Home » Eclipse Projects » Eclipse Platform » IntroPart is null when show welcome screen from Window>Show View > Others.. > General > (I got error when update new product ide to Eclipse 2023-09)
IntroPart is null when show welcome screen from Window>Show View > Others.. > General > [message #1863904] Tue, 05 March 2024 03:41 Go to next message
java.lang.NullPointerException: Cannot invoke "org.eclipse.ui.intro.IIntroPart.getTitle()" because "this.introPart" is null
at org.eclipse.ui.internal.ViewIntroAdapterPart.init(ViewIntroAdapterPart.java:180)
at org.eclipse.ui.internal.ViewReference.initialize(ViewReference.java:129)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:344)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:976)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:938)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:138)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:385)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:311)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:203)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:995)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:544)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:47)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:528)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:73)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:763)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:712)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:110)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:183)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:5249)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:208)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:206)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:123)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:677)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:161)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:92)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:314)
at org.eclipse.e4.ui.workbench.addons.cleanupaddon.CleanupAddon.subscribeRenderingChanged(CleanupAddon.java:334)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:64)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:656)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:625)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:796)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:764)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:686)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:681)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1261)
at org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1248)
at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1236)
at org.eclipse.ui.internal.WorkbenchPage.lambda$13(WorkbenchPage.java:4252)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4250)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4234)
at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:135)
at org.eclipse.ui.handlers.ShowViewHandler.openOther(ShowViewHandler.java:114)
at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:81)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:99)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:298)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:232)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:174)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:165)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:485)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:389)
at org.eclipse.ui.internal.ShowViewMenu$1.run(ShowViewMenu.java:126)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:474)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:580)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:414)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4645)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1547)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1532)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1325)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4412)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3988)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1155)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:342)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:648)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:555)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:173)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:208)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:651)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:588)
at org.eclipse.equinox.launcher.Main.run(Main.java:1459)
Re: IntroPart is null when show welcome screen from Window>Show View > Others.. > General & [message #1863916 is a reply to message #1863904] Tue, 05 March 2024 12:29 Go to previous messageGo to next message
The title is incomplete in that it doesn't say which view. I assume it's the Welcome view. I can't reproduce the in a newer installation, but if you can reproduce it with the 2024-03 release available next Wednesday, please report the details here:
https://github.com/eclipse-platform/eclipse.platform.ui
Re: IntroPart is null when show welcome screen from Window>Show View > Others.. > General & [message #1863936 is a reply to message #1863916] Thu, 07 March 2024 04:09 Go to previous messageGo to next message
Hi Ed Merks
If I want to show the default welcome screen,
Do I need to configure anything in my plugin?
I do not need to follow this guide (https://help.eclipse.org/latest/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Fguide%2Fua_intro_minimal.htm)
right?
Re: IntroPart is null when show welcome screen from Window>Show View > Others.. > General & [message #1863956 is a reply to message #1863936] Thu, 07 March 2024 21:25 Go to previous messageGo to next message
One more question:
Do we have any configuration to handle a clicked event on the welcome screen?
I want to handle this even the same as this configuration:
<extension
         point="org.eclipse.ui.commands">
      <command
            defaultHandler="com.toanle.example.ShowIntro"
            id="com.toanle.example.ShowIntro"
            name="welcome">
      </command>
</extension>
http://
[Updated on: Thu, 07 March 2024 23:49] by Moderator
Re: IntroPart is null when show welcome screen from Window>Show View > Others.. > General & [message #1863960 is a reply to message #1863956] Fri, 08 March 2024 01:54 Go to previous messageGo to next message
I don't know the details of the intro/welcome infrastructure. I doubt anyone reading this forum can help with that in detail. The thing is basically like documentation with hyperlinks so you can control the content...
Re: IntroPart is null when show welcome screen from Window>Show View > Others.. > General & [message #1864542 is a reply to message #1863960] Fri, 22 March 2024 06:13 Go to previous messageGo to next message
If I want to remove the item Welcome in the views, Do you know how to remove it in my product? if I can not customize it, I think I should remove it.
[Updated on: Fri, 22 March 2024 06:14] by Moderator
Re: IntroPart is null when show welcome screen from Window>Show View > Others.. > General & [message #1871778 is a reply to message #1864542] Thu, 10 October 2024 04:47 Go to previous message
Hello.
I am getting the same error when I test my Eclipse plugins.
The way I do it, I create my plugins in Eclipse and then Launch a configuration like this.
index.php/fa/45288/0/
I get that Welcome Page error every time I start or launch my application.
Is there a way to turn it off? Or remove it?
Thank you.
  • Attachment: 29283-02.png
    (Size: 35.13KB, Downloaded 660 times)
[Updated on: Thu, 10 October 2024 05:10] by Moderator
Previous Topic:Dynamic toolbar won't appear in Eclipse RCP app
Next Topic:High DPI problem.
Current Time: Sun Aug 31 02:13:51 EDT 2025
Powered by FUDForum. Page generated in 0.06853 seconds
