Home » Modeling » GMF (Graphical Modeling Framework) » Set Location of a Node
Set Location of a Node [message #188713] Thu, 22 May 2008 07:30 Go to next message
Originally posted by: carlos.munoz.justinmind.com
Hi everyone,
When I create a type of Node, my application must create another type and
locate it in an specific place of the diagram.
I have cerate the second Node, but i don't know how to locate it where I
want in the diagram.
I have use the SetBoundsCommand but ther's no result. The Node is located
in the center of the diagram always.
Anyone knows how can I do this??
Thanks and sorry, my english isn't good, I'm from Spain.
Re: Set Location of a Node [message #189831 is a reply to message #188713] Wed, 28 May 2008 12:32 Go to previous messageGo to next message
Hi Carlos,
if I'm not wrong, in the Request you build (CreateViewRequest) to
create a new Node you can specify the location where the new View will
be created. Have you tried that?
Javi
Carlos Muñoz escribió:
> Hi everyone,
> and locate it in an specific place of the diagram.
> located in the center of the diagram always.
Re: Set Location of a Node [message #189898 is a reply to message #189831] Thu, 29 May 2008 03:17 Go to previous messageGo to next message
The CreateViewElement doesn't have a parameter for the location.
I tried this:
CompositeTransactionalCommand cc = new CompositeTransactionalCommand(
domain, DiagramUIMessages.AddCommand_Label);
PreferencesHint hint = new PreferencesHint(node.getName());
CreateViewAndElementRequest reqVEC = new
CreateViewAndElementRequest(ActivityScenariosElementTypes.Sc enarioPage_1001,
hint);
Iterator iter = reqVEC.getViewDescriptors().iterator();
CreateViewRequest.ViewDescriptor viewDescriptor =
(CreateViewRequest.ViewDescriptor)iter.next();
Point rectangle = new Point(1000,1000);
cc.compose(new SetBoundsCommand(domain,
DiagramUIMessages.SetLocationCommand_Label_Resize,
viewDescriptor,
rectangle));
try {
cc.execute(null, null);
is a SetBoundsCommand, but this is doing nothing.
Re: Set Location of a Node [message #190589 is a reply to message #189898] Mon, 02 June 2008 12:46 Go to previous message
Try reqVEC.setLocation(Point)
CreateViewRequest inherits setLocation from CreateRequest.
- Rich
On 5/29/08 3:17 AM, in article
1ad4112d2a32385e03d44f0ae3c70e39$1@www.eclipse.org, "Carlos Muñoz"
> I tried this:
> hint);
> viewDescriptor,
> rectangle));
> try {
Previous Topic:New wizard
Next Topic:No more handles [gtk_init_check() failed]
Current Time: Wed Sep 17 08:39:07 EDT 2025
Powered by FUDForum. Page generated in 0.07123 seconds
