Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4DIAC with Factory I/O(Error with Subscription)
4DIAC with Factory I/O [message #1870830] Mon, 09 September 2024 21:00 Go to next message
Hello, Im trying to use 4Diac with OPC UA to connect it to an application at Factory I/O, I mean to use subscribe to active an event in other FB, but my subscriber keeps acticvating the event 'IND', without any change at tha variable at the ID
  • Attachment: print.jfif
    (Size: 87.76KB, Downloaded 71 times)
Re: 4DIAC with Factory I/O [message #1870851 is a reply to message #1870830] Tue, 10 September 2024 03:31 Go to previous messageGo to next message
Unfortunately this is partly a problem of Factor I/O. Factory I/O is writing values to the OPC UA server all the time and our Subscribe block will get an IND everytime the value is written even if it is not changed.
Re: 4DIAC with Factory I/O [message #1871331 is a reply to message #1870851] Fri, 20 September 2024 14:31 Go to previous message
Thanks for the reply!
Previous Topic:unable to build 4diac-IDE [develop] with maven
Next Topic:READ data from file
Current Time: Sun Aug 31 12:09:44 EDT 2025
Powered by FUDForum. Page generated in 0.03943 seconds
