Home » Language IDEs » C / C++ IDE (CDT) » External scanner info generator
External scanner info generator [message #186314] Wed, 28 February 2007 04:11 Go to next message
Originally posted by: breezsea.gmail.com
I want to set PATH variable only in Eclipse CDT, but not in Windows (I use
Cygwin and have problems with installation of PosgreSQL with "real" PATH
variable). But when I specify in Window->Preferences->C/C++->PathEntry
variables variable PATH with location H:\Cygwin\bin, I get warnings:
"Error launching external scanner info generator (gcc -E -P -v -dD
H:/Program Files/Eclipse
CDT/eclipse/workspace/.metadata/.plugins/org.eclipse.cdt.mak e.core/specs.c) "
on each of my projects. But compilation of projects is OK.
I tried to set PATH variable on Properties of project (in Environment),
but results were the same. What's wrong?
Re: External scanner info generator [message #186836 is a reply to message #186314] Thu, 01 March 2007 15:38 Go to previous messageGo to next message
Is this bug of Eclipse CDT?
Re: External scanner info generator [message #187243 is a reply to message #186314] Wed, 07 March 2007 03:49 Go to previous messageGo to next message
Can anyone answer my question? Or my question is incorrect?
Re: External scanner info generator [message #187257 is a reply to message #186314] Wed, 07 March 2007 04:21 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
I suspect this is because it is using "gcc" but I doubt your compiler is called
"gcc" but something like "xxx-yyy-zzz-gcc". Try changing the 'compiler
invocation command' in your Project Properties (C/C++ Make Project->Discovery
Options) to the name of your compiler.
HTH
Derek
> use Cygwin and have problems with installation of PosgreSQL with "real"
> PATH variable). But when I specify in
> Window->Preferences->C/C++->PathEntry variables variable PATH with
Re: External scanner info generator [message #187272 is a reply to message #187257] Wed, 07 March 2007 07:16 Go to previous messageGo to next message
called
Project->Discovery
No, my compiler is called gcc. There are file gcc.exe in Cygwin\bin
directory and cygwin Bash accept command gcc, i.e. gcc --version give me
information about version of compiler.
Re: External scanner info generator [message #187278 is a reply to message #187272] Wed, 07 March 2007 07:24 Go to previous message
In that case, try putting /path/to/gcc in the discovery options. I think you can
also use an eclipse variable if you don't want to hard code it.
e.g. set MYPATH in your environment and use
${env-var:MYPATH}/gcc
in the discovery option.
Derek
Thunder wrote:
> called
> Project->Discovery
Previous Topic:Post-build Steps
Next Topic:Adding a context menu visible in all editors - Please help
Current Time: Sat Jul 26 06:16:12 EDT 2025
Powered by FUDForum. Page generated in 0.29416 seconds
