want is request:RequestFacade -> request:Request ->
>> coyoteRequest:Request -> parameters:Parameters. It appears the
>> parameterMap field is a location to store the result of a
>> request.getParameterMap() call. If getParameterMap() is not called,
>> parameterMap is not populated.
>> Cheers,
>> Larry
>> Shahim wrote:
>>> Larry Isaacs wrote:
>>>> I don't think Tomcat 5.5 will touch the post data in the request
>>>> until you ask for a parameter.
>>> Right, I did see that parametersParsed is initially false. It turns
>>> to true after the first read of a parameter.
>>>> Trying to get a parameter should trigger parsing of the post data
>>>> and you should be able to find it in a name=value map somewhere in
>>>> the request.
>>> This is where I am having a problem. I tried a simple form and posted
>>> to a servlet and in the debugging view I do see the parameters under
>>> parameterMap.
>>> When I try to find the same parameters in my real application they
>>> don't show up. All I see is a pair of curly braces in the details
>>> pane and the parametersParsed is true.
>>>> I'm afraid I don't remember the names of the objects involved off
>>>> the top of my head.
>>>> Cheers,
>>>> Larry
>>>>> post parameters in the request object during debugging. So far I
>>>>> found the raw post data (as integers, not text) under postData.
>>>>> parameters the way they appear in the original HTTP request
>>>>> received from the client or just a more friendly display
>>>>> (name=value or something like that) instead of a series of integers?
>>>>> those parameters during debugging within Eclipse?
>>>>> Thanks
>>>>> Shahim
Re: Viewing post parameters during debugging [message #190048 is a reply to message #190040] |
Fri, 16 March 2007 14:31   |
Do you mean "Find..." in the Variables view context menu? This one
isn't really a search. It allows you to specify a filter to limit the
list of currently displayed variables to make it easier to select one
when there is a whole bunch of variables. I'm not aware of a search
that searches into objects that are displayed in the variables view.
Larry
> during debugging?
> Shahim
>> need to learn more about how to use Eclipse effectively to navigate
>> through large projects. I'm slowly getting there :-)
>> Thanks,
>> Shahim
>>> Cheers,
>>> Larry
>>>>> the request.
>>>> posted to a servlet and in the debugging view I do see the
>>>> parameters under parameterMap.
>>>>> the top of my head.
>>>>> Cheers,
>>>>> Larry
>>>>>> Thanks
>>>>>> Shahim
Re: Viewing post parameters during debugging [message #190056 is a reply to message #190048] |
Fri, 16 March 2007 15:10  |
Yes, it looks like I misunderstood the use of Find. It also looks like
Find is really something between search and limit display because if I
collapse a node in the view the Find list still lists the objects that
are hidden. It lists all the variables that have been looked at, not
just the visible ones and it doesn't really limit the display, it just
takes you to that variable.
It would be nice to have a search feature.
Shahim
> This one
> Cheers,
> Larry
>> my search for a variable/object with the name "parameters" didn't show
>> it. It turned out that I must open an object at least once for the
>> search function to be able to find its children.
>> I am using the wrong search method but the one in the variables view
>> during debugging?
>> Shahim
>>> Thanks,
>>> Shahim
>>>> Cheers,
>>>> Larry
>>>>>> the request.
>>>>>> the top of my head.
>>>>>> Cheers,
>>>>>> Larry
>>>>>>> to those parameters during debugging within Eclipse?
>>>>>>> Thanks
>>>>>>> Shahim
FUDForum. Page generated in 0.25378 seconds
