Portable JAVA+DSL installer with ecoretools diagram editor [message #1871823] |
Sat, 12 October 2024 15:43  |
The basic need is to make a portable installation (for Linux PC's without internet connection) which include the Java+DSL distribution and the diagram editor " Ecore Diagram Editor 3.4.0.202201202026 org.eclipse.emf.ecoretools.design.feature.group Eclipse Modeling Project"
1) I tried to set up an Oomph based installer with the eclipse Java- DSL-installer as basis. Java and DSL alone worked.
When adding the diagram editor, Oomph failed when pressing "finish":
Adding metadata repository http://eclipse-cs.sourceforge.net/update/
ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at http://mbarbero.github.io/fr.obeo.releng.targetplatform/p2/.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:417)
Apparently because mbarbero.github.io truly doesn't exist and has been taken over by https://github.com/jonahgraham/f?
First, I don't know if this is true (that the new site is equivalent to the old one), Second, I prefer to get SW from eclipse and not github and third, I failed to identify where to modify the Oomph files to get this from another source. (I also don't know if it could be skipped. It doesn't sound much like "diagram editor".
I don't know if this is just the first problem when trying to make the Oomph installer.
2) Once the Oomph installer is made, can I then just copy to the non-internet connected target computer, or will it fail trying to update SW?
3) Is there a way for Oomph to use the diagram editor (or any other SW) installed in another eclipse installation instead of downloading from repos? I prefer to use SW from he working installation, It was not straight forward to get it to work,
FUDForum. Page generated in 0.04230 seconds
