Home » Language IDEs » Java Development Tools (JDT) » Does anyone know how to work with gcj on windows and to make an EXE
Does anyone know how to work with gcj on windows and to make an EXE [message #188098] Thu, 02 December 2004 05:39 Go to next message
Originally posted by: melko.gmx.at
Hallo!
Does anyone know how to work with gcj and to make an EXE-file out of the
java-files! And the biggest problem is to include Database-Driver so I can
searxh for the Class?!
THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188108 is a reply to message #188098] Thu, 02 December 2004 06:03 Go to previous messageGo to next message
In which way is this related to Eclipse?
melko wrote:
> Hallo!
> can searxh for the Class?!
> THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188116 is a reply to message #188108] Thu, 02 December 2004 06:20 Go to previous messageGo to next message
There is an GCJBuilder as a plugin for Eclipse, that should make exe files
out of eclipse but you must install gcj and make other preferences that I
don't know so it doesn't work on my PC!!
Therefore I need help!
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188124 is a reply to message #188116] Thu, 02 December 2004 06:57 Go to previous messageGo to next message
Ok,
so you should have at least added this information in the first place.
Other information necessary, if you want some help:
- what have you done exactly (example)
- what were the problems you encountered
A better place to ask is probably:
a) The author of the Eclipse plugin
b) The GCJ Mailingslist
Have you tried to build an .exe with gcj from the command line? If you
succeed with this, you can go on and try the same with the Eclipse plugin.
Hope that helps,
Christoph
> files out of eclipse but you must install gcj and make other preferences
> that I don't know so it doesn't work on my PC!! Therefore I need help!
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188131 is a reply to message #188124] Thu, 02 December 2004 07:22 Go to previous messageGo to next message
At first thank you for your answer!
I've tried to make an exe out of the comandline and it goes but I couldn't
involve the database driver that I need so the program is not very useful
then!
Therefore I tried to do it with this GCJBuilder but after I installed it I
wanted to reinstall GCJ so I deleted my previously folder and so now I
cannot start from the comandline and with the Plugin also?!
I must install the gcj right but i don't know how?!
I hope you can help me! THANKS
> Ok,
> Hope that helps,
> Christoph
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188149 is a reply to message #188131] Thu, 02 December 2004 08:32 Go to previous messageGo to next message
Sorry, I don't have any practical experience with gcj or GCJBuilder. I
just wanted to point you to some place where you probably can get more help.
The best guess would be the GCJ/GCC mailing list/forum/newsgroup/or
whatever they have, since you seem to have basic problems to get an .exe
(constructed with gcj) running.
> couldn't involve the database driver that I need so the program is not
> very useful then!
> I wanted to reinstall GCJ so I deleted my previously folder and so now I
>> Ok,
>> plugin.
>> Hope that helps,
>> Christoph
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188157 is a reply to message #188149] Thu, 02 December 2004 09:02 Go to previous messageGo to next message
Thank you for your advice but i was on their HP and they have no
forum/newsgroup or something else!! OK I will try to solve this problem.
Nice greetings
>> very useful then!
>>> Ok,
>>> plugin.
>>> Hope that helps,
>>> Christoph
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #188211 is a reply to message #188098] Thu, 02 December 2004 11:48 Go to previous messageGo to next message
Hi Melko,
I'm the author of the GCJBuilder plugin and your problem has nothing to
do with it.
First you should take a look at how GCJ works and the differences from
pure Java.
To explain it simply, GCJ needs to have all the references from java
classes already compiled as native (object) code in order to perform
dynamic loading of a class.
This issue is affecting you most likely, as you are using Driver manager
to load your db specific driver dynamicly.
A simple scenario looks like this.
you should compile the driver jar as object code
i.e. gcj -c mysqljdbc.jar
this will produce a file named mysqljdbc.o which contains native code.
then say your connection class is called connection.java, pls mind the
commented lines before "com.mysql.jdbc.Driver dummyRef;"
it should look like this:
[start - connection.java ]
package com.stardeveloper.example;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.SQLException;
public class connection{
/* this line will force gcj linker to include
native code from drivers object code by simply referencing
drivers class.
public static void main(String args[]) {
Connection con = null;
try {
// mind the quoted driver name, the compiler doens't know about
// that class and we have to give it hints as seen above
Class.forName("com.mysql.jdbc.Driver").newInstance();
con = DriverManager.getConnection("jdbc:mysql:///test",
"root", "secret");
if(!con.isClosed())
System.out.println("Successfully connected to " +
"MySQL server using TCP/IP...");
} catch(Exception e) {
System.err.println("Exception: " + e.getMessage());
} finally {
try {
if(con != null)
con.close();
} catch(SQLException e) {}
[ end - connection.java]
you should compile it with
gcj -c --classpath=mysqljdbc.jar connection.java
then last step is to link both '.o' files and create an exe file:
gcj --main=connection connection.o mysqljdbc.o -o mysql.exe
now you'll have mysql.exe ready for run
thats it.
GCJBuilder will simplify your work but you must understand the basics first.
take care,
Radu Racariu
melko wrote:
> Hallo!
> THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189074 is a reply to message #188211] Thu, 09 December 2004 07:56 Go to previous messageGo to next message
Hello Radu!!
Thank you for your help! But I didn't understand should I change something
in my sourcecode? Or in the Eclipse-Hierarchie?! *g Because in Eclipse I
involved the drivers as user library named "Database" and in this library
the different jar-files!
And an other problem:
I have deleted the complete folder in which the gcc and gcj files were
and I haven't the download-files anymore. So I have downloaded and
installed new versions of gcj but the bat-file that worked before doesn't
work again. Here is the sourcecode, maybe you can help me:
@echo off
SETLOCAL
echo Name des Hauptprogramms...
set MAIN=Main
echo Festlegen der Umgebungsvariablen...
PATH C:\gcc\bin;C:\gcc\i686-pc-mingw32\bin;%PATH%
set SWT_DIR=C:\gcc\swt
echo Erstellen der Ordner...
if exist bin rmdir /S /Q bin
if exist obj rmdir /S /Q obj
if exist include rmdir /S /Q include
mkdir bin
cd bin
mkdir resources
cd ..
mkdir obj
mkdir include
echo Compilierung zu Java-Bytecode...
gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin src\com\rssoft\gui\*.java
gcj -C -fCLASSPATH=bin;src -g0 -Os -d bin src\com\rssoft\gui\dialog\*.java
src\com\rssoft\gui\functions\*.java
echo Erzeugen eines JAR-Archives...
xcopy /Q src\resources\*.* .\bin\resources
cd bin
jar cf %MAIN%.jar .\com\rssoft\gui\*.class .\com\rssoft\gui\dialog\*.class
\com\rssoft\gui\functions\*.class .\resources\*.*
move %MAIN%.jar ..\include
cd ..
echo Objekt Datei erstellen...
gcj --classpath=obj;bin;%SWT_DIR%\swt.jar -fjni -g0 -Os -c
include\%MAIN%.jar -o obj\%MAIN%.o
echo Library Datei erstellen...
cd obj
ar -crs lib%MAIN%.a *.o
move lib%MAIN%.a ..\include
cd ..
echo Compilierung zur EXE-Datei...
gcj -mwindows --main=com.rssoft.gui.%MAIN% -fjni -g0 -Os -s -o %MAIN%.exe
obj\*.o include\*.a -L%SWT_DIR% -lswt
echo Datei umbenennen...
if exist JTalk.exe del JTalk.exe
ren %MAIN%.exe JTalk.exe
echo Starte ResourceHacker...
ResHacker
if exist JTalk_original.exe del JTalk_original.exe
echo EXE-Datei komprimieren...
upx.exe --best JTalk.exe
REM mew11.exe JTalk.exe -lzma_special
echo.
echo Fertig!
ENDLOCAL
pause
I get this error-message:
Main.java:0: fatal error: reading class com.rssoft.gui.Main$GUIActions for
the second time from .\com\rssoft\gui\Main$GUIActions.class
compilation terminated.
ar: *.o: Invalid argument
gcj: obj\*.o: Invalid argument
But I don't understand why. I hope you can help me!! THANKS!
Nice greetings from austria.
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189450 is a reply to message #188211] Mon, 13 December 2004 02:14 Go to previous messageGo to next message
Hallo!
It doesn't work that way. I don't know why, but I did all this that you
wrote here and it doesn't work. At first I need more different
database-driver and when I want to compile my drivers it can only compile
SQLBaseJDBC.jar the other ones doesn't go but if I compile this one and
make the exe-file as you wrote it goes but I cannot make a connection.
I hope someone can help me!! THANKS
nice greetings.
Radu Racariu wrote:
> Hi Melko,
> do with it.
> pure Java.
> drivers class.
> try {
> "root", "secret");
> if(!con.isClosed())
> } finally {
> try {
> if(con != null)
> con.close();
> thats it.
> take care,
> Radu Racariu
> melko wrote:
>> Hallo!
>> THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189459 is a reply to message #188211] Mon, 13 December 2004 02:47 Go to previous messageGo to next message
I get this error-message if I do it the same way you wrote:
C:\...\Temp/ccCkaaaa.o<.text+0x45>: In function `main':
C:/.../Temp/ccEdaaaa.i: undefined reference to
`com::rssoft::test::connection::class$'
THanks
Radu Racariu wrote:
> Hi Melko,
> do with it.
> pure Java.
> drivers class.
> try {
> "root", "secret");
> if(!con.isClosed())
> } finally {
> try {
> if(con != null)
> con.close();
> thats it.
> take care,
> Radu Racariu
> melko wrote:
>> Hallo!
>> THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189607 is a reply to message #188211] Tue, 14 December 2004 07:10 Go to previous messageGo to next message
sorry there was an error in my example,
pls remove the package line ("package com.stardeveloper.example;") :).
regards
Radu Racariu wrote:
> Hi Melko,
> do with it.
> pure Java.
> drivers class.
> try {
> "root", "secret");
> if(!con.isClosed())
> } finally {
> try {
> if(con != null)
> con.close();
> thats it.
> first.
> take care,
> Radu Racariu
> melko wrote:
>> Hallo!
>> the java-files! And the biggest problem is to include Database-Driver
>> so I can searxh for the Class?!
>> THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189702 is a reply to message #189607] Wed, 15 December 2004 03:59 Go to previous messageGo to next message
Thank you for your answer but the problem is somewhere else! I have no
mysql driver and I needn't. I need all other drivers, like
SQLBaseJDBC.jar, ojdbc14.jar, jt400.jar and so on but when I want to make
an object out of them only the SQLBaseJDBC.jar goes so I made my script on
this driver based. Now the connection.java file looks like this:
jdbc.gupta.sqlbase.SqlbaseDriver dummyRef;
try {
Class.forName("jdbc.gupta.sqlbase.SqlbaseDriver").newInstance();
con =
DriverManager.getConnection("jdbc:sqlbase://192.168.192.252:2160/database","secret",
"secret");
if(!con.isClosed())
System.out.println("Successfully connected to SQLBase");
} finally {
try {
if(con != null)
con.close();
and the *.bat file looks like this:
@echo off
SETLOCAL
echo make SQLBase-Object...
gcj -c SQLBaseJDBC.jar
echo make connection-Object...
gcj -c --classpath=SQLBaseJDBC.jar connection.java
echo make *.exe...
gcj --main=connection SQLBaseJDBC.o connection.o -o test.exe
echo.
echo End!
pause
And i get this test.exe without any errors but I cannot make any
connection!!
I get the error-message: "No driver found for jdbc:sqbase://...."
I must make an exe-file because I work on a program that should be similar
to the SQLTalk, if you know what it is, it's a
database-communication-program and so it should be easy transportable. It
also contains SWT-Widgets but this problem I have solved, so I get a
window and all but no connection!!!
Thank you for your help.
nice greatings from very cold austria
> regards
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189909 is a reply to message #188098] Fri, 17 December 2004 05:56 Go to previous messageGo to next message
IMPORTANT!!
Who has deleted the other posts that where here under this point?!? There
were min. 10 posts?! Where are they?!
Thank you for information!
nice greetings!
melko wrote:
> Hallo!
> THANKS
Re: Does anyone know how to work with gcj on windows and to make an EXE [message #189923 is a reply to message #189909] Fri, 17 December 2004 06:52 Go to previous message
Originally posted by: hcs33.egon.gyaloglo.hu
I don't think that messages was deleted on the server. If you use Outlook
Express as your news reader, look at Tools->Options->Maintenance and see
whether there is a setting "Delete new messages..." is checked.
HTH,
Csaba
"melko" <melko@gmx.at> wrote in message news:cpue0q$it4$1@www.eclipse.org...
> IMPORTANT!!
> nice greetings!
> melko wrote:
> > Hallo!
can
> > THANKS
Previous Topic:Ctrl+Shift+F not working on Linux
Next Topic:Can't resolve class path in launching java application without a project (code)
Current Time: Thu Nov 06 10:49:33 EST 2025
Powered by FUDForum. Page generated in 0.65318 seconds
