Home » Eclipse Projects » Oomph » Unable to install latest eclipse on my windows 10 pc using file eclipse-inst-jre-win64(Unable to install latest eclipse on my windows 10 pc using file eclipse-inst-jre-win64)
Unable to install latest eclipse on my windows 10 pc using file eclipse-inst-jre-win64 [message #1869363] Wed, 14 August 2024 02:34 Go to next message
Unable to install latest eclipse on my windows 10 pc using file eclipse-inst-jre-win64 downloaded from link https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2024-06/R/eclipse-inst-jre-win64.exe&mirror_id=1248 .
Anyone pls help asap. It will be great help. Am struggling since many days?
I have currently following java versions installed on my systems
C:\Users\HP>java --version
java 22.0.2 2024-07-16
Java(TM) SE Runtime Environment (build 22.0.2+9-70)
Java HotSpot(TM) 64-Bit Server VM (build 22.0.2+9-70, mixed mode, sharing)
I have pasted the output below from file C:\Users\HP\AppData\Local\Temp\eoiD145.tmp\configuration\1723614951329 file generated on my desktop:
!SESSION 2024-08-14 11:25:50.796 -----------------------------------------------
eclipse.buildId=unknown
java.version=17.0.11
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64 -data @noDefault
!ENTRY org.eclipse.osgi 4 0 2024-08-14 11:25:56.786
!MESSAGE An error occurred while automatically activating bundle org.eclipse.oomph.setup.installer (159).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.oomph.setup.internal.installer.SetupInstallerPlugin$Implementation.start() of bundle org.eclipse.oomph.setup.installer.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:854)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:775)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1057)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:387)
at org.eclipse.osgi.container.Module.doStart(Module.java:639)
at org.eclipse.osgi.container.Module.start(Module.java:498)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:528)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:620)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:348)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:414)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass0(BundleLoader.java:520)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:434)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:174)
at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:643)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:223)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:987)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:275)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:65)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:143)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:109)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:439)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:271)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:668)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:605)
at org.eclipse.equinox.launcher.Main.run(Main.java:1481)
Caused by: java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
C:\Users\HP\AppData\Local\Temp\eoiD145.tmp\configuration\org.eclipse.osgi\172\0\.cp\swt-win32-4965r11.dll: The specified procedure could not be found
no swt-win32 in java.library.path: C:\Users\HP\AppData\Local\Temp\eoiD145.tmp;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Users/HP/AppData/Local/Temp/eoiD145.tmp//plugins/org.eclipse.justj.openjdk.hotspot.jre.minimal.stripped.win32.x86_64_17.0.11.v20240426-2108/jre/bin/server;C:/Users/HP/AppData/Local/Temp/eoiD145.tmp//plugins/org.eclipse.justj.openjdk.hotspot.jre.minimal.stripped.win32.x86_64_17.0.11.v20240426-2108/jre/bin;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Java\jdk-22\bin;C:\Users\HP\AppData\Local\Programs\Python\Launcher\;C:\Users\HP\Downloads;;.
no swt in java.library.path: C:\Users\HP\AppData\Local\Temp\eoiD145.tmp;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Users/HP/AppData/Local/Temp/eoiD145.tmp//plugins/org.eclipse.justj.openjdk.hotspot.jre.minimal.stripped.win32.x86_64_17.0.11.v20240426-2108/jre/bin/server;C:/Users/HP/AppData/Local/Temp/eoiD145.tmp//plugins/org.eclipse.justj.openjdk.hotspot.jre.minimal.stripped.win32.x86_64_17.0.11.v20240426-2108/jre/bin;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files\Java\jdk-22\bin;C:\Users\HP\AppData\Local\Programs\Python\Launcher\;C:\Users\HP\Downloads;;.
C:\Users\HP\.swt\lib\win32\x86_64\swt-win32-4965r11.dll: The specified procedure could not be found
Can't load library: C:\Users\HP\.swt\lib\win32\x86_64\swt-win32.dll
Can't load library: C:\Users\HP\.swt\lib\win32\x86_64\swt.dll
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:345)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:254)
at org.eclipse.swt.internal.C.<clinit>(C.java:19)
at org.eclipse.swt.internal.win32.STARTUPINFO.<clinit>(STARTUPINFO.java:42)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:149)
at org.eclipse.oomph.setup.internal.installer.SetupInstallerPlugin$Implementation.start(SetupInstallerPlugin.java:133)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:833)
at org.eclipse.osgi.internal.framework.BundleContextImpl$2.run(BundleContextImpl.java:1)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:825)
... 31 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2024-08-14 11:25:56.836
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.oomph.setup.installer was unable to load class org.eclipse.oomph.setup.internal.installer.InstallerApplication.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:242)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:225)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.oomph.setup.installer (159).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:134)
... 15 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.oomph.setup.internal.installer.SetupInstallerPlugin$Implementation.start() of bundle org.eclipse.oomph.setup.installer.
... 24 more
... 31 more
Re: Unable to install latest eclipse on my windows 10 pc using file eclipse-inst-jre-win64 [message #1869375 is a reply to message #1869363] Wed, 14 August 2024 09:44 Go to previous message
I can only theorize that some virus tool is blocking the creation of the dll in your temp folder. For me when I run the installer I can see that dll there
C:\Users\merks\AppData\Local\Temp>find eoi*  -name swt-win32-4965r11.dll
eoi5DA8.tmp/configuration/org.eclipse.osgi/170/0/.cp/swt-win32-4965r11.dll
eoi75AF.tmp/configuration/org.eclipse.osgi/170/0/.cp/swt-win32-4965r11.dll
The installer is effectively like a self-extracting zip and some tools might find that suspicious.
You might try the zipped form and unzip it yourself:
https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2024-06/R/eclipse-inst-jre-win64.zip
Failing the installer working at all, you can download and unzip a package:
Previous Topic:Installation fails
Next Topic:Portable JAVA+DSL installer with ecoretools diagram editor
Current Time: Sun Jun 15 18:31:26 EDT 2025
Powered by FUDForum. Page generated in 0.04917 seconds
