Home » Archived » BIRT » Master- and Subreport with two scripted datasources with parameters
Master- and Subreport with two scripted datasources with parameters [message #187674] Mon, 28 August 2006 16:58 Go to next message
Originally posted by: thmwg.web.de
Hi together,
IŽve a problem which drives be crazy. I try to generate a
master-/subreport with two scripted datasources and I do not know how to
pass the parameter from the master to the subreport. Here is my code
Scripted Source #1
open :
modelClass = new Packages.de.thmwg.scripted.ModelReport();
models = modelClass.readModel();
totalModels = models.size();
currentModel = 0;
fetch :
if (currentModel >= totalModels) {
return (false);
var model = models.get(currentModel);
row["oidModel"] = model["oidModel"];
row["strBezeichnung"] = model["strBezeichnung"];
params["paramsModel"] = row["oidModel"];
currentModel = currentModel+1;
return (true);
And the scripted Datasource #2
open :
fgClass = new Packages.de.thmwg.scripted.ModelReport();
fgs = fgClass.readFG(params["paramsModel"]);
totalFGs = fgs.size();
currentFG = 0;
fetch :
if (currentFG >= totalFGs) {
return (false);
var fg = fgs.get(currentFG);
row["oidFG"] = fg["oidFG"];
row["strFGBezeichnung"] = fg["strFGMasterBezeichnung"];
currentFG = currentFG+1;
return (true);
Within the scripted datasource#1 I try to pass the parameter by
But when generating only the first "oidModel" is passed to the params.
Has anybody a idea how to pass parameters between two scripted
datasources? IŽve also read all informations give in FAQŽs, newgroups etc.
Thanks.
Greetings
Thomas
Re: Master- and Subreport with two scripted datasources with parameters [message #187682 is a reply to message #187674] Mon, 28 August 2006 17:16 Go to previous messageGo to next message
Thomas,
Are you passing data that has been changed by the first query?
If 'yes', then I don't know how to do it.
If 'no', then you should be able to pass the same thing to both,
using the 'beforeOpen' method to change the query before it is executed.
If 'no', then say so and I will supply the code.
Ty
Re: Master- and Subreport with two scripted datasources with parameters [message #187780 is a reply to message #187682] Tue, 29 August 2006 06:09 Go to previous message
Hi Tyrone,
thanks for reply. No - I have a master-/subreport. For each row in
datasource#1 I got an ID and this ID should be passes to the second
datasource#2 as a parameter. That means, when the first query of dataset#1
is called then the parameter idModel is passed to dataset#2 and dataset#2
is called.
For example
1. Customer Meier
INVOICE :
1. Computer
2. Laptop
3. Book
2. Customer Mueller
INVOICE :
1. Notebook
2. Router
I hope IŽll understand my problem. Any suggestions solving the problem?
Thomas
Tyrone Hed wrote:
> Thomas,
Ty
Hi together,
Scripted Source #1
open :
currentModel = 0;
fetch :
return (false);
return (true);
open :
currentFG = 0;
fetch :
return (false);
return (true);
Thanks.
Greetings
Thomas
Previous Topic:Time-scale x axis supported?
Next Topic:Birt Data Engine
Current Time: Sun Nov 09 10:28:31 EST 2025
Powered by FUDForum. Page generated in 0.04024 seconds
