Dragging figures does not resize editor [message #188166] |
Tue, 19 July 2005 09:36  |
Originally posted by: tkoray.aselsan.com.tr
When dragging objects outside the editors visible area, editor doesnt resize
and scrollbars doesnt update accordingly. But when I drop object to the
bottom or right side of editor, after drop editor resizes. What can be the
problem?
Thanx,
Tankut Koray
Re: Dragging figures does not resize editor [message #188538 is a reply to message #188509] |
Thu, 21 July 2005 03:38   |
I found the problem.I had been using a normal layer and changed to
freeformlayer but didint sloved the problem.
But than released my root editpart is ScableRootEditPart not
ScableFreeformRootEditPa.rt. I changed and it worked.
Now I have another problem; When drag object to the left of visible area,
viewer enarges to the negative coordinates, so when I close and reopen the
editor, it doesnt show topleft corner but show areaat location 0,0.How can
move visisble area to the topleft of editor, when I open the diagram?
Thanks for all your help,
Tankut
"Pratik Shah" <none@unknown.com> wrote in message
news:dbmdjf$lnb$1@news.eclipse.org...
> So that rectangle just gets hidden as you drag it outside the editor's
> visible area? You're not perchange mixing XY/Freeform layouts and layers,
> are you? If not, you'll just have to debug and compare the execution to
> that of the shapes example.
> "Tankut Koray" <tankut@gmail.com> wrote in message
> news:dbjpve$omd$1@news.eclipse.org...
>> I think so. I saw a rectangle while dragging...
>> news:dbj59n$tnk$1@news.eclipse.org...
>> > Are you showing the feedback figure when dragging?
>> > "Tankut Koray" <tkoray@aselsan.com.tr> wrote in message
>> > news:dbivkn$ksr$1@news.eclipse.org...
>> >> Hi,
>> > resize
>> >> the
>> >> the
>> >> problem?
>> >> Thanx,
>> >> Tankut Koray
Re: Dragging figures does not resize editor [message #188692 is a reply to message #188538] |
Fri, 22 July 2005 09:46  |
If you don't want negative coordinates, you don't have to use the "freeform"
classes. You would then have to prevent the user from dragging into
negative coordinates or else things will get lost.
news:dbnje7$n90$1@news.eclipse.org...
> Tankut
>> layers,
>>> >> Hi,
>>> > resize
>>> >> the
>>> >> be
>>> >> the
>>> >> problem?
>>> >> Thanx,
>>> >> Tankut Koray
FUDForum. Page generated in 0.04514 seconds
