Home » Modeling » GMF (Graphical Modeling Framework) » hide single property attribute
hide single property attribute [message #189075] Fri, 23 May 2008 07:33 Go to next message
How may I hide from my property view a choosen EAttribute of mine? I have
built a working custom tab property view that reads/saves its value, so I
don't want this property to be shown under the full property list any more.
Thanks!
Paolo
Re: hide single property attribute [message #189107 is a reply to message #189075] Fri, 23 May 2008 08:55 Go to previous messageGo to next message
don't know if it's the better way, but I did by commenting out
public List getPropertyDescriptors(Object object) {
if (itemPropertyDescriptors == null) {
super.getPropertyDescriptors(object);
addCSSPaddingRightPropertyDescriptor(object);
addRenderedELPropertyDescriptor(object);
//addCustomCodePropertyDescriptor(object); //don't get displayed!!
addRequiredPropertyDescriptor(object);
addStyleClassPropertyDescriptor(object);
return itemPropertyDescriptors;
in xxxxxItemProvider.java
This does not remove the eattribute, but prevents only to be enlisted in
the property sheets. Anyway you can access it by get/set methods if you
need to, this is the case if you do a custom tab sheet property view with
a specific editor for a property (here I have a large swt textarea where
to paste & edit code inside).
Re: hide single property attribute [message #189124 is a reply to message #189107] Fri, 23 May 2008 09:43 Go to previous message
Originally posted by: gmerin.integranova.com
Hi Paolo,
You could have achieve that just changing the "property type" to "None"
within your genmodel. It changes the below code for you automatically.
Gabriel.
> with a specific editor for a property (here I have a large swt textarea
> where to paste & edit code inside).
Previous Topic:Error saving resource set
Next Topic:PartContribution
Current Time: Sat Jul 19 12:04:27 EDT 2025
Powered by FUDForum. Page generated in 0.04277 seconds
