Home » Language IDEs » Java Development Tools (JDT) » How to add/update an environment variable without Eclipse restart?
How to add/update an environment variable without Eclipse restart? [message #1867479] Wed, 26 June 2024 11:57 Go to next message
I am currently struggling with setting up environment variable for Eclipse in macOS. Is there a standard/recommended way to do so? Ideally, to set it without restarting Eclipse itself. The only way I know is to use "Info.plist", but that would need Eclipse restart. Are there any other ways?
Bonus points question: is there a way to set up environment variable for Eclipse, that is a result of a bash command? I need it for setting my authorization token for AWS code artifact:
export CODEARTIFACT_AUTH_TOKEN=$(aws codeartifact get-authorization-token ...)
The reason behind it is that that token expires every 24 hours...
Forgot to mention that I have also tried "Environment Variables Preference Page" Eclipse plugin, but it does not seem to work.
Thank you in advance!
UPDATE: I posted the same question on Stack Overflow.
[Updated on: Thu, 25 July 2024 00:16] by Moderator
Re: How to add/update an environment variable without Eclipse restart? [message #1871196 is a reply to message #1867479] Tue, 17 September 2024 22:39 Go to previous messageGo to next message
My issue is the same. Anyone find any solution??
Re: How to add/update an environment variable without Eclipse restart? [message #1871859 is a reply to message #1871196] Mon, 14 October 2024 03:32 Go to previous messageGo to next message
Have you tried using the "Run Configurations" option in Eclipse to set environment variables?
Re: How to add/update an environment variable without Eclipse restart? [message #1872258 is a reply to message #1871859] Fri, 25 October 2024 15:16 Go to previous messageGo to next message
I have tried all the reflections but I still have the same problem , any solution? I see that many of us have the same problem but no solution yet
I will try to see a youtube tutorial maybe I will find a result.
Tutuapp
[Updated on: Thu, 21 November 2024 17:41] by Moderator
Re: How to add/update an environment variable without Eclipse restart? [message #1872791 is a reply to message #1872258] Tue, 19 November 2024 23:24 Go to previous message
My problem is similar, has anyone found a solution?
Previous Topic:m2eclipse (Maven Integration): how to see actual Maven output or customize builds?
Next Topic:Server DTLS X509, client certificate no trust
Current Time: Tue Jul 22 02:15:19 EDT 2025
Powered by FUDForum. Page generated in 0.05771 seconds
