| 1 Document with many reports [message #187500] | Mon, 28 August 2006 05:54  |  |
| Eclipse User  |  |  |  |  | Originally posted by: dm.sobacosoftware.com
 Hello to everyone,
 my problem is the follow;
 I need create an "Asset statements", and this one is composed by many
 different reports. The data source is an only XML file, relative to one
 customer, with, for example, 5/6 or more sub-sets of data.
 The question is:
 It is possible create one single Report/Document, composed, for example,
 by 5/6 or more reports relative to the same XML and obtain at the end
 one big report(pdf file in my case) with index and all the reports as
 part of the same documents.
 It is possible with Birt to do that ? If yes which is the correct
 structure to give at my documents? Which is the correct way to obtain that?
 Thanks a lot!!!!!!
| Re: 1 Document with many reports [message #189313 is a reply to message #187500] | Wed, 06 September 2006 02:59  |  |
| Eclipse User  |  |  |  |  | Originally posted by: mazumdars.airtelbroadband.in
 Diego wrote:
 > Hello to everyone,
 > The question is:
 > Thanks a lot!!!!!!
 Hi Diego,
 It is possible for you to create a single report having multiple
 reports in it.You can put hyperlinks to the different sub reports at the
 start of the document.Since your data source is only one, you could
 create individual datasets using the same data source which can be then
 used for populating the various reports. You can use the various
 formating tools i.e. page breaks, grids etc.
 Hope this helps.
 Sujoy.
FUDForum. Page generated in 0.08316 seconds
