Issue Generating Java Code Programmatically from Ecore Model Using Gen Model [message #1867392] |
Mon, 24 June 2024 12:48  |
I have written the following code to programmatically create a GenModel and generate Java code from an Ecore model. While the code successfully generates the GenModel file (e.g., Family.genmodel), it does not generate the Java code as expected.
Could someone help identify what might be missing or incorrect in my code?
Any help or guidance would be greatly appreciated!
Here is the code:
package com.example.codegen.codeGenerator;
import org.eclipse.emf.codegen.ecore.generator.Generator;
import org.eclipse.emf.codegen.ecore.genmodel.GenModel;
import org.eclipse.emf.codegen.ecore.genmodel.GenModelFactory;
import org.eclipse.emf.codegen.ecore.genmodel.GenModelPackage;
import org.eclipse.emf.codegen.ecore.genmodel.generator.GenBaseGeneratorAdapter;
import org.eclipse.emf.codegen.ecore.genmodel.generator.GenModelGeneratorAdapterFactory;
import org.eclipse.emf.common.util.BasicMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.emf.ecore.xmi.impl.XMLResourceFactoryImpl;
import java.io.File;
import java.io.IOException;
import java.util.Collections;
public class CodeGenerator {
String ecorePath = "/Users/adielt./Documents/demo/src/main/resources/model/Family.ecore";
String genModelPath = "/Users/adielt./Documents/demo/src/main/resources/codegen/Family.genmodel";
String outputDirectory = "/Users/adielt./Documents/demo/src/main/java";
String modelName = "Family";
// Verify and load the .ecore file
ResourceSet resourceSet = createResourceSet();
Resource ecoreResource = loadEcoreModel(resourceSet, ecorePath);
if (ecoreResource == null) return;
// Create and configure the GenModel
GenModel genModel = createGenModel(ecoreResource, outputDirectory, modelName);
saveGenModel(resourceSet, genModel, genModelPath);
// Load the saved GenModel
GenModel loadedGenModel = loadGenModel(resourceSet, genModelPath);
if (loadedGenModel == null) return;
// Generate the code
generateCode(loadedGenModel, outputDirectory);
private static ResourceSet createResourceSet() {
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("genmodel", new XMLResourceFactoryImpl());
return resourceSet;
private static Resource loadEcoreModel(ResourceSet resourceSet, String ecorePath) {
System.out.println("Loading the Ecore file...");
URI ecoreURI = URI.createFileURI(ecorePath);
Resource ecoreResource = resourceSet.getResource(ecoreURI, true);
try {
ecoreResource.load(null);
} catch (IOException e) {
e.printStackTrace();
return null;
if (ecoreResource.getContents().isEmpty()) {
System.err.println("Error: The Ecore file does not contain any packages.");
return null;
System.out.println("Ecore file loaded successfully.");
return ecoreResource;
private static GenModel createGenModel(Resource ecoreResource, String outputDirectory, String modelName) {
EPackage ePackage = (EPackage) ecoreResource.getContents().get(0);
GenModel genModel = GenModelFactory.eINSTANCE.createGenModel();
genModel.initialize(Collections.singleton(ePackage));
genModel.setModelName(modelName);
genModel.setModelDirectory(outputDirectory.replace("\\", "/"));
genModel.setCanGenerate(true);
genModel.setValidateModel(true);
System.out.println("GenModel configuration completed.");
return genModel;
private static void saveGenModel(ResourceSet resourceSet, GenModel genModel, String genModelPath) {
URI genModelURI = URI.createFileURI(genModelPath);
Resource genModelResource = resourceSet.createResource(genModelURI);
genModelResource.getContents().add(genModel);
try {
genModelResource.save(null);
System.out.println("GenModel saved successfully.");
private static GenModel loadGenModel(ResourceSet resourceSet, String genModelPath) {
System.out.println("Loading the saved GenModel...");
Resource genModelResource = resourceSet.getResource(genModelURI, true);
try {
genModelResource.load(null);
return null;
if (genModelResource.getContents().isEmpty()) {
System.err.println("Error: The saved GenModel does not contain any data.");
return null;
System.out.println("Saved GenModel loaded successfully.");
return (GenModel) genModelResource.getContents().get(0);
private static void generateCode(GenModel genModel, String outputDirectory) {
genModel.reconcile();
genModel.setForceOverwrite(true);
Generator generator = new Generator();
generator.setInput(genModel);
generator.getAdapterFactoryDescriptorRegistry().addDescriptor(GenModelPackage.eNS_URI, GenModelGeneratorAdapterFactory.DESCRIPTOR);
// Generate the MODEL_PROJECT_TYPE code
System.out.println("Starting MODEL_PROJECT_TYPE generation...");
generator.generate(genModel, GenBaseGeneratorAdapter.MODEL_PROJECT_TYPE, new BasicMonitor.Printing(System.out));
System.out.println("MODEL_PROJECT_TYPE generation completed.");
// Verify if the files have been generated
File generatedDir = new File(outputDirectory);
File[] generatedFiles = generatedDir.listFiles();
if (generatedFiles != null && generatedFiles.length > 0) {
System.out.println("Java code generated successfully in the directory: " + outputDirectory);
for (File file : generatedFiles) {
System.out.println("Generated: " + file.getAbsolutePath());
} else {
System.err.println("Error: No files generated in the output directory.");
public static String getFileExtension(String fullName) {
String fileName = new File(fullName).getName();
int dotIndex = fileName.lastIndexOf('.');
return (dotIndex == -1) ? "" : fileName.substring(dotIndex + 1);
FUDForum. Page generated in 0.03705 seconds
