Home » Modeling » TMF (Xtext) » [LSP]: How to support project configuration files
[LSP]: How to support project configuration files [message #1870557] Tue, 03 September 2024 06:30 Go to next message
I'm currently trying to find out how to best implement a project configuration file (e.g. similar to .project/.classpath of JDT Projects).
For example, this configuration contains values relevant to the initialization of the project (e.g. something similar to the classpath in java) in the LSP and the validator.
Changes to the project configuration therefore affect all resources of a project and should be picked up automatically after a change to the file.
I looked into org.eclipse.xtext.workspace.IProjectConfig, however, I found no way of refreshing the config once it was created.
Also, I looked into modeling the configuration file as a language, however, that seems heavyweight.
How would you implement this feature?
Sebastian
Re: [LSP]: How to support project configuration files [message #1870560 is a reply to message #1870557] Tue, 03 September 2024 06:53 Go to previous messageGo to next message
Can you check didworkspaceconfigurationchanged implementation
Re: [LSP]: How to support project configuration files [message #1870563 is a reply to message #1870560] Tue, 03 September 2024 07:02 Go to previous messageGo to next message
This request is sent from the Client, so I would have to implement that logic in every client. Also, by default the whole workspace is refreshed, which results in unecessary work if there are multiple projects in the workspace.
Re: [LSP]: How to support project configuration files [message #1870569 is a reply to message #1870563] Tue, 03 September 2024 07:08 Go to previous messageGo to next message
Maybe I reparse the config during incremental building and update the IProjectConfig of the ResourceSet. Would that be a valid approach?
Re: [LSP]: How to support project configuration files [message #1870572 is a reply to message #1870569] Tue, 03 September 2024 07:19 Go to previous messageGo to next message
There is also the did configuration. Change in lsp
Don't you have any control in the client ?
Maybe you can also use
Difdchangewatchedfiiles or however it is exactly called
Re: [LSP]: How to support project configuration files [message #1870578 is a reply to message #1870572] Tue, 03 September 2024 09:53 Go to previous messageGo to next message
The documentation of org.eclipse.xtext.ide.server.LanguageServerImpl#didChangeConfiguration says, that the notification is sent from the client;
A notification sent from the client to the server to signal the change of configuration settings.
I have control over one specific client (VSCode) but I don't know what other editors are going to be used.
I don't want to watch the files, because then I have to trigger the builder myself.
Re: [LSP]: How to support project configuration files [message #1870656 is a reply to message #1870578] Wed, 04 September 2024 10:44 Go to previous message
As I indicated there is no ootb solution
Previous Topic:Code Action Resource access
Next Topic:Create object of dsl ecore classes programatically from generator (xtend)
Current Time: Wed Sep 17 03:47:20 EDT 2025
Powered by FUDForum. Page generated in 0.04124 seconds
