Home » Language IDEs » C / C++ IDE (CDT) » Bookmarks: difference between C and C++?
Bookmarks: difference between C and C++? [message #185604] Wed, 21 February 2007 13:57 Go to next message
When using bookmarks,is there a difference between C and C++? I'm able
to set bookmarks in a .cpp or .hpp file, but not in a .c or .h file.
What's the difference?
Best rgds,
--Geert
Re: Bookmarks: difference between C and C++? [message #185612 is a reply to message #185604] Wed, 21 February 2007 14:06 Go to previous messageGo to next message
Geert Vancompernolle wrote:
> Best rgds,
> --Geert
Same problem is there for the outline: works with .cpp or .hpp, not with
..c or .h files.
Best rgds,
--Geert
Re: Bookmarks: difference between C and C++? [message #185827 is a reply to message #185612] Fri, 23 February 2007 02:14 Go to previous messageGo to next message
Geert,
my guess is you have created a Managed Make C++ project. This project type
does not treat .c as source file out of the box (not sure about .h, though).
So when you open a .c file you don't get the C Editor but rather a simple
TextEditor, which does not feed the outline.
Not sure if the text editor supports bookmarks though.
Norbert
Re: Bookmarks: difference between C and C++? [message #185925 is a reply to message #185827] Fri, 23 February 2007 13:15 Go to previous messageGo to next message
Norbert Ploett wrote:
> Geert,
> Regards,
> Norbert
Well, you're correct Norbert in that it was a standard C++ project. But
the things you mentioned will be equally true for both a managed as well
It's anyhow weird such project treats .c files differently...
But ok, if that's the case, so be it, isn't it?
Thanks for your response.
Best rgds,
--Geert
Re: Bookmarks: difference between C and C++? [message #187285 is a reply to message #185925] Thu, 08 March 2007 06:02 Go to previous messageGo to next message
Hi Geert,
this was much-disputed in the mailing list sometime ago. Different usecases
require different solutions ...
You can change the default per project (project properties --> C/C++ File
Types) or per workspace (Window -> Preferences -> C/C++ -> File Types)
Norbert
Re: Bookmarks: difference between C and C++? [message #187346 is a reply to message #187285] Thu, 08 March 2007 14:12 Go to previous messageGo to next message
I know a large number of mixed C/C++ projects, and C compatibility was
an important design requirement of C++...
So why would the CDT designers choose to make C++ projects not work with
C files? Baffled,
- Scott
Re: Bookmarks: difference between C and C++? [message #187566 is a reply to message #187346] Thu, 15 March 2007 09:31 Go to previous messageGo to next message
Originally posted by: deliciap.cradle.com
I too am interested in Scott's question.
Is there any particular reason why CDT decided to treat .c files ONLY as C
sources and not C++ sources?
I have a toolchain based on the MBS.
Is it safe if I have .c files are recognised by both, C & C++ projects?
Delicia.
"Scott Bronson" <brons_eclipsepost@rinspin.com> wrote in message
news:espn29$gc1$1@utils.eclipse.org...
>> usecases
> C files? Baffled,
> - Scott
Re: Bookmarks: difference between C and C++? [message #187574 is a reply to message #187566] Thu, 15 March 2007 10:30 Go to previous message
At the root of this may be the fact that there are separate parsers for C and
C++. C is not a proper subset of C++ and there were many performance and
correctness issues that were solved when the parser was split in the 3.0 time frame.
-Andrew
> Delicia.
>>> usecases
>> C files? Baffled,
>> - Scott
Previous Topic:code spanning multiple projects
Next Topic:Crash when debugging a shared library
Current Time: Thu Nov 06 17:24:38 EST 2025
Powered by FUDForum. Page generated in 0.04803 seconds
