Home » Language IDEs » ServerTools (WTP) » Creating an XML Document (and more) from an InputStream?
Creating an XML Document (and more) from an InputStream? [message #186534] Thu, 18 January 2007 18:50 Go to next message
Originally posted by: fakeaddress.brainkandy.org
I am trying to write a test whereby I pass an IDOMDocument to one of my
classes. The problem is I don't know how to build an IDOMDocument from
an XMLString.
I've tried this:
InputStream is = new ByteArrayInputString(xmlText.getBytes());
XMLDocumentLoader loader = new XMLDocumentLoader();
IEncodedDocument doc = loader.createNewStructuredDocument(null, is);
This is as far as I was able to get, but I get an exception:
java.lang.ExceptionInInitializerError
at org.eclipse.core.runtime.FileLocator.find(FileLocator.java:8 6)
at org.eclipse.core.runtime.Platform.find(Platform.java:885)
and now I'm stuck.
Truth be told, I need more than that, I need an IDOMDocument, and also
need the affiliated IDOMModel and IStructuredDocument (though I believe
I can successfully mock out IDOMModel and IStructuredDocument)
Any suggestions?
Thanks, Robert
Re: Creating an XML Document (and more) from an InputStream? [message #186691 is a reply to message #186534] Mon, 22 January 2007 03:53 Go to previous messageGo to next message
Robert Konigsberg wrote:
> Hello,
> an XMLString.
> I've tried this:
> and now I'm stuck.
> Any suggestions?
> Thanks, Robert
The best way to go is to start with the IStructuredModel using the
org.eclipse.wst.sse.core.internal.provisional.IModelManager. getModelForRead(String
id, InputStream inStream) (ore getModelForEdit) method. You can
obtain an IModelManager instance from
org.eclipse.wst.sse.core.StructuredModelManager. The "id" value
must be unique, should probably end with ".xml" just to give an
extra hint of the content type, and you absolutely must call the
corresponding IStructuredModel.releaseFromRead() (or
releaseFromEdit) method when you're done with it. IDOMModel is a
subinterface of IStructuredModel, and you can retrieve the
IDOMDocument and IStructuredDocument from there.
Nitin Dahyabhai
Structured Source Editor
Re: Creating an XML Document (and more) from an InputStream? [message #186750 is a reply to message #186691] Mon, 22 January 2007 14:05 Go to previous messageGo to next message
Thank you Nitin. I will give this a try before too long.
>> Hello,
>> my classes. The problem is I don't know how to build an IDOMDocument
>> from an XMLString.
>> I've tried this:
>> and now I'm stuck.
>> believe I can successfully mock out IDOMModel and IStructuredDocument)
>> Any suggestions?
>> Thanks, Robert
> id, InputStream inStream) (ore getModelForEdit) method. You can obtain
> org.eclipse.wst.sse.core.StructuredModelManager. The "id" value must be
> unique, should probably end with ".xml" just to give an extra hint of
> the content type, and you absolutely must call the corresponding
> IStructuredModel.releaseFromRead() (or releaseFromEdit) method when
> you're done with it. IDOMModel is a subinterface of IStructuredModel,
> and you can retrieve the IDOMDocument and IStructuredDocument from there.
> Nitin Dahyabhai
Re: Creating an XML Document (and more) from an InputStream? [message #186943 is a reply to message #186750] Wed, 24 January 2007 22:49 Go to previous messageGo to next message
Nitin,
I am stuck once more. Unfortunately, if I start my first test with:
IModelManager mgr = StructuredModelManager.getModelManager()
but this results in a NullPointerException in getModelManager:
"int state = localBundle.getState()";
localBundle is not initialized (comes from
Platform.getBundle(SSECorePlugin.ID))
Now I have looked at some of the sample unit tests in the CVS
respository, and tried to initialize my project in a similar way, but
only resulting in yet more exceptions.
Thoughts?
Thanks, Robert
>>> Hello,
>>> from an XMLString.
>>> I've tried this:
>>> and now I'm stuck.
>>> also need the affiliated IDOMModel and IStructuredDocument (though I
>>> Any suggestions?
>>> Thanks, Robert
>> be unique, should probably end with ".xml" just to give an extra hint
>> of the content type, and you absolutely must call the corresponding
>> Nitin Dahyabhai
Re: Creating an XML Document (and more) from an InputStream? [message #187069 is a reply to message #186943] Fri, 26 January 2007 07:56 Go to previous messageGo to next message
> Nitin,
> Thoughts?
The most likely reason is that you've added org.eclipse.wst.sse.core
to the Java Build Path, but not added it to your list of plug-in
dependencies.
Nitin Dahyabhai
Re: Creating an XML Document (and more) from an InputStream? [message #187149 is a reply to message #187069] Fri, 26 January 2007 14:18 Go to previous messageGo to next message
Unfortunately, it was already in my list of plug-in dependencies. My
Java build path is pretty clean, actually. No required projects, no
additional source, and my libraries are limited to the JRE (1.5.0_06,
incidentally), JUnit 3.8.1 and Plug-in dependencies. Hmm...
>> Nitin,
>> Thoughts?
> The most likely reason is that you've added org.eclipse.wst.sse.core to
> the Java Build Path, but not added it to your list of plug-in dependencies.
> Nitin Dahyabhai
Re: Creating an XML Document (and more) from an InputStream? [message #187349 is a reply to message #187149] Tue, 30 January 2007 13:31 Go to previous messageGo to next message
>>> Nitin,
>>> Thoughts?
>> dependencies.
>> Nitin Dahyabhai
Is there, by chance, someone who has a simple demo that creates an XML
document starting with the model manager? As I've mentioned, I've had
some strange trouble with this problem.
Thanks, Robert
Re: Creating an XML Document (and more) from an InputStream? [message #187541 is a reply to message #187149] Mon, 05 February 2007 12:20 Go to previous messageGo to next message
Nitin, the other most likely reason is that I was running the test as a
junit JUnit Test and not a JUnit Plug-in Test. :)
Lesson learned. Thanks for your help; I am finally moving forward with
tests.
Robert
>>> Nitin,
>>> Thoughts?
>> dependencies.
>> Nitin Dahyabhai
Service Startup [message #188308 is a reply to message #187149] Tue, 20 February 2007 08:16 Go to previous message
Is there any "standard" way of implementing startup functions for
WTP/Tomcat? I need to do some stuff on startup *before* service becomes
available. I am using bottom-um generated services and would prefere
solution where startup code is not overwritten each time I re-generate
services. Any toughts?
Thx
Previous Topic:out of sync using a vfat filesystem?
Next Topic:Announcing WTP 1.5.3
Current Time: Sat Jul 26 20:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.04685 seconds
