Home » Modeling » TMF (Xtext) » Custom IResourceDescriptionStrategy not working as expected
Custom IResourceDescriptionStrategy not working as expected [message #1872644] Tue, 12 November 2024 07:10 Go to next message
In my project I've implemented my own IResourceDescriptionStrategy, based on DefaultResourceDescriptionStrategy, overriding createEObjectDescriptions() to add an AliasedEObjectDescription for some of the EObjectDescriptions created by the default implementation. The unexpected behaviour is that I can use an AliasedEObjectDescription's QualifiedName to refer to the associated EObject only in a different file than the one that contains the text that, when parsed, creates that EObject.
For example, I have used my IResourceDescriptionStrategy implementation to add an unquoted alias for every EObject that has got a name wrapped in single quotation marks. In my DSL's editor the following does not work:
package a {
	item 'z';
package b {
	reference a::z;
and I get the "Couldn't resolve reference to Item a::z" error. If I copy paste the whole "package b {...}" into a different file, the model suddenly becomes valid.
Within the same file, I am forced to write a::'z'.
What am I missing? Is this intended behaviour, and if so, how can I get the aliases to work even within the same file?
Thanks!
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872647 is a reply to message #1872644] Tue, 12 November 2024 10:10 Go to previous messageGo to next message
this is intentional. local scope is not coming from index but by impl
of ImportNamespaceAwareLocalScopeProvider
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872650 is a reply to message #1872647] Tue, 12 November 2024 10:22 Go to previous messageGo to next message
Thanks. I guess that to customise this to my needs I shall override internalGetAllDescriptions() in my custom ImportedNamespaceAwareLocalScopeProvider to somehow add my AliasedEObjectDescriptions to the allDescriptions iterable before it is used to initialise the MultimapBasedSelectable, correct?
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872653 is a reply to message #1872650] Tue, 12 November 2024 10:25 Go to previous messageGo to next message
depends on what you actually want to achive. (this does not come clear from your initial post)
[Updated on: Tue, 12 November 2024 10:26] by Moderator
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872662 is a reply to message #1872653] Wed, 13 November 2024 02:06 Go to previous messageGo to next message
Christian Dietrich wrote on Tue, 12 November 2024 15:25
In my DSL, items can optionally have their name wrapped in quote marks. I want to be able to refer to all items whose name is wrapped in quote marks, using not only their original wrapped name, but also their name without quote marks. And of course I want to be able to do so both from within the same file, and from other files.
What I described in my first post is the first reasonable approach I managed to implement and (mostly) get to work, but I'm of course open to advice on how to improve it and/or make it more sound.
Thank you very much, as usual!
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872671 is a reply to message #1872662] Wed, 13 November 2024 16:08 Go to previous messageGo to next message
Imwould have expected to do this on pure grammar or value converter level
So myself=[Thing|DatatypeOrTerminalRuleToUse]
With DatatypeOrTerminalRuleToUse: STRING|ID; + a value converter that strips the quotes
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872677 is a reply to message #1872671] Thu, 14 November 2024 08:06 Go to previous messageGo to next message
Christian Dietrich wrote on Wed, 13 November 2024 21:08
Thanks for the advice, I had already looked into ValueConverters in the past but haven't ever actually used them. However, my understanding is that with a ValueConverter that strips the quote marks, I would be able to refer to my elements only with their unquoted names, which is not what I want (I want both options, i.e. quoted and unquoted, to be valid and usable). Am I wrong?
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872692 is a reply to message #1872677] Thu, 14 November 2024 15:14 Go to previous messageGo to next message
Well
If you have "x" or x in the file the value converter will make x out of it.
This is what the scope provider be asked
Re: Custom IResourceDescriptionStrategy not working as expected [message #1872707 is a reply to message #1872692] Fri, 15 November 2024 07:45 Go to previous message
Christian Dietrich wrote on Thu, 14 November 2024 20:14
Well
Oh, I think I've only now understood your point!
The value converter will map both 'x' and x to x when it processes the name of an entity (which is parsed using a custom rule and assigned as "name=Name" in my entities' rules), but it will also do the same whenever a cross-reference making use of the Name rule is parsed, so both variants of the name are effectively mapped to the unquoted variant in both contexts and thus it will be possible to resolve the cross-references both with and without quotes.
(sorry if I've worded this post slightly imprecisely, I've written it in a hurry)
Next week I'll try to implement this approach.
Previous Topic:Xtext 2.37.0.M2 for Eclipse 2024-12 M3
Next Topic:Xtext 2.37.0 is released
Current Time: Sun Aug 31 02:45:56 EDT 2025
Powered by FUDForum. Page generated in 0.03782 seconds
