Home » Language IDEs » ServerTools (WTP) » Compatible with Eclipse 3.3M5?
| Compatible with Eclipse 3.3M5? [message #188498] |
Thu, 22 February 2007 12:16  |
Hello.
I have Eclipse 3.3M5 and I'm trying to install the WTP tools (WTP, JST,
etc). I downloaded the SDK with all the required plugins.
Though, WTP never shows up - i.e., it did not add JSP, XML, XSD, etc
support to the IDE...
I tried different versions of the WTP downloads but still no success.
Any idea?
Etienne
| Re: Compatible with Eclipse 3.3M5? [message #188506 is a reply to message #188498] |
Thu, 22 February 2007 12:50   |
Etienne wrote:
> Hello.
> Any idea?
For running on 3.3 M5, you'll want the 2.0 M5 milestone build due
tomorrow. Also, when you install plug-ins manually, you need to
restart Eclipse with -clean so they're detected.
Nitin Dahyabhai
Structured Source Editor
| Re: Compatible with Eclipse 3.3M5? [message #188816 is a reply to message #188707] |
Wed, 28 February 2007 14:42  |
I am having the same problem
I have tried 3.3.M4, 3.3.M5, 3.3.M5eh
My 3.3.M5 configuration
*** Date: Wed Feb 28 14:40:42 EST 2007
*** Platform Details:
*** System properties:
eclipse.buildId=I20070209-1006
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/usr/eclipse/europa/3.3.M5/release/eclipse
-name
Eclipse
-library
/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse.equin ox.launcher.gtk.linux.x86_1.0.0.v20070208a/eclipse_1006.so
-startup
/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse.equin ox.launcher_1.0.0.v20070208a.jar
-showsplash
-vm
/usr/java/jdk1.5.0_08/bin/../jre/lib/i386/client/libjvm.so
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1172691559101
eclipse.vm=/usr/java/jdk1.5.0_08/bin/../jre/lib/i386/client/ libjvm.so
eclipse.vmargs=-Xms40m
-Xmx256m
-Djava.class.path=/usr/eclipse/europa/3.3.M5/release/plugins /org.eclipse.equinox.launcher_1.0.0.v20070208a.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/usr/eclipse/europa/3.3.M5/release/plugins/o rg.eclipse.equinox.launcher_1.0.0.v20070208a.jar
java.class.version=49.0
java.endorsed.dirs=/usr/java/jdk1.5.0_08/jre/lib/endorsed
java.ext.dirs=/usr/java/jdk1.5.0_08/jre/lib/ext
java.home=/usr/java/jdk1.5.0_08/jre
java.io.tmpdir=/tmp
java.library.path=/usr/java/jdk1.5.0_08/jre/lib/i386/client: :/usr/java/jdk1.5.0_08/jre/lib/i386::/usr/lib/mozilla-1.7.13 :/usr/lib/mozilla-1.7.13
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_08-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_08
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_08-b03
line.separator=
org.eclipse.equinox.launcher.splash.handle=152361056
org.eclipse.equinox.launcher.splash.location=/usr/eclipse/eu ropa/3.3.M5/release/plugins/org.eclipse.platform_3.2.100.v20 070205/splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.18-1.2200.fc5
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/usr/eclipse/europa/3.3.M5/release/configur ation/org.eclipse.osgi/bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/usr/eclipse/europa/3.3.M5/rele ase/configuration/
osgi.framework=file:/usr/eclipse/europa/3.3.M5/release/plugi ns/org.eclipse.osgi_3.3.0.v20070208.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.0.v20070208
osgi.install.area=file:/usr/eclipse/europa/3.3.M5/release/
osgi.instance.area=file:/home/acarbone/workspace_eclipse_3_3 /
osgi.instance.area.default=file:/home/acarbone/workspace_sub version/
osgi.logfile=/home/acarbone/workspace_eclipse_3_3/.metadata/ .log
osgi.manifest.cache=/usr/eclipse/europa/3.3.M5/release/confi guration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.splashLocation=/usr/eclipse/europa/3.3.M5/release/plugi ns/org.eclipse.platform_3.2.100.v20070205/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/usr/eclipse/europa/3.3.M5/release/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/usr/java/jdk1.5.0_08/jre/lib/rt.jar:/us r/java/jdk1.5.0_08/jre/lib/i18n.jar:/usr/java/jdk1.5.0_08/jr e/lib/sunrsasign.jar:/usr/java/jdk1.5.0_08/jre/lib/jsse.jar: /usr/java/jdk1.5.0_08/jre/lib/jce.jar:/usr/java/jdk1.5.0_08/ jre/lib/charsets.jar:/usr/java/jdk1.5.0_08/jre/classes
sun.boot.library.path=/usr/java/jdk1.5.0_08/jre/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/usr/eclipse/europa/3.3.M5/release
user.home=/home/acarbone
user.language=en
user.name=acarbone
user.timezone=America/New_York
*** Features:
org.eclipse.cvs (1.0.0) "Eclipse CVS Client"
org.eclipse.cvs.source (1.0.0) "Eclipse CVS Client"
org.eclipse.jdt (3.3.0.v20070205-180-GKeyrSg2mvoVKQM) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.3.0.v20070205-180-GKeyrSg2mvoVKQM) "Eclipse Java
Development Tools SDK"
org.eclipse.jst (1.6.0.v200611220050-xEzZktHIhCmcvju) "J2EE Standard Tools
(JST)"
org.eclipse.pde (3.3.0.v20061114-080-87cMNDNcOD-KLPM) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.3.0.v20061114-080-87cMNDNcOD-KLPM) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.3.0.v2007020-6BKMZVNUaZs1qhM) "Eclipse Platform"
org.eclipse.platform.source (3.3.0.v2007020-6BKMZVNUaZs1qhM) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.3.0.v20070116-fFIEHGCmfQISbVP) "Eclipse RCP"
org.eclipse.rcp.source (3.3.0.v20070116-fFIEHGCmfQISbVP) "Eclipse RCP
org.eclipse.sdk (3.3.0.v2007012-HHOOvpEmjMa0dli) "Eclipse Project SDK"
org.eclipse.wst (1.6.0.v200611220050-iA4pdQ1Ztn4xezD) "Web Standard Tools
(WST)"
org.tigris.subversion.subclipse (1.2.0) "SVN Team Provider Core"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Installed]
com.ibm.icu (3.6.0.20061215) "International Components for Unicode for Java
(ICU4J)" [Active]
com.ibm.icu.source (3.6.0.20061215) "International Components for Unicode
for Java (ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Starting]
org.apache.axis (1.3.0.v200608161946) "Apache Axis 1.3.0" [Starting]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Starting]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20070115) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200608161946) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200612131415) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.200.v20070128) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.100.v20070128) "Ant UI" [Starting]
org.eclipse.compare (3.3.0.I200702081800) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070205-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20060808) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.databinding (1.0.0.I20070206-0010) "JFace Data Binding"
[Active]
org.eclipse.core.databinding.beans (1.0.0.I20070206-0010) "JFace Data
Binding for JavaBeans" [Starting]
org.eclipse.core.expressions (3.3.0.v20070205-1800) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.3.0.v20070205-1800) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070202) "Core File Systems" [Active]
org.eclipse.core.filesystem.linux.x86 (1.1.0.v20070202) "Core File System
for Linux" [Resolved]
org.eclipse.core.jobs (3.3.0.v20070202) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.3.0.v20070202) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20061106) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20061204) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20061120) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20070202) "Authorization
Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20060828) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20070205) "Core Variables" [Starting]
org.eclipse.cvs (1.0.0.v20070122) "Eclipse CVS Client" [Starting]
org.eclipse.cvs.source (1.0.0) "Eclipse CVS Client" [Resolved]
org.eclipse.debug.core (3.3.0.v20070207a) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.0.v20070206) "Debug UI" [Active]
org.eclipse.equinox.app (1.0.0.v20070203) "Equinox Application Container"
[Active]
org.eclipse.equinox.common (3.3.0.v20070122) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.launcher (1.0.0.v20070208a) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.gtk.linux.x86 (1.0.0.v20070208a) "Equinox
Launcher Linux X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20060918) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.100.v20061204) "Extension Registry
Support" [Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved]
org.eclipse.help (3.3.0.v20070207) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20060612) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.0.v20070207) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.0.v20070206) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.0.v20070206) "Help System Webapp" [Starting]
org.eclipse.jdt (3.2.100.v20070205-1800) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.0.v20070129-1720) "Java Annotation Processing
Core" [Active]
org.eclipse.jdt.apt.ui (3.3.0.v20070129-1720) "Java Annotation Processing
UI" [Starting]
org.eclipse.jdt.compiler.tool (1.0.0.v_728) "Java Compiler Tool" [Installed]
org.eclipse.jdt.core (3.3.0.v_735) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070205-1800) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.2.100.v20070207a) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.100.v20070207) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.3.0.v20070205-1800) "Eclipse JDT Plug-in
Developer Guide" [Starting]
org.eclipse.jdt.doc.user (3.3.0.v20070205-1800) "Eclipse Java Development
User Guide" [Starting]
org.eclipse.jdt.junit (3.3.0.v20070205-1800) "Java Development Tools JUnit
support" [Starting]
org.eclipse.jdt.junit.runtime (3.2.100.v20070205-1800) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070205-1800) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.100.v20070202) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.3.0.v20070208) "Java Development Tools UI" [Active]
org.eclipse.jem (1.2.1.v20060918_M_wtp-patch-M4b) "Java EMF Model"
[Installed]
org.eclipse.jem.beaninfo (1.2.0.v20060918_M_wtp-patch-M4b) "Java EMF Model
BeanInfo (Introspection) Support" [Installed]
org.eclipse.jem.proxy (1.2.0.v20060918_M_wtp-patch-M4b) "Java EMF Model
Proxy Support" [Installed]
org.eclipse.jem.ui (1.2.1.v20060918_M_wtp-patch-M4b) "Java EMF Model UI"
[Installed]
org.eclipse.jem.util (1.2.1.v20060918_M_wtp-patch-M4b) "Java EMF Model
Utilities" [Installed]
org.eclipse.jem.workbench (1.2.1.v20060918_M_wtp-patch-M4b) "Java EMF Model
Workbench Support" [Installed]
org.eclipse.jface (3.3.0.I20070206-0010) "JFace" [Resolved]
org.eclipse.jface.databinding (1.1.0.I20070206-0010) "JFace Data Binding for
SWT and JFace" [Active]
org.eclipse.jface.text (3.3.0.v20070205-1800) "JFace Text" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.1.v200611161500)
"Annotation Controller Plug-in" [Installed]
org.eclipse.jst.common.annotations.core (1.1.1.v200611161515) "Annotation
Core Plug-in" [Installed]
org.eclipse.jst.common.annotations.ui (1.1.1.v200611230506) "Annotations UI
org.eclipse.jst.common.frameworks (1.1.3.v200612111947) "Integration
org.eclipse.jst.common.project.facet.core (1.1.0.v200608141517) "Project
Facet Core (Java Support)" [Starting]
org.eclipse.jst.ejb.doc.user (1.0.203.v200609221652) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.1.v200611161506) "WTP EJB UI Plug-in"
[Installed]
org.eclipse.jst.j2ee (1.1.3.v200612131833) "J2EE Component" [Installed]
org.eclipse.jst.j2ee.core (1.1.102.v200612060400) "J2EE Core Component"
[Installed]
org.eclipse.jst.j2ee.doc.user (1.0.203.v200609182036) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.3.v200612131833) "EJB component Plug-in"
[Installed]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.1.v200611232200) "EJB
Annotation Model Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.1.v200611161506) "EJB
Emitter Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.1.v200611161506) "EJB
Annotations Ui Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.1.v200611161506) "Xdoclet
Annotations Plug-in" [Installed]
org.eclipse.jst.j2ee.infopop (1.0.202.v200611161440) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.1.3.v200612061730) "JCA Plug-in" [Installed]
org.eclipse.jst.j2ee.jca.ui (1.1.1.v200611062157) "WTP JCA UI Plug-in"
[Installed]
org.eclipse.jst.j2ee.navigator.ui (1.1.1.v200611161506) "J2EE Extensions to
Common Navigator" [Installed]
org.eclipse.jst.j2ee.ui (1.1.1.v200612151123) "WTP J2EE UI Plug-in"
[Installed]
org.eclipse.jst.j2ee.web (1.1.3.v200612061730) "Web Plug-in" [Installed]
org.eclipse.jst.j2ee.webservice (1.1.3.v200612131833) "Web Service Plug-in"
[Installed]
org.eclipse.jst.j2ee.webservice.ui (1.1.101.v200612130807) "WTP Webservice
UI Plug-in" [Installed]
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.1.v200611161506) "XDocletRuntime
org.eclipse.jst.jee (1.0.0.v200612151123) "JEE common Plug-in" [Installed]
org.eclipse.jst.jee.ejb (1.0.0.v200612151123) "JEE Ejb Plug-in" [Installed]
org.eclipse.jst.jsp.core (1.2.0.v200611161411) "Structured Source JSP Model"
[Installed]
org.eclipse.jst.jsp.ui (1.1.200.v200612280403) "SSE JSP Source Editor"
[Installed]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools infopops"
[Resolved]
org.eclipse.jst.server.core (1.0.204.v20061204) "Java Server Support"
[Starting]
org.eclipse.jst.server.generic.core (1.0.101.v200701042200) "Generic Server
Plugin" [Installed]
org.eclipse.jst.server.generic.jboss (1.5.1.v200701021438) "JBoss Generic
server definitions" [Installed]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS Generic
Server definitions" [Installed]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200612101159) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Installed]
org.eclipse.jst.server.generic.ui (1.0.102.v200701042200) "Generic Server
Plugin UI" [Installed]
org.eclipse.jst.server.generic.weblogic (1.5.1.v200612120248) "Weblogic
generic server definitions" [Installed]
org.eclipse.jst.server.installable (1.5.2.v200612120248) "Installable
servers" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.203.v20061202) "Apache Tomcat
Support" [Starting]
org.eclipse.jst.server.tomcat.ui (1.0.203.v20061218) "Apache Tomcat UI
org.eclipse.jst.server.ui (1.0.203.v20061218) "Java Server UI Support"
[Installed]
org.eclipse.jst.server.ui.doc.user (1.0.203.v200609221652) "Server Tools
documentation for J2EE Standard Tools" [Starting]
org.eclipse.jst.server.ui.infopop (1.0.2.v200605040115) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.101.v200611161440) "WebSphere
org.eclipse.jst.servlet.ui (1.1.1.v200612122040) "WTP Servlet UI Plug-in"
[Installed]
org.eclipse.jst.servlet.ui.infopop (1.0.201.v200606130315) "Servlet infopop"
[Starting]
org.eclipse.jst.ws (1.0.102.v200612120248) "Web Services" [Installed]
org.eclipse.jst.ws.axis.consumption.core (1.0.102.v200612120248) "Web
service Axis Consumption Core" [Installed]
org.eclipse.jst.ws.axis.consumption.ui (1.0.102.v200612120248) "Webservice
Axis Consumption UI" [Installed]
org.eclipse.jst.ws.axis.creation.ui (1.0.102.v200612120248) "Webservice Axis
Creation UI" [Installed]
org.eclipse.jst.ws.axis.infopop (1.0.201.v200605152241) "Web services Axis
UI" [Starting]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.203.v200609221652) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.102.v200612140447) "Web Services
Consumption" [Installed]
org.eclipse.jst.ws.consumption.infopop (1.0.201.v200605152241) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.103.v200612140447) "Web Services
Consumption Graphical User Interface" [Installed]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.202.v200609221652) "Web
service consumption documentation" [Starting]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200606130315) "Web Services
Creation EJB Graphical User Interface" [Installed]
org.eclipse.jst.ws.creation.ui (1.0.103.v200612140447) "Web Services
Creation Graphical User Interface" [Installed]
org.eclipse.jst.ws.doc.user (1.0.203.v200609221652) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.201.v200605162034) "Web services UI"
[Starting]
org.eclipse.jst.ws.uddiregistry (1.0.100.v200612120248) "Web Services
Universal Description Discovery and Integration Registry" [Installed]
org.eclipse.jst.ws.ui (1.0.101.v200612120248) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.3.0.v20070205-1800) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.3.0.v20070205-1800) "Refactoring UI"
[Active]
org.eclipse.osgi (3.3.0.v20070208) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.100.v20060918) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060918) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.3.0.v20061211-0010) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.0.v20070209) "Plug-in Development Environment
Build Support" [Active]
org.eclipse.pde.core (3.3.0.v20070208-1200) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070208-0011) "Eclipse Plug-in Development
User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070205-0010) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070208-0010) "Plug-in Development
Environment Runtime" [Starting]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.3.0.v20070208-0012) "Plug-in Development UI"
[Starting]
org.eclipse.pde.ui.templates (3.3.0.v20070208-0010) "PDE Templates"
[Starting]
org.eclipse.platform (3.2.100.v20070205) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.isv (3.3.0.I20070206-0010) "Eclipse Platform
Plug-in Developer Guide" [Starting]
org.eclipse.platform.doc.user (3.3.0.v20070205-1800) "Eclipse Workbench User
Guide" [Starting]
Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.linux.gtk.x86 (3.3.0.v2007020-6BKMZVNUaZs1qhM)
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Starting]
org.eclipse.rcp.source.linux.gtk.x86 (3.3.0.v20070116-fFIEHGCmfQISbVP)
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.3.0.v20070205) "Eclipse Project SDK" [Starting]
org.eclipse.search (3.3.0.v20070205-1800) "Search Support" [Starting]
org.eclipse.swt (3.3.0.v3325g) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.3.0.v3325c) "Standard Widget Toolkit for
GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.100.I200702081800) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.0.I200702051300) "CVS Team Provider Core"
[Starting]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070122) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.0.I20070202) "CVS Team Provider UI" [Starting]
org.eclipse.team.ui (3.3.0.I200702071200) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070205-1800) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20061208) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.0.I20070208-1200) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070108) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.3.0.v20070206) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.2.0.v20070202) "Console" [Active]
org.eclipse.ui.editors (3.3.0.v20070205-1800) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.200.v20070128) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070208) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.3.0.I20070205-1300) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070130-0800) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.100.v20070206) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070129) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.2.100.I20061212-0010b) "Common Navigator View"
[Starting]
org.eclipse.ui.navigator.resources (3.2.100.I20061213-1608) "Navigator
Workbench Components" [Starting]
org.eclipse.ui.presentations.r21 (3.2.0.I20060918-0010) "R21 Presentation
Plug-in" [Starting]
org.eclipse.ui.views (3.2.100.I20060918-0010) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.100.I20061213-1608) "Tabbed
Properties View" [Starting]
org.eclipse.ui.workbench (3.3.0.I20070208-1200) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060918-0010) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.3.0.v20070208) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.100.v20061214) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.100.v20061220) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.2.0.v20060605) "Install/Update Core for
Linux" [Resolved]
org.eclipse.update.scheduler (3.2.100.v20061214) "Automatic Updates
Scheduler" [Active]
org.eclipse.update.ui (3.2.100.v20061220) "Install/Update UI" [Active]
org.eclipse.wst (1.0.1.v200610230930) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.102.v200612120248) "Environment Command
Framework (headless)" [Installed]
org.eclipse.wst.command.env.core (1.0.101.v200612120248) "Environment
Command Framework (core)" [Installed]
org.eclipse.wst.command.env.doc.user (1.5.0.v200611161425) "Web services
Axis Ant task documentation" [Starting]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services UI"
[Starting]
org.eclipse.wst.command.env.ui (1.0.102.v200612120248) "Environment Command
Framework (GUI)" [Installed]
org.eclipse.wst.common.core (1.1.100.v200611232215) "WST Common Core
Plug-in" [Starting]
org.eclipse.wst.common.emf (1.1.103.v200612151123) "EMF Utilities"
[Installed]
org.eclipse.wst.common.emfworkbench.integration (1.1.103.v200612151123) "EMF
Workbench Edit Plug-in" [Installed]
org.eclipse.wst.common.environment (1.0.100.v200612120248) "Enviornment
Plug-in" [Starting]
org.eclipse.wst.common.frameworks (1.1.102.v200612131445) "Common
Frameworks" [Installed]
org.eclipse.wst.common.frameworks.ui (1.1.1.v200609182043) "WTP UI Plug-in"
[Installed]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST infopops"
[Starting]
org.eclipse.wst.common.modulecore (1.1.102.v200612060335) "Modulecore
org.eclipse.wst.common.project.facet.core (1.1.100.v200612111947) "Project
Facet Core" [Starting]
org.eclipse.wst.common.project.facet.ui (1.1.100.v200612111947) "Project
Facet UI" [Installed]
org.eclipse.wst.common.snippets (1.1.101.v200612062150) "Snippets View"
[Installed]
org.eclipse.wst.common.ui (1.1.200.v200611250503) "Eclipse Base UI
extensions" [Starting]
org.eclipse.wst.common.ui.properties (1.0.101.v200611161425) "Common
Properties UI" [Starting]
org.eclipse.wst.common.uriresolver (1.1.100.v200611142226) "Common URI
Resolver Framework" [Starting]
org.eclipse.wst.css.core (1.1.101.v200612141813) "Structured Source CSS
Model" [Installed]
org.eclipse.wst.css.ui (1.0.201.v200612060029) "SSE CSS Source Editor"
[Installed]
org.eclipse.wst.doc.user (1.0.203.v200608231821) "Master User Doc TOC"
[Starting]
org.eclipse.wst.dtd.core (1.1.101.v200611161400) "Structured Source DTD
Core" [Installed]
org.eclipse.wst.dtd.ui (1.0.201.v200612140053) "SSE DTD Source Editor"
[Installed]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor infopops"
[Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.203.v200609221652) "DTD Editor
org.eclipse.wst.html.core (1.1.101.v200612200806) "Structured Source HTML
Model" [Installed]
org.eclipse.wst.html.standard.dtds (1.0.1.v200608230302) "Known DTDs"
[Installed]
org.eclipse.wst.html.ui (1.0.201.v200612060029) "HTML UI Source Editor"
[Installed]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor infopops"
[Resolved]
org.eclipse.wst.internet.cache (1.0.201.v200612070354) "Cache URI Resolver
Plug-in" [Starting]
org.eclipse.wst.internet.monitor.core (1.0.103.v20061212b) "Monitor"
[Starting]
org.eclipse.wst.internet.monitor.ui (1.0.103.v20061212b) "TCP/IP Monitor"
[Starting]
org.eclipse.wst.internet.proxy (1.0.100.v200612120248) "Internet Proxy
Preferences" [Installed]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet Proxy
Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.1.v200611161411) "Structured Source
JavaScript Model" [Starting]
org.eclipse.wst.javascript.ui (1.0.101.v200612140053) "SSE JavaScript Source
Editor" [Installed]
org.eclipse.wst.javascript.ui.infopop (1.0.1.v200605040131) "Javascript
infopop" [Resolved]
org.eclipse.wst.server.core (1.0.204.v20061218) "Server Core" [Starting]
org.eclipse.wst.server.ui (1.0.204.v20061218) "Server UI" [Starting]
org.eclipse.wst.server.ui.doc.user (1.0.203.v200609221652) "Server Tools
documentation for Web Standard Tools" [Starting]
org.eclipse.wst.server.ui.infopop (1.0.3.v200611161425) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sse.core (1.1.201.v200611210029) "Structured Text Model"
[Installed]
org.eclipse.wst.sse.doc.user (1.0.203.v200609060236) "Structured text editor
and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.301.v200612280403) "Structured Source Editor"
[Installed]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops"
[Resolved]
org.eclipse.wst.validation (1.1.2.v200612131833) "Validation Framework"
[Installed]
org.eclipse.wst.validation.infopop (1.0.201.v200609292131) "WST validation
infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.102.v200612061730) "Validation Framework
UI" [Installed]
org.eclipse.wst.web (1.1.101.v200612131402) "Simple Web Plug-in" [Installed]
org.eclipse.wst.web.ui (1.1.1.v200612111947) "Simple Web UI Plug-in"
[Installed]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web infopop"
[Starting]
org.eclipse.wst.webtools.doc.user (1.0.203.v200609221652) "Web tools
org.eclipse.wst.ws (1.0.101.v200612120248) "Web Services" [Installed]
org.eclipse.wst.ws.explorer (1.0.103.v200612120248) "Web Services Explorer"
[Installed]
org.eclipse.wst.ws.infopop (1.0.201.v200605152241) "Web Services UI"
[Starting]
org.eclipse.wst.ws.parser (1.0.101.v200612120248) "Web Services Description
Parser" [Installed]
org.eclipse.wst.ws.ui (1.0.101.v200612120248) "Web Services UI" [Installed]
org.eclipse.wst.wsdl (1.0.103.v200612061614) "WSDL Model" [Installed]
org.eclipse.wst.wsdl.ui (1.1.100.v200609220004) "WSDL UI" [Installed]
org.eclipse.wst.wsdl.ui.doc.user (1.0.203.v200609221652) "WSDL Editor
Documentation" [Starting]
org.eclipse.wst.wsdl.validation (1.1.200.v200608162152) "WSDL Validator"
[Installed]
org.eclipse.wst.wsi (1.0.103.v200612120248) "WSI Conformance Tools"
[Installed]
org.eclipse.wst.wsi.ui (1.0.200.v200608150316) "Soap Monitor" [Installed]
org.eclipse.wst.wsi.ui.doc.user (1.0.202.v200609221652) "WS-I Validation
Documentation" [Resolved]
org.eclipse.wst.xml.core (1.1.101.v200612131416) "Structured Source XML
Model" [Installed]
org.eclipse.wst.xml.ui (1.0.300.v200612140053) "XML UI Plugin" [Installed]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200605040131) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.203.v200609221652) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.200.v200612120245) "XSD Core Plugin"
[Installed]
org.eclipse.wst.xsd.ui (1.1.101.v200612111819) "XML Schema Editor"
[Installed]
org.eclipse.wst.xsdeditor.doc.user (1.0.203.v200609221652) "XML schema
editor" [Resolved]
org.junit (3.8.2) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0.1) "JUnit Testing Framework Version 4" [Resolved]
org.tigris.subversion.subclipse.core (1.2.0) "SVN Team Provider Core"
[Active]
org.tigris.subversion.subclipse.doc (1.2.0) "Subclipse Documentation"
[Resolved]
org.tigris.subversion.subclipse.ui (1.2.0) "SVN Team Provider UI" [Active]
org.uddi4j (2.0.5.v200608231542) "UDDI4J 2.0.5" [Resolved]
org.wsdl4j (1.4.0.v200612131455) "WSDL4J 1.4" [Resolved]
*** User Preferences:
#Wed Feb 28 14:40:42 EST 2007
/instance/org.eclipse.wst.server.core/module-start-timeout=3 00000
@org.eclipse.debug.ui=3.3.0.v20070206
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?><templates/>
@org.eclipse.ui.ide=3.3.0.I20070205-1300
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1170883943115 "
defaultVMConnector\="">\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\n<vm
id\="1170883943115" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jdk1.5.0_08"
path\="/usr/java/jdk1.5.0_08"/>\n</vmType>\n</vmSettings >\n
@org.eclipse.pde.core=3.3.0.v20070208-1200
/instance/org.eclipse.birt.chart.reportitem.ui/enable_live=t rue
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
@org.eclipse.ui.browser=3.2.100.v20070108
/instance/org.eclipse.jst.jsp.core/jspIndexState=1
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
@org.eclipse.jdt.ui=3.3.0.v20070208
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.3.0.v20070202
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=25
/instance/org.eclipse.help.ui/browser.x=109
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1115
/instance/org.eclipse.pde.core/platform_path=/usr/eclipse/eu ropa/3.3.M5/release
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.launching=3.2.100.v20070202
file_export_version=3.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.help.ui/browser.h=768
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Mo nospace|10.0|0|GTK|1|;
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.enumIdentifier=error
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.MemoryVi ew.viewPanesVisibility=org.eclipse.debug.ui.MemoryView.Memor yBlocksTreeViewPane,org.eclipse.debug.ui.MemoryView.Renderin gViewPane.1,
/instance/org.eclipse.ui.ide/platformState=1171970457114
/instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=Report
Prototype,com.verisign.vans.birt.report.data.oda.agency,com. verisign.vans.birt.report.data.oda.agency.ui,Report
Adapter Project
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/shemas_pr efetch_config=YES
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .compliance=1.5
@org.eclipse.wst.server.core=1.0.204.v20061218
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/user_max_ num_of_schema=20
@org.eclipse.ui.editors=3.3.0.v20070205-1800
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=/home/ac arbone/workspace_eclipse_3_3,/home/acarbone/workspace_jasper
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .codegen.targetPlatform=1.5
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.PREF_LAU NCH_PERSPECTIVES= <?xml
version\="1.0" encoding\="UTF-8"?>\n<launchPerspectives/>\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=11
@org.eclipse.jdt.core=3.3.0.v_735
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.birt.report.data.oda.jdbc.ui/user_max_ num_of_table_each_schema=100
@org.eclipse.search=3.3.0.v20070205-1800
/instance/org.eclipse.update.ui/ConfigurationView.showUnconf =true
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\n<web-browsers current\="0">\n<system/>\n<external
location\="/usr/bin/mozilla" name\="Mozilla"/>\n</web-browsers>
/instance/org.eclipse.debug.ui/org.eclipse.debug.ui.user_vie w_bindings= <?xml
version\="1.0" encoding\="UTF-8"?>\n<viewBindings>\n<view
id\="org.eclipse.ui.console.ConsoleView">\n<perspective
id\="org.eclipse.jdt.ui.JavaPerspective"
userAction\="opened"/>\n</view>\n</viewBindings>\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.birt.report.designer.ui/Palette\ Size=125
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .source=1.5
/instance/org.eclipse.birt.chart.reportitem.ui/max_row=6
@org.eclipse.team.ui=3.3.0.I200702071200
/instance/org.eclipse.search/org.eclipse.search.defaultPersp ective=org.eclipse.search.defaultPerspective.none
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.birt.report.designer.ui/user_maxrow=50 0
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
@org.eclipse.update.ui=3.2.100.v20061220
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler .problem.assertIdentifier=error
@org.eclipse.help.ui=3.3.0.v20070206
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.ui=3.3.0.I20070208-1200
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
*** Current Install Configuration:
Install configuration:
Last changed on Feb 26, 2007
file:/usr/eclipse/europa/3.3.M5/release/configuration/org.ec lipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
1.6.0.v200611220050--87cMN8SeSlJWbs
ID: org.eclipse.jdt.source, Version: 3.3.0.v20070205-180-GKeyrSg2mvoVKQM
ID: org.eclipse.pde.source, Version: 3.3.0.v20061114-080-87cMNDNcOD-KLPM
ID: org.eclipse.sdk, Version: 3.3.0.v20070205
1.6.0.v200611220050-zjf2Su0vv0wF6ik
1.6.0.v200611220050--87cMN7TdRvPzVZ
ID: org.eclipse.rcp.source, Version: 3.3.0.v20070116-fFIEHGCmfQISbVP
1.6.0.v200611220050-zlxHf5IAECfPs5K
1.6.0.v200612120330--4hNDDhHSKTGeFR
ID: org.eclipse.jst, Version: 1.0.1.v200605040115
1.6.0.v200611161425--0842282A443874
1.6.0.v200611161440--0842282A443874
1.6.0.v200611220050-POHzvgPpDjQiYdh
1.6.0.v200611220050-pM8LXM9WhXtEAN7
1.6.0.v200611220050-VYgjUpX-F56MryO
1.6.0.v200611161425-PGIEYfZNqOMLRX9
ID: org.eclipse.platform, Version: 3.2.100.v20070205
ID: org.eclipse.cvs, Version: 1.0.0.v20070122
1.6.0.v200611220050-ygkd9b0cTafXjGP
1.6.0.v200701030250--4hNDDhILJSGRLc
1.6.0.v200611161425--1G955G5L9_7IB8
1.6.0.v200611161425--3YIAAYAkGMDUSM
1.6.0.v200611161515--4hNDDhDwMTJbaR
1.6.0.v200701030945-XOqsX299MAeqUkG
ID: org.eclipse.jdt, Version: 3.2.100.v20070205-1800
1.6.0.v200701030413--AXrVWXbOgBgECV
1.6.0.v200611220050--0842282_363739
1.6.0.v200611220050-hnSgW6sLaW8fXo2
1.6.0.v200611220050-----1G955G797Ep
ID: org.eclipse.cvs.source, Version: 1.0.0
1.6.0.v200611161425--2PD88P9QCHANJG
1.6.0.v200612131833--4hNDDhINHZIcQP
1.6.0.v200611220050-PGIEVDRE_DHCF5A
ID: org.eclipse.platform.source, Version: 3.3.0.v2007020-6BKMZVNUaZs1qhM
ID: org.eclipse.rcp, Version: 3.2.0.v20060605
ID: org.eclipse.pde, Version: 3.3.0.v20061211-0010
ID: org.eclipse.wst, Version: 1.0.1.v200610230930
ID: org.tigris.subversion.subclipse.core, Version: 1.2.0
Configured plug-ins:
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. text_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.filesystem_1.1.0.v20070202.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.resources_3.3.0.v20070202.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. update.core.linux_3.2.0.v20060605.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. pde.ui_3.3.0.v20070208-0012.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jface.databinding_1.1.0.I20070206-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst_1.0.1.v200610230930.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.apache.l ucene_1.4.103.v20070115/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.doc.user_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.creation.ui_1.0.103.v200612140447.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jface.text_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ui.workbench.texteditor_3.3.0.v20070208.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.tigris.s ubversion.subclipse.ui_1.2.0.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.core.manipulation_1.1.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.server.ui.infopop_1.0.3.v200611161425.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jface_3.3.0.I20070206-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.runtime.compatibility.registry_3.2.100.v20060828/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.server.tomcat.ui_1.0.203.v20061218.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.runtime.compatibility_3.1.100.v20061120.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.server.tomcat.core_1.0.203.v20061202.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.ejb.annotations.ui_1.1.1.v200611161506.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.ui_1.0.101.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.ws.infopop_1.0.201.v200605152241.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.ui_3.3.0.v20070208.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.server.generic.weblogic_1.5.1.v200612120248/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. pde_3.3.0.v20061211-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.databinding_1.0.0.I20070206-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.junit_3. 8.2/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.web.ui_1.1.1.v200612111947.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.ws.ui_1.0.101.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.commands_3.3.0.I20070205-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.infopop_1.0.201.v200605162034.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. equinox.preferences_3.2.100.v20060918.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. help.webapp_3.3.0.v20070206/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.boot_3.1.100.v20060603.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.jsp.ui_1.1.200.v200612280403.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.common.environment_1.0.100.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. platform.doc.user_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.jca_1.1.3.v200612061730.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.apache.c ommons_logging_1.0.4.v200608011657/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.ws.parser_1.0.101.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.internet.proxy.infopop_1.0.0.v200605070230.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. rcp.source_3.3.0.v20070116-fFIEHGCmfQISbVP/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.internet.monitor.ui_1.0.103.v20061212b.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.server.installable_1.5.2.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jem.util_1.2.1.v20060918_M_wtp-patch-M4b.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.apt.core_3.3.0.v20070129-1720.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.xsdeditor.doc.user_1.0.203.v200609221652.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. rcp_3.2.0.v20060605.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ant.core_3.1.200.v20070128.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.validation.ui_1.1.102.v200612061730.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.common.annotations.core_1.1.1.v200611161515.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.web_1.1.3.v200612061730.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ltk.ui.refactoring_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jem_1.2.1.v20060918_M_wtp-patch-M4b.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.axis.infopop_1.0.201.v200605152241.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. equinox.launcher_1.0.0.v20070208a.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.internet.monitor.core_1.0.103.v20061212b.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.common.snippets_1.1.101.v200612062150.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.webservice_1.1.3.v200612131833.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.server.core_1.0.204.v20061218.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.tigris.s ubversion.subclipse.doc_1.2.0.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt_3.2.100.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ui.intro_3.2.100.v20070206.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. debug.ui_3.3.0.v20070206.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jem.workbench_1.2.1.v20060918_M_wtp-patch-M4b.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.uddiregistry_1.0.100.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.wsi.ui.doc.user_1.0.202.v200609221652.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.doc.user_1.0.203.v200609182036.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.jsp.ui.infopop_1.0.2.v200605040115.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.common.emf_1.1.103.v200612151123.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. help.base_3.3.0.v20070207.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.ejb_1.1.3.v200612131833.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.junit.runtime_3.2.100.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.server.ui_1.0.204.v20061218.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.jsp.core_1.2.0.v200611161411.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. platform.source.linux.gtk.x86_3.3.0.v2007020-6BKMZVNUaZs1qhM /
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.variables_3.1.100.v20070205.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.xml.ui_1.0.300.v200612140053.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst_1.0.1.v200605040115.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.junit_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. help_3.3.0.v20070207.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.javascript.ui_1.0.101.v200612140053.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.ui_1.1.1.v200612151123.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.consumption.ui_1.0.103.v200612140447.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. update.scheduler_3.2.100.v20061214.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.consumption_1.0.102.v200612140447/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.ws.explorer_1.0.103.v200612120248/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.xsd.ui_1.1.101.v200612111819.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.command.env.doc.user_1.5.0.v200611161425.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. pde.source_3.3.0.v20061114-080-87cMNDNcOD-KLPM/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.jca.ui_1.1.1.v200611062157.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.servlet.ui_1.1.1.v200612122040.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.filebuffers_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. team.cvs.ui_3.3.0.I20070202.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.infopop_1.0.202.v200611161440.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.javascript.core_1.0.1.v200611161411.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.wsdl.ui_1.1.100.v200609220004.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.common.annotations.controller_1.1.1.v200611161500.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. cvs.source_1.0.0/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. sdk_3.3.0.v20070205/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.core_1.1.102.v200612060400.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ui.externaltools_3.1.200.v20070128.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.html.core_1.1.101.v200612200806.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.consumption.ui.doc.user_1.0.202.v200609221652.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.compiler.tool_1.0.0.v_728.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.webtools.doc.user_1.0.203.v200609221652.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.ejb.annotation.model_1.1.1.v200611232200.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.command.env.ui_1.0.102.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. cvs_1.0.0.v20070122.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. osgi.util_3.1.100.v20060918.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws_1.0.102.v200612120248.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. platform.doc.isv_3.3.0.I20070206-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.core_3.3.0.v_735.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.debug.ui_3.2.100.v20070207.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.j2ee.xdoclet.runtime_1.1.1.v200611161506.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. team.cvs.core_3.3.0.I200702051300.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.apache.j akarta_log4j_1.2.8.v200607172048/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.html.standard.dtds_1.0.1.v200608230302/
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ui.ide.application_1.0.0.I20070130-0800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. swt.gtk.linux.x86_3.3.0.v3325c.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.server.ui.infopop_1.0.2.v200605040115.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. pde.runtime_3.3.0.v20070208-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jdt.junit4.runtime_1.0.100.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. pde.ui.templates_3.3.0.v20070208-0010.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. wst.common.infopop_1.0.1.v200605270041.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.runtime.compatibility.auth_3.2.0.v20070202.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. debug.core_3.3.0.v20070207a.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. core.expressions_3.3.0.v20070205-1800.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. ui.views.properties.tabbed_3.2.100.I20061213-1608.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ws.doc.user_1.0.203.v200609221652.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. team.ui_3.3.0.I200702071200.jar
file:/usr/eclipse/europa/3.3.M5/release/plugins/org.eclipse. jst.ejb.doc.user_1.0.20
Current Time: Wed Nov 05 09:37:01 EST 2025
Powered by FUDForum. Page generated in 0.05380 seconds
