Home » Newcomers » Newcomers » Liking the debugger to third-party source code
Liking the debugger to third-party source code [message #188532] Tue, 16 January 2007 21:05 Go to next message
Originally posted by: pwfarwell.yahoo.com
What's the best way to include third party source code into my Eclipse 3.2
project so that I can use the debugger to step into the code?
(The third-party source is from Hibernate; I have the version of the
Hibernate source that matches exactly its binary/jar version, so that
isn't a problem).
I want to include the Hibernate source into my project without having to
compile it each time I compile my own source.
Also, I've seen the "Attach Source" button that appears whenever you open
a compile class file in the Eclipse editor. I'm unable to use this method
due to a problem with the Maven plugin for Eclipse.
Is there some other way to include source into an Eclipse project, so that
the source is used for debugging, but doesn't need to be compiled?
Thanks in advance...
pf
Re: Liking the debugger to third-party source code [message #188553 is a reply to message #188532] Tue, 16 January 2007 23:55 Go to previous message
Originally posted by: eclipse5.rizzoweb.com
> 3.2 project so that I can use the debugger to step into the code?
> isn't a problem).
Right-click on the Hibernate JAR and choose Properties. There is an
option to specify the source location. That should automatically update
the Launch you use to debug your application so the source will be
available at runtime. Unless your debug Launch configuration does not
use the JAR that is associated with your project build classpath...
Hope this helps,
Eric
Previous Topic:AST and Writing out to another CompilationUnit
Next Topic:Shortcut to view a file in the finder
Current Time: Fri Jul 18 09:17:35 EDT 2025
Powered by FUDForum. Page generated in 0.07125 seconds
