Home » Newcomers » Newcomers » parallel computing(What happened to the Eclipse for Scientific Computing package?)
parallel computing [message #1871961] Thu, 17 October 2024 01:41 Go to next message
Hi! I am new to Eclipse and I would like to use it for parallel computing with MPI on a Linux machine. I saw that there was a nice package that one could install called Eclipse for Scientific Computing but it does not seem to be anymore an option with the Installer. Is it still a way to install it? And more relevant, was the latest version stable? If not, is it there any alternative?
I found a lot of material online about the Parallel Tools Platform that the package incorporated but I don't know how to retrieve it and if it is a good idea at all since the project was archived few years ago
Re: parallel computing [message #1872009 is a reply to message #1871961] Thu, 17 October 2024 10:37 Go to previous message
It's probably not a good idea to rely on archived projects. The installer by default shows only the latest releases. If you switch to advanced mode (menu button on the upper right) you can install any version of the products including older discontinued products.
Previous Topic:Ongoing problems with lack of icon control
Next Topic:How to set the linking parameter to put data in a special section
Current Time: Sun Aug 31 02:44:30 EDT 2025
Powered by FUDForum. Page generated in 0.08444 seconds
